Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Mar 31, 2020 at 11:50 PM
    Bloodytaco208
    Bloodytaco208 Well-Known Member
    Twisted steel sex appeal reg cab tacoma
    Bunch of built and bought mods
    I spent quite a bit of time in enterprise and dothan. I donated a lot of money to teasers lol
  2. Mar 31, 2020 at 11:51 PM
    Bloodytaco208
    Im too gringo to go to mexico. You can smell American on me.
    BananaMan likes this.
  3. Apr 1, 2020 at 12:12 AM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    I couldn't even do street tuning if I wanted to right now... Maine governor just imposed the stay at home order for a month. If you don't comply it's 6 months in the slammer or 1k out of your wallet
    MadTaco461 likes this.
  4. Apr 1, 2020 at 10:06 AM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Already out of MAF in open loop? I took mine up to about 4.88V total output before I switched injectors, but I'm a 99. You could probably take it to 4.75V if you are working in volts in your fuel table.
    I'm keeping low on the street tuning since everyone is home. I know it is safe once the rowdy teenagers are out in their ricers.
    Jstand and Torspd like this.
  5. Apr 1, 2020 at 10:55 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Curious if you are even able to make it to any off road areas, like you used to? Now that I think about it.
  6. Apr 1, 2020 at 11:52 AM
    MadTaco461
    CA
    Kinda stock
    They shutdown all the state parks because people starting flooding them over the weekend. Technically federal land is open, but I wouldn't be surprised if that gets closed too or rangers out ticketing people. It's set up so people don't go flooding the gas stations and stores out in the desert areas and affecting the people that live out there. Any type of travel outside your city is looked down on right now. I have some other things I can wrench on right now.
    Bloodytaco208 likes this.
  7. Apr 1, 2020 at 12:18 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Got to keep those hands busy! Been playing a lot of Rummikub, and doing a little wrenching.
    Bloodytaco208 and MadTaco461 like this.
  8. Apr 1, 2020 at 12:48 PM
    Kamshaft2142
    Kamshaft2142 Member
    Kamrin
    2008 tacoma 4.0l v6
    Stage 3 URD supercharger LCengineering electric cooling fan Aem wideband & boost
  9. Apr 1, 2020 at 12:49 PM
    Kamshaft2142
    Kamshaft2142 Member
    Kamrin
    2008 tacoma 4.0l v6
    All things that cause boost creep. Need help
  10. Apr 1, 2020 at 9:09 PM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    What's it spiking to?
    Could start with hooking up the rest of the exhaust.
    Run Wastegate signal line off compressor.
    Poor wastegate position or too small could be a thing.
  11. Apr 1, 2020 at 10:08 PM
    Kamshaft2142
    Kamshaft2142 Member
    Kamrin
    2008 tacoma 4.0l v6
    9psi spring spiking to 11.1. Exhaust obviously isn’t finished but the wastegate is plenty big. This is a second-hand kit and it did work just fine before but something is going on with my setup. Possibly vacuum I guess
  12. Apr 2, 2020 at 4:47 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Where is your wg boost coming from? If it is post IC you could try making it pre IC and then it would see 11.1 psi before you were really making that at the manifold
  13. Apr 2, 2020 at 5:02 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    He has a point. Where is your boost gauge getting its reference from? After the throttle body, or before?
    As well as rerouting the w/g vacuum source from manifold to compressor housing would do like yota said. As there might be a psi or so lost along the length of the intake system. So moving the source to the compressor housing could lower the overall psi. As long as yours isn't already setup like that?
  14. Apr 2, 2020 at 6:07 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Used to play that game all the time!
    Torspd[QUOTED] likes this.
  15. Apr 2, 2020 at 7:35 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Very fun game. Hours go by quickly.
    Reh5108[QUOTED] likes this.
  16. Apr 2, 2020 at 9:24 AM
    yota243
    E.J.
    north Alabama
    I did have $.07 off per gallon but still this is a new low for me... Never have i put gas in my vehicle this cheap...
    05Taco4x4 likes this.
  17. Apr 2, 2020 at 11:28 AM
    Kamshaft2142
    Kamshaft2142 Member
    Kamrin
    2008 tacoma 4.0l v6
    So right now wastegate is Plumbed to the vacuum line right after the throttle body and that exactly where I have the boost gauge routed to as well. Turbo doesn’t have a port on the compressor housing but I do have room to reference the wastegate in the charge pipe right after the turbo.
  18. Apr 2, 2020 at 11:46 AM
    Jon64l
    Jon
  19. Apr 2, 2020 at 12:13 PM
    Kamshaft2142
    Kamshaft2142 Member
    Kamrin
    2008 tacoma 4.0l v6
    Thank you. I’ll give that a go
  20. Apr 2, 2020 at 12:58 PM
    Reh5108
    Idaho
    I just had my compressor housing off and noticed that one of the bolts that hold the clamps on goes all the way through. I've considered using that as a reference point. Might be a possibility for you.
