Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Apr 30, 2020 at 9:33 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Noticing a trend with you 4cylinder guys. Basically most of y'all have the .6x A/R's.
    What rpm all y'all hitting max boost in 1st gear?
  2. Apr 30, 2020 at 9:36 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Done anymore driving today? Get anymore visual data?
  3. Apr 30, 2020 at 9:42 AM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Define max boost. This one is factory set to 26 psi iirc and guys run it into the 30s, I'm running it at 8psi atm
  4. Apr 30, 2020 at 9:44 AM
    05Taco4x4
    2TR-FE Enthusiast
    having said that, I haven't really tested that so not sure. Next time I go somewhere I'll give you an answer :thumbsup:
    Torspd likes this.
  5. Apr 30, 2020 at 9:48 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    What every your max boost that you are using, is.
    05Taco4x4[QUOTED] likes this.
  6. Apr 30, 2020 at 9:53 AM
    05Taco4x4
    2TR-FE Enthusiast
    I doubt mine will hit 8psi in first, we'll see
  7. Apr 30, 2020 at 10:00 AM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    Quick update.
    I was able to get 5psi at about 2300rpm at part throttle in overdrive today. Any more pedal and it drops a gear into 3rd.
    05Taco4x4 and MadTaco461 like this.
  8. Apr 30, 2020 at 10:10 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That is an improvement, yes? That's very early.
  9. Apr 30, 2020 at 10:15 AM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    My first gear is pretty short. I probably hit max boost in that gear probably 5k rpms. It feels like it is still building when I'm getting ready to shift.
  10. Apr 30, 2020 at 10:20 AM
    Jon64l
    Jon
    Yes, definitely more than before with the 1.03.
    Torspd[QUOTED] likes this.
  11. Apr 30, 2020 at 10:25 AM
    05Taco4x4
    2TR-FE Enthusiast
    That’s a great point, my R155 is pretty tall
  12. Apr 30, 2020 at 10:26 AM
    05Taco4x4
    2TR-FE Enthusiast
    Is why I’m still eyeing the auto conversion
    BassAckwards likes this.
  13. Apr 30, 2020 at 10:46 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I have such a long first gear. 2.66, with a 3.73 final. With my old exhaust setup, with this 1.04, it was still breaking threshold at 2k.
  14. Apr 30, 2020 at 11:25 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Obvious question, but going to ask anyway. Your speedo has been corrected for the tire size, yes?
  15. Apr 30, 2020 at 11:27 AM
    MadTaco461
    CA
    Kinda stock
    Wow your first might be as long as my 2nd. Maybe I should rephrase. All my gears are short. I have an R155 in my truck. 1st gear is 3.95 and I'm 4.56 on 33's MT
    Maybe I can get in the truck and bang thru the gears on the gopro this week. I need to drive that poor thing.
  16. Apr 30, 2020 at 11:30 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Heck yeah! I'd like to see that!
    It is a celebratory event, everytime I get into 6th. Being a .50. Never need it, unless cruising way out down I-10.
    MadTaco461[QUOTED] likes this.
  17. Apr 30, 2020 at 11:35 AM
    Bloodytaco208
    Bloodytaco208 Well-Known Member
    Twisted steel sex appeal reg cab tacoma
    Bunch of built and bought mods
    Ive never hit max boost in first i rarely hit boost in 1st gear. Due to gearing i rarely put a load on the engine large to create enough drive pressure to create positive pressure. Maybe when im whèeling or pulling a trailer is when i can hit boost in 1st.
  18. Apr 30, 2020 at 11:42 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I apologize. Could you remind me of the specs of your turbo again?
  19. Apr 30, 2020 at 11:45 AM
    05Taco4x4
    2TR-FE Enthusiast
    To the best of my ability, yes
  20. Apr 30, 2020 at 11:46 AM
    05Taco4x4
    2TR-FE Enthusiast
    Ok, I’m 4.1 on 32s atm
