Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Apr 30, 2020 at 8:25 PM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2006 Tacoma, 2000 4runner, 1996 Tacoma
    MadTaco461 likes this.
  2. Apr 30, 2020 at 8:44 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  3. Apr 30, 2020 at 8:47 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I feel like I guessed pretty well. That is very impressive!
    Now the next question is, will cruising over 2k mean that you're in boost or no?
  4. Apr 30, 2020 at 9:03 PM
    Jon64l
    Jon
    Cruising is fine. Drives like a normal truck. It's not the Rpm, its load. So towing, uphill or head wind could put it in boost. Too soon to tell, but so far so good.
    @Torspd
  5. Apr 30, 2020 at 11:24 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Gonna be the ideal A/R really for this. Be super street able and fun. which it looks like you're finding out.
  6. Apr 30, 2020 at 11:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    2" for increased velocity/faster spool.
    2.25" if you're going for just a HP queen.
    Id go down to .81 A/R at least as well, aren't you twin? Or is that a different guy..
  7. May 1, 2020 at 5:52 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    I'm also throwing a vote for 2"; a lot less "stuff" you gotta make room for with the smaller pipes and it will be lighter and gas velocity will be higher and you can weld 2" faster than 2.25" haha
  8. May 1, 2020 at 6:33 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I’d like to be twin, but don’t think I’d ever spool two 9180’s lol.
    There might be a smaller A/R for mine, but if memory serves somewhat accurately, it is only in a T3. Being that I don’t have that kind of housing, it rules that choice out.
    Oh yeah, well aware. Just getting a mental comparison between your setup and how quickly it spools, versus the story of my friend’s with his smaller sized turbo on his 1GR. Going off of rpm because I cannot remember where an XR runs in vacuum cruising, between 2 & 3k rpms on level ground.
    Also reminds me of a conversation with an engineer from Both Warner. They were working with a drag racing team. Maybe Australia? Twin 9180's. At idle the turbos were creating 1-2 psi! I digress. My 4 liters of fury still needs the load plus 3k to make the choo choo sounds happen.
    Speaking of which, after correcting my VVTi map the other day, my engine is much more responsive. Including spool time.
  9. May 1, 2020 at 8:12 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Why did you go with such a big turbo?
  10. May 1, 2020 at 9:23 AM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Is there any interest from 2nd Gen 2TR guys for a billet valve cover?
  11. May 1, 2020 at 9:30 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Because everything is built for 1k+. I take that back. I still need to revise the fuel system. That Walbro 480 isn't enough.
  12. May 1, 2020 at 9:37 AM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    What is the redline on your motor? I was playing with the BW matchbot with your turbo and you can make over 800hp around 6500rpms with only 20 psi pump gas. Even can make 15psi by 3k rpms holding your wastegate shut pretty aggressively. 7000rpm's and the turbo is going outside the curve.
    Torspd[QUOTED] likes this.
  13. May 1, 2020 at 9:41 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    6200 RPM's. It would before on the old setup. Hit that boost like that. I have too long a section of 3" before the inlet, is why.
  14. May 1, 2020 at 9:44 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I could go higher, but there is no need. Not with my gearing.
  15. May 1, 2020 at 9:51 AM
    MadTaco461
    CA
    Kinda stock
    dual 2.25" is a larger x-section than 3" You are probably decreasing your volume with the new setup.
    15psi at 3k is pretty rowdy. I'm a bit later than that.
  16. May 1, 2020 at 10:28 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Just a tad larger, but yeah I know when you're coming from. When I originally planned out the kit, years ago, I ran a bunch of numbers. Header outlet size also being considered.
    I still have 2.25 from both sides. Just like back then. Even with the journal bearing setup, it still was a little quicker than now. The dual 2.25 merge to 3" T4 was right before the flange. Problem was accessibility and disassembly ease. So tried a slightly different routing to add in a v-band to make it easy to remove the turbo. Super easy to remove now, but the sacrifice was spool time.
    The 2.25 doesn't really seem to be THE issue more than leading into it, or in a few cases, going larger.
    The kits with 1.75" primaries reduced the velocity as well. They had slower spool times than mine with 1 5/8" primaries (Doug Thorley and URD Spec-U diameters). They still had higher torque than HP though.
    One kit had 1 5/8" primaries, into 2.5" Y-pipe legs, then into 2.5" or 3" and finally into the turbo. They had a laggy boost, but also more importantly LESS torque than HP. Imagine that.
    My goal is to go back to 1 5/8" primaries, and then either of the two twin scroll inlet sizes.
    The 2.25, in the past, had a pretty flat torque curve. Where I feel that the 2" may spike then taper off, as a matter of high RPM restriction.
    MadTaco461[QUOTED] likes this.
  17. May 1, 2020 at 12:07 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Hell yeah!
  18. May 1, 2020 at 12:08 PM
    MadTaco461
    CA
    Kinda stock
    Wild, single turbo v6 sure is a sensitive setup to make.
    Life would be easy if you could set the turbo over the v section like a duramax.
  19. May 1, 2020 at 12:53 PM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    Hell yes
  20. May 1, 2020 at 1:27 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Right?! Especially if it had the dual inlets, in the turbine housing!
