Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. May 19, 2017 at 8:42 AM
    #1241
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    The turbo heats your oil further than it would normally be heated causing it to become thin and break down. Using a thicker 5w-40, with more additives helps prevent this.
    GreeGunc[QUOTED] likes this.
  2. May 19, 2017 at 10:35 AM
    #1242
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    @Jstand have you put in one way check valves where they need to go, added a breather filter to the others, and rerouted your fpr vacuum to manifold?
    MrCrowntown likes this.
  3. May 19, 2017 at 11:27 AM
    #1243
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    I haven't done any one way check valves but I've done the other things you mentioned
  4. May 19, 2017 at 7:29 PM
    #1244
    j0shu4
    That could be your problem the check valve. Most of us use a little one from eBay or Amazon. Just a plastic little one way vacuum breather. You did put a little cone filter on the tubes that need to breathe? I can shoot a couple pics of the check valve and breather
  5. May 19, 2017 at 10:52 PM
    #1245
    Brice
    Brice Turbo Member
    Brice
    Texas
    Unless the pcv system is causing a vacuum leak, which it may be, then it wouldn't really affect anything I don't think.
  6. May 20, 2017 at 12:24 AM
    #1246
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Its required for the supercharger. Be a good idea for a turbo
  7. May 20, 2017 at 4:21 AM
    #1247
    Jstand
    Irving,Tx
    yes please:)
  8. May 20, 2017 at 4:47 AM
    #1248
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    And we all know that the PCV system confuses people as far as routing is concerned, when a turbo is introduced. 4 Turbo kit people I always say it's easiest just to vent it to atmosphere. Valve cover two pre turbo inlet will also work as well.
  9. May 20, 2017 at 4:52 AM
    #1249
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    So many number homonyms so wrong... Tew urly fur thice shyt
    Torspd[QUOTED] likes this.
  10. May 20, 2017 at 5:15 AM
    #1250
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Eh. Talk to text.
    yota243 likes this.
  11. May 20, 2017 at 7:23 AM
    #1251
    Jstand
    Irving,Tx
    So I'm guessing from this that I should vent PVC to atmosphere and plug the spot on the intake
  12. May 20, 2017 at 7:28 AM
    #1252
    yota243
    E.J.
    north Alabama
    As long as ur pcv doesnt see boost it shouldnt be a big deal, but i think most run a catch can and vent to atm... By most i mean me for sure
    Jstand[QUOTED] likes this.
  13. May 20, 2017 at 7:48 AM
    #1253
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    For testing right now, yes
  14. May 22, 2017 at 5:35 AM
    #1254
    yota243
    E.J.
    north Alabama
  15. May 22, 2017 at 6:18 AM
    #1255
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :pccoffee:
    Still waiting on @MadTaco461 to install that IAT sensor. :playball:
    MadTaco461 likes this.
  16. May 22, 2017 at 1:14 PM
    #1256
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    I think he is still working on getting everything for the trans
    Unless he is slackin at posting updates!!!
  17. May 22, 2017 at 1:38 PM
    #1257
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Been lacking motivation starting the transmission swap. I haven't done anything to the truck lately,lol. It was 100 degrees over the weekend and I was like nope maybe next weekend since it suppose to be nice and cool.
  18. May 22, 2017 at 1:39 PM
    #1258
    MrCrowntown
    Alyn
    Ky
    I miss that about Cali. Wait a week and get better temps. Were about to jump head first into the 100+ which will probably last over 100+ days lol........
    MadTaco461[QUOTED] likes this.
  19. May 22, 2017 at 1:52 PM
    #1259
    MadTaco461
    CA
    Kinda stock
    I sit about 10 to 15 degrees cooler than az during the summer. Makes a difference for sure. First 100 degree weekend my body wasn't ready for it,lol.
    MrCrowntown[QUOTED] likes this.
  20. May 22, 2017 at 2:09 PM
    #1260
    Jstand
    Irving,Tx
    Texas too
