Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Sep 20, 2020 at 6:29 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    MAF sensors, absolutely. MAP sensors are based on BAR. Barometric pressure changes. Their resolution is based off of how many BAR they are capable of reading per a specified voltage.
    1 BAR would be vacuum to Atmospheric pressure. 2 is above atmosphere. And so on.
    Not by a flow through a cross sectional surface area.
    Hawk373 likes this.
  2. Sep 20, 2020 at 6:33 PM
    420taco
    420taco Well-Known Member
    Justin
    PA
    Right, the sensor won’t care but the ecm’s load calculation is going to be way off now. It’s gonna need a lot more fuel for a given pressure with the bigger pipe.
  3. Sep 20, 2020 at 6:34 PM
    Hawk373
    Hawk373 Well-Known Member
    2012 TRD Sport DCLB
    DMZ, ADS, King, JFR, SOS, ECGS, LSK
    I just figured out the third variable the ECM uses. Temp/pressure are from the MAP and engine speed dictates how much fuel based off that air density calculation. Correct?
  4. Sep 20, 2020 at 6:38 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Air temp could be on that pressure sensor or be its own.
    You are correct though. The MAP sensor gives the load, then the rpm gives the speed. Then the VE calculations off of that, give the fueling necessary to maintain programmed AFR's.
    Hawk373 likes this.
  5. Sep 20, 2020 at 6:41 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If the main fueling is based off of the post TB sensor, then nothing changed, so that won't affect the tune. Having an increased or deceased load, based off of flow characteristics of changed parts, per rpm, will.
    How flexible the OEM tuning software is, will determine how well it can adapt to changed parts.
    Hawk373 likes this.
  6. Sep 20, 2020 at 6:41 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Usually intercooler swaps are plug and play without a tune needed. Map sensors are bothered. Never seen a map sensor on a charge pipe before yet. Post a pic?
    You will get more out of the intercooler if you have the car tuned
    Hawk373[QUOTED] likes this.
  7. Sep 20, 2020 at 6:42 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I am curious was TMAP stands for.
  8. Sep 20, 2020 at 6:45 PM
    Hawk373
    2012 TRD Sport DCLB
    So the ECM doesn’t care about the size of the vessel supplying the air? If there is more air available to flow then so be it?
    The only thing I’m curious about is why there are two sensors, one pre and one post TB.
  9. Sep 20, 2020 at 6:46 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That comes back to what TMAP stands for.
  10. Sep 20, 2020 at 6:46 PM
    Hawk373
    2012 TRD Sport DCLB
    It’s what you were saying before, temperature manifold absolute pressure. The rear sensor doesn’t measure temp.
  11. Sep 20, 2020 at 6:47 PM
    MadTaco461
    CA
    Kinda stock
    Temperature
  12. Sep 20, 2020 at 6:49 PM
    MadTaco461
    CA
    Kinda stock
    I'm a bit behind, lol. Thanks for the photo. Never seen a map sensor in the charge pipe before. Do you have an electric bypass valve?
    Hawk373 likes this.
  13. Sep 20, 2020 at 6:56 PM
    Hawk373
    2012 TRD Sport DCLB
    This is the first intercooler kit that replaces all the plumbing for this engine. Most intercoolers only replace the exchanger itself.
    Yes there is a solenoid. I was just in the middle of writing my speculation about that.
    MadTaco461[QUOTED] likes this.
  14. Sep 20, 2020 at 7:02 PM
    Hawk373
    2012 TRD Sport DCLB
    Ok, well at least I have a better grasp of things going on with the MAP system.
    I’ll do a bunch of logs before and after and look for any evidence suggesting that it’s leaning out and losing timing.
    Thanks guys!
    MadTaco461 and Torspd like this.
  15. Sep 20, 2020 at 7:43 PM
    MrMurse
    MrMurse Well-Known Member
    Riley
    St. George, Utah
    2006 Crew Cab TRD Sport Tacoma
    Turbocharger with all the fixins
    Random question: Does anyone have a stock intake and/or stock injectors laying around that I could borrow/buy? @JustDSM and I are trying to get a tune working for my turbo build but have run into trouble. He recommended swapping those items to get a baseline, but I don't have them. Thanks!
  16. Sep 20, 2020 at 7:54 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    What kind of issue?
  17. Sep 20, 2020 at 8:09 PM
    MrMurse
    Riley
    St. George, Utah
    We are putting in known values like injector data, MAF housing diameter, etc, and getting very unexpected results. We're seeing trims with a sum total applying upwards of 50% correction. So, the thought was this: essentially turning the motor back into a N/A setup to run at idle with OE MAF calibrations and injector data to eliminate any and all ECU related issues.
  18. Sep 21, 2020 at 12:20 AM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    It hasn’t been done, I’m probably going to sell it to move into something with four doors and don’t want to drop $1200 in it
  19. Sep 21, 2020 at 4:35 AM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    @Hawk373
    I run a VW 1.8t and have had it for years through multiple tune vendors. Currently it’s getting a bigger Holset turbo plumbed in.
    As for the sensors and larger FMIC/piping, I don’t see it being an issue. My MAF, MAP, and temp sensors are pre throttle body. 20psi is 20psi, be it in a 3” IC pipe or 2” IC pipe because it still bottle necks down through the TB to the intake manifold anyway. The larger piping will make for smoother transitions rolling onto the throttle but all that air has to stop when the TB closes when getting off the throttle. A larger post IC pipe will cause a pressure drop which will also drop the temps some but not significantly enough to help HP wise.
    Plug your numbers into this calculator as honestly as possible and have a look. Use maybe 5* degrees cooler than ambient for the IC temp and about 60-70% for efficiency. Water/meth injection goes a long way, too. Worth getting into that also. I'm looking at +20hp/tq gain just from summer temps to 70* fall temps in Southern Miss. I know it is a lot more peppy when it's cool out vs hot. Very noticeable when we get those 20* temp swings from one day to the next this time of year.
    http://www.not2fast.com/turbo/glossary/turbo_calc.shtml
    Hawk373 and Torspd like this.
  20. Sep 21, 2020 at 4:38 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Need some good pictures of your engine bay. Need to see the MAF and vacuum hoses from both valve covers to the intakes.
