Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Dec 14, 2020 at 6:54 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Better get a first start-up video. I am excited for you. Also, pull the fuel pump relay and crank it for a good bit, to get the oil circulated. Then do your start-up.
    yota243[QUOTED] likes this.
  2. Dec 14, 2020 at 6:55 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Good call. I got a new fuel pump (just the whole unit) I'm gonna put in it while ive got it in the shop.
  3. Dec 16, 2020 at 6:58 AM
    yota243
    E.J.
    north Alabama
    Sooo... The crank turns 2x every 1 turn of the cam... Pretty sure I have something upside down because it wouldnt start last night. Gonna pull the cover off and roll it to tdc, take the chain off, roll it to the next tdc and hope that's what it was. Good news is there should be plenty of oil pressure built up now...
    BananaMan likes this.
  4. Dec 16, 2020 at 7:38 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  5. Dec 16, 2020 at 7:45 AM
    yota243
    E.J.
    north Alabama
    I mean I did get video of the first cranks... Just not a start up lol
  6. Dec 16, 2020 at 7:47 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  7. Dec 16, 2020 at 7:57 AM
    yota243
    E.J.
    north Alabama
    Also on two different forums I saw where the 2 az was non-interference and zero tolerance so timing is either not a huge deal if its off or catastrophic.... I actually thought like mid 90s early 00 everyone pretty much got away from interfering engines...
  8. Dec 16, 2020 at 9:05 AM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Thinking out loud. Shouldn't need to spin the crank 360. Just need the marks lined up. Crank and cam sensor tell the motor where it is. Maybe off a tooth?
  9. Dec 16, 2020 at 9:09 AM
    yota243
    E.J.
    north Alabama
    Thats what my buddy said but I figured 1 tooth off would still at least start. It hit like 1 time on 1 cylinder over the course of probably a total of 3 or 4 minutes of cranking
  10. Dec 16, 2020 at 9:12 AM
    MadTaco461
    CA
    Kinda stock
    Test compression.
  11. Dec 16, 2020 at 9:16 AM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    The crank doesn't care when the spark plugs fire since there can be two TDC in a 4 stroke motor: one bang and one exhaust. But I bet the ECU wants to know. I used a bamboo shishkabob to find my TDC when I had my head reworked a while back. I rolled it until #1 was eyeballed TDC then I bolted the head down. Then laid the cams in, clocked them TDC, and bolted them down. Then made 4 rounds on the crank to verify it was all good and cam back exactly as it should then put everything else back on and in the engine bay. There should be that obscure crank mark to go off of and the cam marks are a lot more obvious. The crank mark is what concerned me and why I made sure to have it as close as possible before installing the head. Then the use of the stick to verify the mark below to the mark above.
    Good luck. It took a while to prime the fuel system, too. If you could jumper wire the pump it'd help speed it up some vs. whining on the starter. Also you could disconnect the tank return side and blow that into a water bottle to get the air out of the pressure side. I took the plugs out while priming the oil and I'm not sure if the fueling was priming at this time or not since the plugs were out.
  12. Dec 16, 2020 at 9:56 AM
    yota243
    E.J.
    north Alabama
  13. Dec 16, 2020 at 9:58 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Sounds more like a diesel. It's trying though.
    yota243 likes this.
  14. Dec 16, 2020 at 10:02 AM
    yota243
    E.J.
    north Alabama
    I left the fuel rail connected so still should be pressurized I figured that fueling time may be an issue if the piston in exhaust and ecu thought it was compression, maybe ill get it knocked out tonight
  15. Dec 16, 2020 at 10:22 AM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Sounds like exhaust is clogged haha check the coil wires
  16. Dec 16, 2020 at 10:42 AM
    Brake Weight
    You didn’t pull the injectors off of it?
  17. Dec 16, 2020 at 11:06 AM
    yota243
    E.J.
    north Alabama
    I just unbolted the rail and left the injectors in the rail... Its moot now after all the cranking attempts
  18. Dec 17, 2020 at 9:25 PM
    yota243
    E.J.
    north Alabama
  19. Dec 17, 2020 at 9:27 PM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    yota243[QUOTED] and 05Taco4x4 like this.
  20. Dec 18, 2020 at 3:28 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
