Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. May 29, 2017 at 12:59 PM
    #1321
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    @Jstand In reference to your previous thing about the auto trans.
    There is a $100 valve body reprogramming kit by transgo that I put in my truck. @vasinvictor also has one I believe. It has a hot rod and tow setting. I have mine on hot rod and it shifted hard enough to spin the tires in 3rd when the engine was NA. Look at your door sticker, it'll say which trans you have below where you find the gear ratios, then just order the appropriate kit. Its well worth it and keeps the trans from heating up so much.
  2. May 29, 2017 at 1:07 PM
    #1322
    Brice
    Brice Turbo Member
    Brice
    Texas
    I'd like to bring something up for the guys with auto V6's.
    The header and wastegate block my trans filler tube from bolting to the block of the engine, which in turn prevents the dipstick from going back into the filler tube. Does anybody else have this problem? If so how'd you fix it?
  3. May 29, 2017 at 1:08 PM
    #1323
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Fab work. Haz welder. Do work!
    yota243 likes this.
  4. May 29, 2017 at 1:09 PM
    #1324
    Brice
    Brice Turbo Member
    Brice
    Texas
  5. May 29, 2017 at 1:16 PM
    #1325
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    :popcorn:
  6. May 29, 2017 at 1:40 PM
    #1326
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    THANK YOU that is exactly what i was looking for:thumbsup::)
    boostedka and Brice[QUOTED] like this.
  7. May 29, 2017 at 1:43 PM
    #1327
    Brice
    Brice Turbo Member
    Brice
    Texas
    No problem man!
  8. May 29, 2017 at 2:29 PM
    #1328
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    So guys, got a new job unloading toyotas off the railroad at a warehouse and got to drive a v6 6spd. Horribly slow on take off...autos are as well. My 2.7 will burn the tires off more than that thing
    Brice likes this.
  9. May 30, 2017 at 3:35 AM
    #1329
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Lol. #Letdown #Needssnailpower
    MrCrowntown likes this.
  10. May 30, 2017 at 5:04 AM
    #1330
    GreeGunc
    Jacob
    North GA
    I was a bit heartbroken....
    It did make me not want a new one anymore
  11. May 30, 2017 at 5:15 AM
    #1331
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
  12. May 30, 2017 at 6:32 AM
    #1332
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
  13. May 30, 2017 at 6:41 AM
    #1333
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I don't. You could look up the Toyota PN and see if its the same between engines.
    boostedka[QUOTED] likes this.
  14. May 30, 2017 at 8:45 AM
    #1334
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Question:
    Flex-a-lite controller has a potentiometer (variable resistor) that is used to adjust the target temperature. I have it set as low as it can go and coolant temps are still ~195-205F.
    My question is this: Does increasing resistance increase the target temperature or decrease? If increased resistance = lower target temps, I can put a resistor in the senor volage line to lower the target temps... If not, I may have to move the sensor to the top radiator hose...
  15. May 30, 2017 at 11:13 AM
    #1335
    Brice
    Brice Turbo Member
    Brice
    Texas
    There's a video where "The Fast Lane Truck" youtube channel races 1st 2nd and 3rd gen trucks and a first gen manual V6 beat the 3rd gen V6 auto lol
    The 2nd gen V6 auto was the fastest.
    GreeGunc[QUOTED] and MadTaco461 like this.
  16. May 30, 2017 at 11:20 AM
    #1336
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  17. May 30, 2017 at 11:23 AM
    #1337
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Those guys do good road tests. When they go offroad, I want to use them as shooting practice..
    GreeGunc and Brice[QUOTED] like this.
  18. May 30, 2017 at 11:34 AM
    #1338
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  19. May 30, 2017 at 12:04 PM
    #1339
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    @Tap1 . Ask your questions in here. :thumbsup:
    GreeGunc and MrCrowntown like this.
  20. May 31, 2017 at 10:05 AM
    #1340
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Volt meter will tell you that in a heart beat. But if it's turned to the left all the way it's at the lowest setting.
