Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Mar 20, 2021 at 5:45 PM
    Sleipnir
    Sleipnir Still havent found that stupid snipe
    I'm a horse
    Asgard
    Furd Rangero Ecoboost
    Think you can properly drain a turbo like this?
    1F3A3AC3-C655-46CF-AF5C-0C04CB7B2B33.jpg 3D914DAE-9667-46D7-BB32-0D772F3D15F5.jpg
    MadTaco461 likes this.
  2. Mar 20, 2021 at 5:49 PM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    Should work. What’s the smallestID on that? I’m using a 3/4” hose on billet barbs so it’s maybe 16mm in the fittings. Holset calls for 19mm but I haven’t had any blue smoke issues. Using the OPR, too.
    Sleipnir[QUOTED] likes this.
  3. Mar 20, 2021 at 5:55 PM
    Sleipnir
    I'm a horse
    Asgard
    Smallest size is probably 1/2”, the lines are vibrant -10 ptfe lines. I have had bellows of white smoke and running out of ideas. Using an OPR, getting 40 psi max, pressure washed the exhaust and I still smoke. The drain lines are the only thing I can think of that are the issue now.
  4. Mar 20, 2021 at 5:56 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Could you run a reducer or smaller reducer so there would be a little less oil in the turbo that needed to be evacuated?
  5. Mar 20, 2021 at 6:10 PM
    Sleipnir
    I'm a horse
    Asgard
    wouldn’t you want a large drain though?
  6. Mar 20, 2021 at 6:12 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    I think he meant the feed. Smaller diameter would be less flow for the same pressure, so you'd have a smaller volume for the drain to handle.
    yota243 likes this.
  7. Mar 20, 2021 at 6:12 PM
    yota243
    E.J.
    north Alabama
    Well of course, but if you can't drain enough out, it would be only logical to put less in... I mean unless you under oil your turbo.
    I see how i may have been unclear... Yes like @buyobuyo clarified, reducer in the oil feed line
  8. Mar 20, 2021 at 6:19 PM
    Sleipnir
    I'm a horse
    Asgard
    Gotcha. The feeds are -6 and recommended from what BorgWarner says. I have oil restrictors built into the efr so I don’t think that’s the issue. I think the drain isn’t dumping properly because of the elbow and it’s backing into the turbos on that small ass 1/2” 90
    yota243[QUOTED] likes this.
  9. Mar 20, 2021 at 6:29 PM
    Brake Weight
    White would be coolant. Are they water cooled? If not.....
    Sleipnir likes this.
  10. Mar 20, 2021 at 6:34 PM
    Sleipnir
    I'm a horse
    Asgard
    They are water and oil cooled and the smoke stinks of burnt oil
    Torspd likes this.
  11. Mar 20, 2021 at 7:06 PM
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    The 90 probably isn't helping. A 45 would drain better if theirs room for it. What thread is the bolt-on drain that you adapted to AN?
  12. Mar 20, 2021 at 7:10 PM
    Sleipnir
    I'm a horse
    Asgard
  13. Mar 20, 2021 at 7:26 PM
    Sleipnir
    I'm a horse
    Asgard
    The more I look at this the more I think the drain fittings are jacked on the turbos. Just on a comparison here’s the drains again on the turbos
    [​IMG][​IMG]
    the drains are covered in oil. Meaning they’re not draining into the block and back into the turbos. I say this because here’s the block side
    [​IMG][​IMG]
    the drains on the block are not covered in oil so this goes back to my theory the fittings on the drain are jacked. I ordered new vibrant fitting that are straight and will be here Tuesday.
    MadTaco461 and Brake Weight like this.
  14. Mar 20, 2021 at 7:26 PM
    Brake Weight
    3/8” is only 9.5mm. Gonna need a bigger drain.
    Torspd and Sleipnir like this.
  15. Mar 20, 2021 at 7:28 PM
    Sleipnir
    I'm a horse
    Asgard
    Oh trust me I know. I have new fittings coming Tuesday. The current fitting were installed by a shop :jerkoff:
    Torspd likes this.
  16. Mar 20, 2021 at 7:33 PM
    Brake Weight
    I ordered 4 turbo side drain flanges before settling on one. 3 threaded nipples later I used a thin wall billet one. Then the block side I used the previous flange and cut it out to match the OD of the thin wall billet and had it welded onto it. Then ordered more thinking I’d have the room for them but after having the 1” nipples welded to 3/4” threaded bungs realized it was too big to fit. Been rocking the smaller drain thus far with no issues yet. Most turbos just need an oil bath versus crank bearings or the like that are under pressure. You’re flow in is optimum therefore the flow out is not. You’ll get it sorted. Mine looks like a long sweeping conduit elbow.
  17. Mar 21, 2021 at 7:46 AM
    Sleipnir
    I'm a horse
    Asgard
    buyobuyo likes this.
  18. Mar 21, 2021 at 8:42 AM
    Sleipnir
    I'm a horse
    Asgard
    buyobuyo and Reh5108 like this.
  19. Mar 21, 2021 at 8:54 AM
    Sleipnir
    I'm a horse
    Asgard
    Per BW install instructions. That 90* bend ain’t doing me no favors
    Jon64l likes this.
  20. Mar 21, 2021 at 9:52 AM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    Here is my drain. Had to make it a short hard line, soft line and fittings would have been too close and more difficult to work on.
    Screenshot_20210321-094945_Gallery.jpg Screenshot_20210321-095000_Gallery.jpg Screenshot_20210321-095007_Gallery.jpg
