Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Apr 22, 2021 at 7:06 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    At least they were smart with the v band.
  2. Apr 22, 2021 at 11:03 PM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    I went through that same class and degree completion on a '20 fiat 124 spyder abarth. Same deal with the dump pipe too, for a 1.3 liter they gave it a massive exhaust.
    Speedytech7[QUOTED] likes this.
  3. Apr 23, 2021 at 5:08 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That's impressive actually. Just watched a YouTube video yesterday of James Clay racing his F80 around VIR. I imagine that little car feels like a luxury go kart. :D
  4. Apr 23, 2021 at 5:09 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Or is it? Muwhahahahah
    MadTaco461[QUOTED] likes this.
  5. Apr 23, 2021 at 5:10 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That's worse than my E36. I thought evolution was supposted to make things better.....
  6. Apr 23, 2021 at 5:12 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    This must be the pinnacle of that evolution. Lol
  7. Apr 23, 2021 at 6:58 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Working on my Tacoma and my Land Cruiser both give me peace. Everything has at least and ounce of thought put into servicing it. The N55 in this 135i, well it doesn't haha. But I kinda get it too. It's really 15lbs of shit in a 5lb bag. It's got dual variable valve timing, variable intake valve lift (it uses this instead of a throttle body), direct injection, coil on plug, the whole damn turbo system, variable rate/pressure oil pump... It makes at least a little sense why it is so tightly packed, but I do wish there was more thought put into serviceability.
    The turbo charging system is kinda nutso, the turbo recirc (which is used to also control boost ramp) is like a BorgWarner EFR turbo where it's mounted right on the compressor housing and because the engine makes no vacuum (no throttle body) the pneumatic wastegate defaults to open and the solenoid feeding from the vacuum pump's tank closes it to spool. Both sides of the turbocharger can be controlled in the event of a failure of some sort.
    The whole thing is delightfully over complicated, but I have to say it makes for a sensational driving experience. The "throttle" response is instantaneous and the thing spools up beyond 15psi in the blink of an eye. It's got so many damn things to mess with I feel like a fish out of water messing with the tunes. You have to be some sort of genius to figure out how to dial in the variable valve timing, turbo ramp (recirc and wastegate), timing, and valve lift requirements. I have much more ability when it comes to tuning the DCT trans, less to keep in mind :/
    The E36 if it has the M50 is way easier to work on, I like working on those. They're little ticking bastards that never die as long as you keep that waterpump happy.
    MadTaco461 and 05Taco4x4 like this.
  8. Apr 23, 2021 at 7:00 AM
    Speedytech7
    Pretty much what it is, mine doesn't have any screens or infotainment thankfully.
    Torspd[QUOTED] likes this.
  9. Apr 23, 2021 at 7:10 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I just learned a lot of things. Wow.
    M52. ;) Too bad not the S... Maybe some internal swaps in the future.
  10. Apr 23, 2021 at 8:53 AM
    TacoBike
    TacoBike The Researcher
    Mason
    Shingle Springs, California
    2000 3.4 Ext Cab TRD 4x4 with original SC
    ARP head studs Supercharger FIC6 AFR gauge painted fenders audio install
    Its too early to be hurting my brain like this.
    Good explanation though
    Speedytech7[QUOTED] and Sleipnir like this.
  11. Apr 23, 2021 at 9:25 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Some more parts on order for the turbo project truck. Very likely a new Holset replacement. Well get that sorted, but in the meantime had to fix the power problem with the garage and house. Wanted to spend Wednesday and Thursday working on the truck. Couldn't.
    Ended up being a outlet that had the push in connections, rather than screw down. They were from the 80's. Had a poor connection on the neutral, for where it jumped to other connections. Replaced with new.
    Need to fix my wiring for the lighting in the garage, then time to make some progress on the weekend. I want to see how this thing feels.
    Also, the owner is getting the DMZ engine mount gusset kit, and going to fix the other highly troubled areas.
    Hawk373, Sleipnir, MadTaco461 and 2 others like this.
  12. Apr 23, 2021 at 10:50 AM
    Rldanie
    Rldanie Punisher78
    Colorado
    2002 Supercharged, 2” pulley, FIC, Methanol, Transgo Shift Kit
    Engine Performance upgrades: Supercharged (Magnuson) FIC/6 Champion Radiator Toyota Corolla thermostat 168° JBA Headers JBA cat back exhaust Upgraded fuel pump Volant Cold Air Intake With custom plexiglass cover TransGo Transmission A340F Valve Body upgrade B&M Transmission cooler Methanol Injection 2 inch pulley Future Plans Supra Injectors Light weight crankshaft pulley Leather seats Off-road upgrades 3” rough country lift 33x12.5” Dick Cepeks Other upgrades: JL Audio 12W6 Sub in custom box JL Audio C5 Mids and tweets all the way around Sound dampened whole cab Transmission temp sensor Gen Tex rear view mirror (temp and compass) Blue instrument panel, a/c control panel lights, shifter, ashtray, glove box. Blacked out badges Blackout bumpers and grill MariMoto Projectors with demon eyes LED Taillights Second generation leather steering wheel with audio controls Custom leather wrapped automatic transmission shifter 3rd gen 4 Runner key ring light (blue) 3rd gen 4 Runner hood scoop
    What’s the max PSI y’all are running on the 3.4 with stock internal?
    If you’ve had to replace your motor please keep scrolling
  13. Apr 23, 2021 at 10:55 AM
    Speedytech7
    You won't break it with the baby supercharger haha, well as long as your fueling and timing are fine. It becomes thermally inefficient long before you hit the max safe boost for a 5VZ
  14. Apr 23, 2021 at 11:15 AM
    TacoBike
    Mason
    Yes, but for those of us who are planning ahead for 400whp...
    Max I have heard of was around 18psi, but thats like the absolute limit. 15 is probably safe?
    Rldanie likes this.
  15. Apr 23, 2021 at 11:18 AM
    Speedytech7
    Should probably plan for a built 5VZ then haha, 400WHP on one of those is gonna be damn near 460 at the crank and the 5VZ isn't robust enough to sustain that on its stock internals and even afterward it might be pushing it with the weak main girdle setup
  16. Apr 23, 2021 at 11:22 AM
    TacoBike
    Mason
    Oh yeah. But the real problem are the rod bolts breaking. Thats what actually gives out first. Problem is that you have to completely do new rods and cant just add nice rod bolts
    (470 by my calcs) ive heard of 430-450 whp is consistent give out point
  17. Apr 23, 2021 at 5:13 PM
    BananaMan
    @Brake Weight here's the info tag off the TD04C62BE2E2-BC94-41AE-9AA1-3D028927E407.jpg
    edit: feck... sideways. Let me know if you need me to rotate that and resend it.
    Brake Weight and Sleipnir like this.
  18. Apr 23, 2021 at 5:55 PM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    That’s good. I can rotate it.
    Sleipnir and BananaMan[QUOTED] like this.
  19. Apr 23, 2021 at 6:15 PM
    BananaMan
    Wouldn't that be clocking it since it's a turbo? :D :rofl:
  20. Apr 23, 2021 at 6:31 PM
    Sleipnir
    Sleipnir Still havent found that stupid snipe
    I'm a horse
    Asgard
    Furd Rangero Ecoboost
