Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. May 22, 2021 at 6:23 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
  2. May 22, 2021 at 6:25 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Reading the thread I snipped, Matt was saying some of those sensors are better than others- I'm curious how good the 2TR one is. If I ever get this thing tuned I'll asked the tuner, maybe have this^ standing by in the glove box haha
    MadTaco461[QUOTED] likes this.
  3. May 22, 2021 at 6:29 PM
    05Taco4x4
    2TR-FE Enthusiast
    So you guys don't think I'm a slacker, I've got about 3K in brick work I need done and I've made my mind up I want a patio that's going to cost me about 4K so my Taco budget is almost non-existent at this point. What I do have is everything I need to swap over to a auto trans but the tuner told me it's easier to tune with a manual and I'll get a better tune with my manual so I'm waiting to swap after the tune.
    Torspd likes this.
  4. May 22, 2021 at 9:36 PM
    MadTaco461
    CA
    Kinda stock
    I bet yours is fine unless you are getting false knock.
    Oh man brick work. Ouch that’s painful. Yeah I’m used to the taco taking the backseat. At least it’s not on jackstands.
  5. May 23, 2021 at 4:36 AM
    05Taco4x4
    2TR-FE Enthusiast
    The lintels used back in 1948 were not galvanized so they swell and lifted the entire body of bricks above the windows in the back, they're all over the place and the mortar is jacked; to make it worst someone johnny patched the mortar with caulk and it looks horrible. I'm going to have them remove the old bricks, install new lintels and replace the bricks. If anyone is looking for steady work become a brick mason, they stay busy and they make good money. I do 95% of my own work but I'm not trying this one.
    Torspd, MadTaco461 and BananaMan like this.
  6. May 23, 2021 at 11:48 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    This is a true statement. You can hold rpm and load way easier than with an auto.
  7. May 25, 2021 at 12:27 PM
    MadTaco461
    CA
    Kinda stock
    So how painful it is to fill flow data for a Denso injector? I have some 540cc injectors right now. Can't find any good data on them.
    Denso 23250-74200. They run awesome on my piggyback. Am I better off jumping to some injector dynamics from the start?
    Sleipnir likes this.
  8. May 25, 2021 at 5:26 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    What did those come out of?
  9. May 25, 2021 at 6:16 PM
    MadTaco461
    CA
    Kinda stock
    Some type of turbo Toyota from Japan. I think found them on eBay years ago by just doing a Google search. They had a 2rz performance tag.
    It's pretty much the same injector as stock but just higher flowing. Worked great for tuning a piggyback but not sure if it translates over to a standalone
  10. May 25, 2021 at 8:55 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You'd have to try to find dead times (dwell times), to enter for the voltage scaling. There might be a similar vehicle in the Haltech Toyota list, which has those injectors, or something near. Not sure what the OEM size Supra injectors were. Maybe a Soarer, or IS350?
    That would get you round -about close.
    MadTaco461 likes this.
  11. May 25, 2021 at 9:55 PM
    MadTaco461
    CA
    Kinda stock
    It does seem I can test out different values and run some testing too. I'll run them and see how it works. I'll look for some maps too. I have time
    Torspd[QUOTED] likes this.
  12. May 26, 2021 at 4:11 AM
    05Taco4x4
    2TR-FE Enthusiast
    You can send injectors off for this stuff?
  13. May 26, 2021 at 7:22 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    May also be able to get the data from emailing an engineer from Denso Aftermarket.
    MadTaco461 and Sleipnir like this.
  14. May 26, 2021 at 8:33 AM
    MadTaco461
    CA
    Kinda stock
    It's an engineering test. Labor intensive, but you can test it while on the truck.
    Thanks sent denso an email. Only scary thing is that part# doesn't pop up on their site. Might be a Toyota #.
    Torspd[QUOTED] and Sleipnir like this.
  15. May 26, 2021 at 9:26 AM
    MadTaco461
    CA
    Kinda stock
    Denso already got back to me. They said they quit making fuel injectors a few years ago. So no more injector data. You can really only find these injectors in China now. No wonder why the price has gone down so much on these. Off to the next issue.
    Here is how to do it from scratch on a Haltech trial and error. It's really just so that my VE table doesn't get tweaked too much from what it should be at.
    https://forums.haltech.com/viewtopic.php?t=9748
    05Taco4x4 and Torspd like this.
  16. May 26, 2021 at 11:02 AM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    So you know how you guys were talking about oil pressure. I have a sensor on my 1uz and on a cold start it pegs at 100 psi. After it warms up it drops to 25 psi idle and back up to 100 when driving lol. Apparently this is normal for them too. I can only image what a turbo would do at 100 psi
    BananaMan likes this.
  17. May 26, 2021 at 11:25 AM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    Kaboom! Oil pressure regulators would definitely be needed in that situation.
  18. May 26, 2021 at 11:29 AM
    5 Lug Fury
    Kenny
    Knoxville, TN
    Good thing if whenever I go boost I'll just slap an m90 on top lol.
    Sleipnir and BananaMan[QUOTED] like this.
  19. May 26, 2021 at 11:39 AM
    BananaMan
    Boost is boost. We like it!
  20. May 26, 2021 at 11:56 AM
    Sleipnir
    Sleipnir Still havent found that stupid snipe
    I'm a horse
    Asgard
    Furd Rangero Ecoboost
    Turbosmart makes a fantastic OPR that I highly recommend :thumbsup:
    Brake Weight likes this.
