Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Jul 16, 2021 at 9:18 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    All I hear about them is how unreliable they are.
    My gf's dad has a works edition mini. Sounds bitchin. Looks pretty cool too
    Brake Weight likes this.
  2. Jul 17, 2021 at 6:12 AM
    Pinchaser
    Pinchaser Flipper Crazy
    Alan
    2020 Tacoma ECU 04B82 AT
    I am fishing for information, from people with turbo experience, so posting here.
    I live in the hills of upstate NY, and the VFTuner Turbo Kit that I am waiting for, I believe includes wrapping the manifold, turbo and down-pipe. Concern is that with our high humidity all summer, and salted roads with humidity all winter; Insulating wrap may dramatically reduce the life of the pipes. I think they are all 304, which helps, but 304 does rust, this is why 319 is preferred for hardware near an ocean. I tend to keep my vehicles for 10+years.
    Makes me wonder if I should plan on taking the time to make metal heat shields for all this, instead of wrapping? Though I do not think shields will be as effective at keeping the heat in the pipes.
    Anyone have thoughts or experience with wrapping pipes in these climates?
    What do car manufacturers do on turbo cars?
  3. Jul 17, 2021 at 6:14 AM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    A really popular and effective option would be having the pipes cerakoted, which will act as an insulator and rust preventative in one.
    Reh5108, MadTaco461, Torspd and 2 others like this.
  4. Jul 17, 2021 at 6:44 AM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    Cerakote and there is some ceramic type that bakes on like powder coat that is supposed to be good, too.
    BananaMan likes this.
  5. Jul 17, 2021 at 8:43 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I agree with these guys. Ceramic coating would be coating would be the best vet. Then you. Then you could also rap it for additional for additional thermal insulation.
  6. Jul 17, 2021 at 10:56 AM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    +1 for what the other guys said about ceramic coating.
    Also, heat shields won't do anything for keeping heat in the pipes. Heat shields keep heat off other things.
  7. Jul 17, 2021 at 1:15 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    No tubo 2tr swapped mini?
  8. Jul 18, 2021 at 6:04 AM
    Pinchaser
    Alan
    Thank you all @BananaMan @Brake Weight @Torspd and @buyobuyo Reading up on Cerocote and Swaintech. The Swaintech is thicker, and probably the way to go if I decide not to wrap it, though only available in white and is more expensive.
    Mat at OVTune, confirmed that the header and down-pipe are both 304ss, so that helps. He also said he did not think rust will be an issue, but he does not recommend wrapping the header (for lack of room) or the down-pipe. Unclear if not wrapping down-pipe is due to my climate or universally.
    I will seriously consider Swaintech for the Manifold, and turbo, maybe the down-pipe too, and then add heat shields to help protect surroundings. Looking at other sites, it seems wrap use in my climate is a serious corrosion problem. The problems found do not address 304ss, but seems better safe than sorry, when underwater, I've seen 304 start rusting in only a few weeks. Under-hood heat can be mitigated in other ways, or add wrap later.
    BTW @buyobuyo, liking your motto; I say similar, regularly.
    Thanks all!
    BananaMan and buyobuyo like this.
  9. Jul 18, 2021 at 7:06 AM
    Sleipnir
    Sleipnir Still havent found that stupid snipe
    I'm a horse
    Asgard
    Furd Rangero Ecoboost
    You alright Tor? Not having a stroke are you?
    Torspd[QUOTED] and BananaMan like this.
  10. Jul 18, 2021 at 8:30 AM
    yota243
    E.J.
    north Alabama
    Rap is right cuz he already got the "W"
    Torspd and Sleipnir[QUOTED] like this.
  11. Jul 18, 2021 at 10:09 AM
    Bloodytaco208
    Bloodytaco208 Well-Known Member
    Twisted steel sex appeal reg cab tacoma
    Bunch of built and bought mods
    Dont use header wrap. I wrapped my manifold and cause moisture to build up caused extreme corrosion. It didnt help that my timing was retarded extremely. Cerakote is a great option plus they have high temp colors.
  12. Jul 18, 2021 at 10:23 AM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    I didn't wrap my manifolds with the OVTune TT kit, but I did wrap the proximal parts of the downpipes because of their proximity to various cables and wires and was needing wire loom/circular heat shielding for so many spots that I needed to maximize use of material (and I'd bought quite a bit too).
  13. Jul 19, 2021 at 1:08 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Blasted talk to text. Grrr.
    Sleipnir[QUOTED] and BananaMan like this.
  14. Jul 19, 2021 at 1:21 PM
    dirtdigginjoe
    dirtdigginjoe Resident meth-head
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    It'll get ya every time!
  15. Jul 20, 2021 at 9:00 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  16. Jul 20, 2021 at 9:45 AM
    MadTaco461
    CA
    Kinda stock
    It does spool up fast. Nice
  17. Jul 20, 2021 at 11:24 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It really does. That is what I like about the video I captured of the owner driving. As he kept blipping the throttle. I could hear the response, but couldn't tell how it actually felt with regard to throttle input. You get to hear it though.
    Then when I drove, the dots were all connected. Throttle equalled diesel like spool response.
    What is really fascinating to me, is that there is no discerning difference between the exhaust only, and the vent to atmosphere wastegate dump tube. They blend together as if tied together.
  18. Jul 20, 2021 at 11:37 AM
    MadTaco461
    CA
    Kinda stock
    I thought I would hear that wastegate scream. It was pretty quiet. Makes me want to slide around in the dirt with my truck instead of being at work.
  19. Jul 20, 2021 at 11:46 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Heck yeah! It was brief, but sooo much fun!
    MadTaco461 likes this.
  20. Jul 20, 2021 at 1:36 PM
    BananaMan
    That's a whole lotta spool! I still don't like the sound of a v6, but it definitely sounds proper for a desert "hopper"
    Torspd likes this.
