Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Jul 25, 2021 at 8:56 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    In this scenario, is the MAF pre or post turbo/s?
    Also, the Tee going to air box will, before the check valve, unless at minimum a -8AN, will not be large enough a vent hose. It will also pull in vain from the air box, which would be unmetered. Unless that is placed post MAF. Without drawing it out, this is how it looks to work in my head.
    Overall. Your plan could be made to work with refinement. However it is unnecessarily overly complicated. If the MAF is pre turbo, then you'll still get film buildup on the turbo and intercooler, but much less than without a catch can.
    The method I proposed to pre-turbo, is far simpler, and easier to troubleshoot. No check valves needed. It is either under vacuum, or under super vacuum when the turbo spools. Which is actually quite beneficial, as it reduced the air acting as a resistance against the underside of the combustion side.
  2. Jul 25, 2021 at 10:23 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Hey everyone a young friend of the family ended up buying a sr20 swapped 240sx for too much and I am trying to help him sort out the issue of the engine rpms dropping when shifting almost to the point of dee stalling and stalling even sometimes. The issue is that I don’t have experience with this or other setups with turbos or their associated trouble shooting techniques. Here’s pics of his engine bay:
    41D91B36-A76B-4D7C-9AFC-21BECD8928C9.jpg D6C1E09E-8A2C-4747-B8DA-AD3E064874A8.jpg 6F437EAE-06AD-4946-AEAB-31278535BEE2.jpg
    He also saw a video that the owner of a SR20 swap was having the same or similar issue and fixed it by relocating the MAF. I don’t see his MAF in his pics so I’m not sure if the guy in the video is having the same problem.
    https://youtu.be/Y0h1Vl5upDQ
    Any advice is helpful. I can help him with anything short of welding aluminum.
    edit: I found that he has an aftermarket ecu with a map sensor.
  3. Jul 25, 2021 at 11:42 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I was about to say that it looks like there is a MAP sensor on there.
    The catch can is open on one port. The line tss's onto the valve cover. Where does the other part of that tee go?
  4. Jul 25, 2021 at 11:43 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I reaaaaally want to work on that. Looks like fun!
  5. Jul 25, 2021 at 2:43 PM
    DirtyHammmer
    DirtyHammmer Member
    Austin
    2009 Tacoma - 2.7L
    Does anyone know if the 2rz/3rz injectors fit and work with a 05-12 2TR-FE? Trying to find 850-1000cc injectors but the highest I've found is 750cc on Fiveomotorsports.
    Also curious if the fuel rails are compatible, or semi compatible with some fab
    BananaMan likes this.
  6. Jul 25, 2021 at 2:49 PM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    I seem to remember hearing about a 1075 cc or similar from somewhere, I can't recall where though now.
    DirtyHammmer[QUOTED] likes this.
  7. Jul 25, 2021 at 4:43 PM
    DirtyHammmer
    DirtyHammmer Member
    Austin
    2009 Tacoma - 2.7L
    Did some research and created an easy guide for anyone to calculate their fuel injector size for their builds, works for any vehicle but I haven't seen any of this info here and thought it would be useful
    How to choose the correct Fuel Injectors for your horsepower goals - Naturally aspirated and turbocharged/supercharged
    1lb/hr = 10.5cc/min
    .5lb/hr of fuel per 1 horsepower
    How much fuel do I need to make ____ horsepower?
    • Calculate flow rate for injectors at desired horsepower
      • Desired Horsepower ÷ Number of cylinders/injectors = Horsepower per cylinder
      • Horsepower per cylinder ÷ 2 = Flow Rate per Injector ( lb/hr )
      • Flow Rate per injector lb/hr × 10.5 = Flow Rate per Injector ( cc/min )
    • Example: 2.7L 2TR-FE 4 Cylinder engine, desired horsepower = 250HP
      • 250hp ÷ 4 cylinders = 62.5hp/cylinder
      • 62.5hp/cylinder ÷ 2 = 31.25lb/hr
      • 31.25lb/hr × 10.5 = 328.125cc/min
    “But.. But what about the turbo???”
    Forced induction creates pressure in the intake manifold. Adding cylinder pressure decreases fuel injector pressure, which requires more fuel pressure to maintain a proper a/f ratio, which is why it’s important to have the correct fuel pressure and injectors that are slightly oversized so they’re not working at their 100% flow.
    More air = more fuel
    • Flow Rate per Injector ÷ .80 will give you the correct size for your forced induction application
      • 328.125cc/min ÷ .80 = 410.16cc/min
      • Size up to a 450cc injector
      • Pshhhh noises with a happy truck
    Always size up if you can, better to have the flow and not need it than go lean
  8. Jul 25, 2021 at 4:53 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    You know you can just Google fuel injector calculator and get a billion websites that will do this for you, right?
    05Taco4x4, Brake Weight and Torspd like this.
  9. Jul 25, 2021 at 4:58 PM
    DirtyHammmer
    DirtyHammmer Member
    Austin
    2009 Tacoma - 2.7L
    I got a few different results from websites and wanted to learn it for myself and understand the process a little better.
    05Taco4x4 likes this.
  10. Jul 25, 2021 at 5:16 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Adding a boost line to the fuel pressure regulator will create a 1:1 increase in pressure as boost increases which will also compensate for the excess cylinder pressure, it already has a vacuum line ran to it from the factory so it sees vacuum when need be as well
    Torspd and DirtyHammmer like this.
  11. Jul 25, 2021 at 5:20 PM
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    You see different results depending on how simple or complex the calculator is. They'll all get you in the right ballpark, and they don't always make injectors that are exactly what the calculator spits out.
    It's good that you took the time to learn what the different numbers are. However, even your numbers are a generalization. BSFC (brake specific fuel consumption), that 0.5/0.8 number, varies based on engine, efficiency, etc. Fuel pressure also affects fuel injector size.
    Torspd and DirtyHammmer[QUOTED] like this.
  12. Jul 25, 2021 at 6:00 PM
    Pinchaser
    Pinchaser Flipper Crazy
    Alan
    2020 Tacoma ECU 04B82 AT
    Torspd, MAF is Pre-turbo, at airbox, so is only a slight vacuum.
    Tee to air-box has another ck-valve, sucked closed during intake vacuum, BUT under boost/higher crankcase pressure>> the manifold line ck-valve closes due to boost and the ck in to the air-box would then bleed off crankcase pressure, as well as the opposite valve cover vent reversing and venting to post MAF (Pre-turbo). Are two Ck-valves, but creates a fail safe so leaking ck valve cannot Boost-pressurize the crankcase.
    yes some film buildup opportunity at turbo, but none when intake has vacuum, and split duty when crankcase is pressurized. Unless oil passes thru both filters at airbox (uncertain, but suppose it might).
    This one you proposed? Filter>valve cover in>other valve cover out> catch can>hose or tube pre-turbo.
    The filter>valve cover in would need to be post MAF for metered air (or maybe eliminate any air inlet?). But also this means everything that gets past the Catch Can is consumed through the turbo/intercooler. Assuming that a sizable amount of driving is non-boost, the complexity might be worth utilizing manifold vacuum, when available. Although with a very Effective catch can; yours might be awesome. Will the seals of the crankcase hold up to Super Vacuum?
    Torspd[QUOTED] likes this.
  13. Jul 25, 2021 at 6:20 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    This one completely eliminate the ecu on how it was wired on my 99.
    Harness was 500 plus 60 per added sensor.
    I'll start hooking it up soon.
    DirtyHammmer[QUOTED] and Torspd like this.
  14. Jul 25, 2021 at 6:40 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  15. Jul 25, 2021 at 6:42 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That's how roots s/c systems work. ;)
    For our V6's, I recommend a -8AN hose. We can get away with -6AN, but once boost is pushing towards 15 psi+, -8AN is wanted.
  16. Jul 26, 2021 at 8:56 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    You might try giving injector dynamics a call. I think i remember someone with a 2TR-FE running some 1050cc’s a while back.
  17. Jul 27, 2021 at 1:01 AM
    DirtyHammmer
    DirtyHammmer Member
    Austin
    2009 Tacoma - 2.7L
    I'd love to see an update when you do :thumbsup:
  18. Jul 27, 2021 at 7:12 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    How do you plumb turbo coolant lines and actually take advantage of the thermal siphon effect. Using a T doesn't seem to be ideal as water will take the path of least resistance. And plumbing inline of something would leave both hoses either high or low.
    Coolant is only flowing through the heater core when the heat is on, correct?
  19. Jul 27, 2021 at 8:05 PM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    I used the throttle body coolant lines on my 5vz fwiw. @Reh5108
    Torspd and Reh5108 like this.
  20. Jul 28, 2021 at 4:10 AM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    It doesn’t have to be a solid stream of water to cool. I’ve seen equipment at my work that was water cooled overheat. We put a ball valve on the discharge side and pinched it off some and no more overheating. Seems counterintuitive but it redneck worked just slowing down the flow. Some turbos don’t even have a water line and are strictly oil lubed and cooled.
    Never even thought of this. Good idea.
    Jon64l[QUOTED] likes this.
