Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Jun 10, 2017 at 1:25 PM
    #1461
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    @boostedka Have you done anything to the inside of your engine or ARP studs ?
  2. Jun 10, 2017 at 1:57 PM
    #1462
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Motor is stock with just under 180k. I've just replaced the clutch and did a new rear main seal at the same time since I had it opened up.
  3. Jun 10, 2017 at 2:33 PM
    #1463
    Jstand
    Irving,Tx
    And your running 10 psi boost makes me want to push a little more when I get the injector in which just came in today thx :)
    MadTaco461 likes this.
  4. Jun 10, 2017 at 2:37 PM
    #1464
    boostedka
    James
    NM
    I was running about 8.5psi with them. That's probably close to the max with a stock Ecu.
    Glad to see they got there so quickly!
    Jstand[QUOTED] likes this.
  5. Jun 10, 2017 at 6:41 PM
    #1465
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I might be the only 4 banger with arp studs cuz I had to pull my head. Never popped it when I ran 8 psi.
    As long as you don't start knocking should be good on stock gasket for a while.
    Lord Helmet and boostedka like this.
  6. Jun 10, 2017 at 6:49 PM
    #1466
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    i'll be #teamARP too
    eventually :spy:
  7. Jun 10, 2017 at 8:32 PM
    #1467
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    My car has arp studs with stock gasket on 8 psi. No issues :notsure: But then again it revs to 8500 rpm :D
    Torspd and MadTaco461[QUOTED] like this.
  8. Jun 10, 2017 at 8:39 PM
    #1468
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    ARP on 4 of my engines. Three 1GRs, and one M52.
  9. Jun 10, 2017 at 9:25 PM
    #1469
    MadTaco461
    CA
    Kinda stock
    There is a huge difference between those stockers and arp.
    Lord Helmet likes this.
  10. Jun 11, 2017 at 8:13 AM
    #1470
    boostedka
    James
    NM
    Has anyone ever pulled the valve cover off and just replaced the stock head bolts with ARP studs? Just torqued them down using the stock gasket left in place?
  11. Jun 11, 2017 at 10:23 AM
    #1471
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If you can get to them without interference from the valve train, then just do one at time. Although, that wouldn't be the preferred method, since it will unevenly unload the head. Still do-able though. Safer on your RZ blocks since they are iron.
    Draining some coolant, evenly untorquing the factory bolts, but retaining a few around 20 ft-lbs on each would be best. Then replace one at a time, in sequence and torque back to the first torque step. Until all are replaced.
    This way, by keeping some tension on the OEM bolts, you'll prevent fluids from getting between the mating surfaces of the gasket, ruining its seal.
    Then follow up by torquing the rest in sequence, in steps.
    Best also to put the studs in a bag a boil them. That will allow them to have some heat expansion. Next, after the maximum torque of ~75 ft-lbs is reached, let them sit for a few hours or even a day. Come back a retorque to max again. Due to condtructional stretch.
    Lord Helmet, Brice and boostedka like this.
  12. Jun 11, 2017 at 10:52 AM
    #1472
    MadTaco461
    CA
    Kinda stock
    Gotta pull the cams to get to the studs on an rz motor. I'd wait til you want to do head work or the gasket begins to fail.
    Lord Helmet, Torspd and boostedka like this.
  13. Jun 11, 2017 at 11:06 AM
    #1473
    boostedka
    James
    NM
    Thanks for the feedback on that guys. Seems crazy you can't access the head bolts with the cams in. Aren't you supposed to re-torque after a certain amount of miles when install ARP studs? IIRC i did that on my 240sx i built back in the day
  14. Jun 11, 2017 at 12:10 PM
    #1474
    MadTaco461
    CA
    Kinda stock
    It didn't say anything about a retorque. That would be a good chunk of time if you had to do that. I just clean my threads out with a tap because the oem head bolts are kinda dirty when you pull them. It crazy you can feel the head and cams flex when you install them.
    boostedka likes this.
  15. Jun 11, 2017 at 12:58 PM
    #1475
    boostedka
    James
    NM
    I was just getting ideas but sounds it'll just be way down the road when it's time for a full rebuild or if the HG goes
  16. Jun 11, 2017 at 5:01 PM
    #1476
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Kinda too funny not to share
  17. Jun 11, 2017 at 6:14 PM
    #1477
    MrCrowntown
    Alyn
    Ky
  18. Jun 11, 2017 at 7:01 PM
    #1478
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Just about to watch it!
    MrCrowntown likes this.
  19. Jun 12, 2017 at 11:19 AM
    #1479
    yota243
    E.J.
    north Alabama
    wish I could of finished mine in 35 mins... HOLY FREAKIN CRAP
  20. Jun 12, 2017 at 11:25 AM
    #1480
    MadTaco461
    CA
    Kinda stock
    Those barra motors are cool. That thing looks like it could of made 800hp and still not phase that engine. Huge engine in that little car.
