Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Sep 28, 2021 at 2:39 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Try some wd40. I haven't had issues stretching couplers. I had the issue of them being too loose. 80mm coupler sounds like a good solution.
    Hawk373[QUOTED] likes this.
  2. Sep 28, 2021 at 2:42 PM
    MadTaco461
    CA
    Kinda stock
    No video from my trip. I wasn't going fast enough to film anything exciting. Barely got above 50mph.
  3. Sep 29, 2021 at 6:06 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    There are 3.25" couplers. They don't come cheap though. HPS silicone couplers makes them. Quickest to my mind. There are others as well.
    Hawk373 and MadTaco461[QUOTED] like this.
  4. Sep 29, 2021 at 6:11 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Just imagining all of the on/off throttle fun, is exciting.
    MadTaco461[QUOTED] likes this.
  5. Sep 29, 2021 at 6:12 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Got a picture of that?
  6. Sep 29, 2021 at 6:15 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Any of you 2TR guys with turbos have a picture of where and how you did your oil drain?
  7. Sep 29, 2021 at 8:59 AM
    dirtdigginjoe
    dirtdigginjoe Resident meth-head
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    Circled in red is where I tapped the upper oil pan
    You can see it running down between the manifold, around the oil filter
    And into the part on the pan I tapped. I used a screw-in bung, that has a lock on the backside that gets staked...Didn't have access to a TIG, but have zero issues with leaks
    Hawk373, Taco47, 05Taco4x4 and 5 others like this.
  8. Sep 29, 2021 at 1:41 PM
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
  9. Sep 29, 2021 at 1:43 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Can't nail down a good size set of twins for the 454, really hard to find what I need with T3 base.
    BananaMan likes this.
  10. Sep 29, 2021 at 1:51 PM
    dirtdigginjoe
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    I'm too lazy to go back through old pages, but are you referring to a 454ci engine? And trying to mate up T3 turbos to a motor that big??
    Shit, even 5.3 and 6.0 LS motors want T6's!
  11. Sep 29, 2021 at 1:56 PM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    I was going to say T3's would be way too small I'd think. 454's are massive
    dirtdigginjoe likes this.
  12. Sep 29, 2021 at 2:01 PM
    Speedytech7
    She's gonna be a low boost low revving old bird, well not old, it's all new and I've hand ported the heads to their limit... but I'm not chasing horsepower to the ends of the earth or anything.
    I've got two NOS cast manifolds for T3 turbos. Thinking 61/62 Garrett twins
  13. Sep 29, 2021 at 2:17 PM
    dirtdigginjoe
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
  14. Sep 29, 2021 at 2:20 PM
    Speedytech7
    I could see that if it were a single, even a single HX40 is wayy too small. But twin 61/62 with .82 AR turbine housings is too small ya think?
  15. Sep 29, 2021 at 4:25 PM
    MadTaco461
    CA
    Kinda stock
    Maybe go for a 1.06 exhaust housing to keep that backpressure down if you going for a gt3582
    Torspd and Speedytech7[QUOTED] like this.
  16. Sep 29, 2021 at 4:51 PM
    Speedytech7
    I'll browsed AGP turbo later and see if I can find a housing when their site is working
  17. Sep 29, 2021 at 5:34 PM
    MadTaco461
    CA
    Kinda stock
    But you could probably run a .82 just fine. 3.4 tacomas typically run gt3582's with a .70 hot side. Half your motor is 3.7
  18. Sep 29, 2021 at 6:55 PM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    I had the .82 on the 3.4 w/35r, moving to the 1.03. Shooting from the hip, for a 3.7 (x2), I would do the same. Maybe look at other people's results?
    The new G35-1050 has a new 1.21 hot side available now. Could even mirror the turbos.
    3.4 pron w/1.03.
    .02 cents fwiw
    Torspd and MadTaco461 like this.
  19. Sep 29, 2021 at 7:01 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    So it's settled that the next I4 Toyota puts in the Tacoma will be a 3.7 because math and why not? #torque4dayz
    Torspd likes this.
  20. Sep 29, 2021 at 7:10 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    I have since replaced that upper oil pan with welded in bungs, was getting leaks with these. The second one is for the AOS-R
