Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Jun 25, 2022 at 7:26 AM
    Pinchaser
    Pinchaser Flipper Crazy
    Alan
    2020 Tacoma ECU 04B82 AT
    I don't know? when the fans are running, the flaps would be sucked closed. So at speed, for flaps to help, would mean the fans are not running, or they are, but do not move enough air. can u tell if the fan is on while you experience this?
    Try, sealing gaps between shroud and radiator on all sides, make sure every bit of air moved by fan, can only have arrived after passing thru the radiator (none from around it).
    Seer if you can remove any obstruction from in front of the radiator.
    I had a van with a 350 once, solved slight overheating by removing every-other tube from the custom grille. This made a huge difference when towing.
  2. Jun 25, 2022 at 9:07 AM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Yeah that's what I think my next move is. I'll add a flap where I can but I'm also just going to drill out some areas to help.
    My fans are always on and from what I understand the flaps stay closed at low speeds and open allowing the air to bypass the fans at high speed.
    Torspd[QUOTED] likes this.
  3. Jun 25, 2022 at 12:47 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Wind speed while driving will easily push the flaps open. A speed related control would be required if the fans were desired to be off while driving over a certain speed.
  4. Jun 25, 2022 at 12:48 PM
    Pinchaser
    Alan
    If the electric fan is adequate as slow traffic speeds, then it is certainly adequate at cruising speeds (though possibly not at WOT excessive speeds). I think it is something else.
    Any open holes in the fan guard (without flaps) will dramatically reduce the effectiveness of your fans during low speeds. The holes will allow engine compartment air to re-circulate to the front of the fan; the flaps are a check valve to prevent this re- circulation. The fans move a specific amount of air (varying with induced pressure of vehicle speed), but the fan itself has a fixed capacity for moving air, at any given speed; open holes in the shroud simply means that at low speeds, some of that air capacity will be drawn from the engine compartment (re-circulated), without the benefit of going through the radiator to absorb heat from the coolant!
    The flaps simply open if the pressure on the front side is greater than the pressure on the back side. With the fans running, this is highly unlikely. The Free Air (from forward motion) would need to be pushing more air than the fan will ALLOW; in order for the flaps to open, (fan will ramp up with increase in vehicle speed, as it performs less work; so air thru fan will increase with vehicle speed). The flaps are utilized with a temperature controlled fan, because while the fan is off, it is an obstacle to air flow, reducing available Free-air cooling. The flaps allow venting past the fan, to enable increased free air.
    I'm just not sure this is your problem. What are you using for antifreeze coolant ratio; more concentrated than 50/50? Has the system ever leaked where radiator leak-seal was added? Are there any kinked hoses. Do you have big lights or a light bar added within or in-front-of the grille, that may cause unusual turbulence, that could reduce air through the grill at higher speeds?
  5. Jun 25, 2022 at 12:55 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    No flaps, no radiator fan shroud, tightly packed engine bay. Damn good fan.
    MadTaco461 likes this.
  6. Jun 25, 2022 at 1:01 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  7. Jun 25, 2022 at 1:48 PM
    Pinchaser
    Alan
    WOW, that should do well!
  8. Jun 28, 2022 at 11:18 AM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    Stumbled across this and is a new one for me but old tech. Quick search here didn’t show anything about these particular ones. They are/were actually Toyota OEM on mostly non American soil it looks like.
    Quick search shows this one as the most common and rated just below an Eaton m90 by only a few CC. Apparently doesn’t build a lot of boost, per one website, but is more about the flow rate. ‘A lot of boost’ would be a relative number honestly. This would explain the wide range of displacement it covers. It has an electromagnet in the pulley so an on/off switch or other trigger can be utilized. Conventional and/or smaller pulleys are out there. Would need a mounting bracket and a longer belt but the plumbing should be an easy one. Power wise I’d say it would be on par with the more expensive SCs out there but needs some fab skills to pull off.
    https://itstillruns.com/supercharger-sc14-specifications-8083848.html
    https://www.amazon.com/Supercharger...=&hvlocphy=9026906&hvtargid=pla-1641953266079
    MadTaco461, Torspd and Jon64l like this.
  9. Jun 28, 2022 at 11:31 AM
    PhoS
    PhoS Proffauxssional
    PNW
    08 FJ Cruiser
    Contains MSG
    Reminds me of the SC12/14 on the 4agze.
  10. Jun 28, 2022 at 12:14 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Reminds me of the early Mad Max s/c cars. That had the flip switch boost. @Lucario Runner
  11. Jun 28, 2022 at 1:10 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Also reference Nissan super turbo.
    Speedytech7 likes this.
  12. Jun 28, 2022 at 1:12 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
  13. Jun 28, 2022 at 2:26 PM
    PhoS
    PNW
    08 FJ Cruiser
    Contains MSG
    So if I add two that's good for a 7 liter right?
  14. Jun 28, 2022 at 3:53 PM
    Brake Weight
    This is that one I believe. There’s a bigger variant, sc20, some are running on the 1uz. SC14=TX15. Just found it oddly interesting.
  15. Jun 28, 2022 at 5:11 PM
    Brake Weight
    So it begins.
    Ruh roh. Baby snail has some cracks developing. Time for the bigger one to go on.
  16. Jun 28, 2022 at 5:23 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    What engine is that? Not familiar with a longitudinal awd i4
  17. Jun 28, 2022 at 6:00 PM
    Brake Weight
    From my 2003 Audi A4B6. I’ve got all the parts ratholed for a BT. Now I just need the funds to tune it. Barring the delivery of the crank main bolts in a day or two, I’m hoping to have fresh crank bearings, fresh rod bearings, forged rods, Wiseco pistons done tomorrow. Front and rear main seals as well.
    Thursday I’m shooting for stainless exhaust valves, all new valve seals, new clutch and SMFW. Going to tap all m8 turbo mani bolt holes to 3/8-16 and I have a sack of 3/8 allen head bolts for it. May drill holes in the allen heads and run some stainless tie wire through them to be safe. I forgot to pick up some m10 bolts for the t3 flange but will get them soon. Those will get Nord-loc washers.
    Getting excited about her again.
    Torspd and MadTaco461[QUOTED] like this.
  18. Jun 28, 2022 at 6:47 PM
    MadTaco461
    CA
    Kinda stock
    Wild, had no idea quattros were longitudinal. Never really looked at them. That's a lot of motor up front.
  19. Jun 28, 2022 at 7:12 PM
    Brake Weight
    Begs for an LS swap.
    MadTaco461[QUOTED] likes this.
  20. Jun 29, 2022 at 6:05 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Transmission reminds me of the Subi one. Which then makes me think of these both in their rally heritage.
