Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Aug 30, 2022 at 4:48 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    05Taco4x4 and MadTaco461 like this.
  2. Aug 30, 2022 at 5:12 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Shoot I should pull off my AC belt in the winter. 2rz life. My mechanical fan eats a ton of my power, but I don't want the efan life again.
    Glad that belt is working out so well.
  3. Aug 30, 2022 at 5:19 PM
    Boomtacoma01
    Boomtacoma01 Well-Known Member
    Houston
    i appreciate it. I just got home and was going to measure the one on my other truck. Nothing like having 2 project’s ongoing at the same time
    Brake Weight[QUOTED] likes this.
  4. Aug 30, 2022 at 5:33 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That's one way to extend the life of the belt. Lol.
    MadTaco461[QUOTED] likes this.
  5. Aug 30, 2022 at 5:39 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    I've thought about going to efan life here and there. 3rz in mine. I feel like I lose half my HP when that mechanical fan kicks in.
    I hear too many failures stories about efans though to make me wanna give it a try. That would suck to have an electrical fan failure on the trail somewhere
  6. Aug 30, 2022 at 9:21 PM
    MadTaco461
    CA
    Kinda stock
    That efan made great power letting the motor rev out. I slammed into the rev limiter a whole bunch. If I did it again I'd buy a very nice brushless fan and have the haltech control it. My radiator is too thick now to squeeze it in there.
    I had e fan failure. You just cruise at speed. Just sucks when it's shits during a pull.
  7. Aug 30, 2022 at 10:00 PM
    betterbuckleup
    Ian
    Concord, CA
    What failed on your efan?
  8. Aug 31, 2022 at 4:21 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Which brand e-fan?
    I ask because I have had zero issues with the two SPALs on my truck, and one on my Bimmer.
  9. Aug 31, 2022 at 9:24 AM
    MadTaco461
    CA
    Kinda stock
    Flex a lite. More like flexheavy. It was ok for street but couldn't handle my abuse. I'm sure a brushless spal would of been great, but 10 year ago brushless was still just coming out. The old fans required 30 amps.
    Torspd[QUOTED] likes this.
  10. Aug 31, 2022 at 11:34 AM
    betterbuckleup
    Ian
    Concord, CA
    What size fans are you using?
    Wired to a temp sensor?
  11. Aug 31, 2022 at 1:22 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Pretty sure the Bimmer is a 16". The Tacoma has two smaller than that. I'd have to measure them. Maybe two 12's? One is to a temp sensor in the manifold for the radiator hoses and thermostat.
    It kicks on at 186. Simplistic design as it kicks on at full power. Then the other's relay is wired to the A/C relay. If I turn the fan knob to any
  12. Aug 31, 2022 at 1:33 PM
    betterbuckleup
    Ian
    Concord, CA
    No issues with temps while only the 1 fan is running?
    Good idea with having the other cycle on with A/C as long as the other single can otherwise manage temps.
    I would think a single 12" couldn't do enough CFM to keep up in low speeds and/or crawling scenarios. Those OEM clutch fans apparently do 3k+ CFM or something like that
  13. Aug 31, 2022 at 2:28 PM
    PhoS
    PhoS Proffauxssional
    PNW
    08 FJ Cruiser
    Contains MSG
    Their higher end belts are beyond excellent (RPM, HD, Fleetrunner) , that's why I've been pushing them on ppl. Specially for S/C.
    I bought the highest rated fan Flexalite makes and a big ol sheet of aluminum to make a shroud but I think I'm gonna stick with the mechanical fan after all. The e-fan moves a shit ton of air, I just don't want the added complexity right now.. If anyone wants this fan LMK...
    https://www.jegs.com/i/Flex-A-Lite/...8SNA82JJC&trk_link=UC5K5SIV10TK53HRIJM0NPIENO
  14. Aug 31, 2022 at 5:28 PM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    How prone are the mechanical fans to failure? This summer the AC has had a hard time cooling when static. Like long red lights, etc. I charged it and it’ll freeze you at road speed, just not when static.
  15. Aug 31, 2022 at 5:42 PM
    MadTaco461
    CA
    Kinda stock
    Fan clutch do go bad. If yours is pretty old might be worth your time to replace.
  16. Aug 31, 2022 at 6:32 PM
    Brake Weight
    Ill have a look in the morning. Should have some wiggle in it I’d imagine?
  17. Aug 31, 2022 at 6:49 PM
    MadTaco461
    CA
    Kinda stock
    Honestly I couldn't tell the difference beside that the new one blows air like crazy at idle.
  18. Aug 31, 2022 at 6:54 PM
    MadTaco461
    CA
    Kinda stock
    Another topic. Has anyone used one of those GESI G sport high flow cats recently? They are pretty expensive. Curious if they kill the tail pipe stank when at idle or cruising.
  19. Aug 31, 2022 at 8:08 PM
    PhoS
    PNW
    08 FJ Cruiser
    Contains MSG
    Cat gonna cat, wtf is that pricing though. :eek:
  20. Aug 31, 2022 at 10:35 PM
    MadTaco461
    CA
    Kinda stock
