Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Jun 20, 2017 at 5:11 AM
    #1581
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    It will depend on the turbo size. Mine doesn't start to audibly spool up until around 2-2.5k rpms :notsure:.
  2. Jun 20, 2017 at 6:55 AM
    #1582
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    And gearing and motor and tranny. Haha all factors
  3. Jun 20, 2017 at 7:00 AM
    #1583
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Yup.
    For myself, I alway notice that driving with the turbo on, makes for easier acceleration, with less throttle input.
    MadTaco461 and Jstand like this.
  4. Jun 20, 2017 at 8:23 AM
    #1584
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    Good, getting tired of downshifting for a hill.
    At 60mph I'm around 2500rpm, I'm hoping to get a bw 54mm with a .63 a/r
  5. Jun 20, 2017 at 10:14 AM
    #1585
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I definately notice better power in the mountains but I think a lot of that is the better breathing exhaust and intake. Still had to use OD OFF a few times to keep from baking my transmission (trans locks up at 55mph in 3rd gear with OD OFF btw).
    But the better answer to that problem is a gear job. I'm seriously thinking about 4.88's in the next year. Possible 35's to follow.
  6. Jun 20, 2017 at 10:14 AM
    #1586
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I rarely downshift on hills now. It's Usually only if I'm at higher elevations of 7000+ ft. Before my little 2.7 was always needing a downshift.
    My gearing is 4.88 w 33's so I'm at 3000 at 70-75 mph. It gets into a couple pounds of boost very quickly
    Jstand and MadTaco461 like this.
  7. Jun 20, 2017 at 11:14 AM
    #1587
    GreeGunc
    Jacob
    North GA
    Have you checked your gas mileage since then? Seems like it'd use more but all Toyotas run high rpms on the rd
  8. Jun 20, 2017 at 11:18 AM
    #1588
    boostedka
    James
    NM
    On the freeway I get 20-21, in town is a little less. It's about the same as when I was all motor w 31's and 3.90 gears, but with way more power. Those numbers are when I had the pinks and stock ecu running things. I haven't tuned or driven enough yet with the MS and 550's to compare the difference.
  9. Jun 20, 2017 at 11:44 AM
    #1589
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    My turbo didn't change my street driving. Just lot more power.
    Jstand likes this.
  10. Jun 23, 2017 at 8:15 AM
    #1590
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    Is that in top gear or your 1:1 gear ? Reason i ask is mine in 3rd gear which is 1:1 ratio at 60 mph im at 3000 with 31s
  11. Jun 23, 2017 at 9:00 AM
    #1591
    GreeGunc
    Jacob
    North GA
    With my 265s and 4.30s I'm at 75mph at 3k. Wanting to put on 285s cause my truck is mostly on highway
  12. Jun 23, 2017 at 9:09 AM
    #1592
    boostedka
    James
    NM
    That is in 5th gear. With my W59 manual transmission that is 0.85:1. Your auto trans it closer to 0.71, IIRC, lowering your RPM's at cruising HWY speeds.
    Jstand[QUOTED] likes this.
  13. Jun 23, 2017 at 9:17 AM
    #1593
    Jstand
    Irving,Tx
    Im thinking I'v ether got 4:30s or 4:56s
  14. Jun 23, 2017 at 2:36 PM
    #1594
    boostedka
    James
    NM
    Did you look at your door jam gear code?
  15. Jun 23, 2017 at 8:15 PM
    #1595
    Jstand
    Irving,Tx
    Yes it B07A :)
    boostedka[QUOTED] likes this.
  16. Jun 23, 2017 at 8:19 PM
    #1596
    Jstand
    Irving,Tx
    I've just about got everything to do the inter cooler and I think that will be it for the engine some I realize now that it's not going to be a drag truck:rolleyes:
  17. Jun 23, 2017 at 8:42 PM
    #1597
    Blackdawg
    Monte
    Wyoming/St. Louis
    If you are going to 35s, anything but 5.29s is a mistake ESPECIALLY with you're stupid slush box tranny.
    And you should manual swap it before even thinking about 35s. You don't offroad so why bother with 35s :p :luvya:
  18. Jun 24, 2017 at 1:43 PM
    #1598
    boostedka
    James
    NM
    How do you like that oil? I saw at Walmart today the they have the 0W-40 for $25 for 5 qts. I thought about trying it out. I've been using Mobile1 5-30.
    Jstand likes this.
  19. Jun 24, 2017 at 3:38 PM
    #1599
    GreeGunc
    Jacob
    North GA
    I use the Pennzoil full synthetic in my toyota and my dad runs regular in my mom's sequoia and my sisters 5 lug tacoma.
    Not a problem
  20. Jun 24, 2017 at 7:10 PM
    #1600
    GreeGunc
    Jacob
    North GA
    I have a predicament....instead of trying to stuff an intercooler in the grill I could sell my shrockworks and winch to get a tube bumper.
    I dont really like the open concept of a tube bumper but I could add some filler plate around the intercooler so it isn't as "open" but it will most likely have headlight protection cause that's what saved my truck before
    boostedka likes this.
