Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Nov 26, 2022 at 4:37 PM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    I just got some more info. He had a built 3rz in it originally, but the bottom end let go 5 years ago. So he put a 2rz in there with the "built" head. Going to look at it tomorrow morning, I'll get more photos and info.
  2. Nov 26, 2022 at 5:37 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Just got back from a week long trip in the desert. Truck did great as always.
    PhoS, j0shu4, betterbuckleup and 5 others like this.
  3. Nov 26, 2022 at 5:52 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Still sounds like a winner to build upon.
    Jon64l and BananaMan[QUOTED] like this.
  4. Nov 26, 2022 at 5:53 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I swear that your truck has got to be the most trouble free. You've got a good formula.
    MadTaco461[QUOTED] likes this.
  5. Nov 26, 2022 at 6:10 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    I'm one step closer to turboing the RAV4 now... 16 with 63k 4wd with icons all the way around... The wife may love it more than she does me... Just can't wait to get them bfg's replace and probably gonna relocate the oil filter since it's behind the skid plate and it's the junky cartridge one
    Torspd, MadTaco461 and mZiggy like this.
  6. Nov 26, 2022 at 8:23 PM
    MadTaco461
    CA
    Kinda stock
    I am pretty easy on the truck. It is exciting that it just wants to go. It is pretty high maintenance compared to a stock truck, but general prep has been good to me.
    Torspd[QUOTED] and BassAckwards like this.
  7. Nov 27, 2022 at 6:28 AM
    BananaMan
    Alright, so the turbo taco is a bit of a project to say the least. I think I'm probably going to pass on it. The guy who originally built it, did so in order to drive from Maine to Michigan with a camper in the back, compete in a car and driver event, then drive back to Maine.
    He successfully did this, but it means he set the truck up a bit weird. The coil springs on the rear struts are rubbing on the buckets, the top of the buckets have pipe thread nipples to mount the struts to. There's also bungee cords wrapped around the shock to act as a bump stop. The truck sits with a very forward rake to it, because he meant for it to have a camper in the back. Bottom of the frame has been plated from the rear dog leg to the front of the cab on both sides. It's got a fuel cell in the rear, the pump is mounted too high so it goes dry when under 1/4 tank. Also the fuel fill leaks water into the tank and it has for years. Needs all four calipers rebuilt or replaced, and four new tires.
    It's got a non intercooled turbonetics turbo setup, t3/t4 hybrid pushing 11psi, 500cc injectors, "built" 3rz head with a cam package on a stock 2rz bottom end. SDS stand-alone, yard tuned to 11:1 afr at WOT, but "more rich" at idle and normal driving. He said he can see oil pushing out the back of the turbo on startup, but it only does it for a minute before sealing up, so I think the turbo is on its way to heaven.
    Overall, I think it needs too much work and repair for me to take on with my current projects. It would be good for somebody just starting out on turbo projects, but I can't justify buying it when my other projects need the attention.
    B7D898D5-6417-442B-BD35-15BE9CB7F433.jpg 2C4A33C7-CE69-4E34-8C03-68F638320576.jpg 09E64ADB-CA4E-4B11-8083-964ADE889043.jpg 8E6E6589-87B4-44FE-9548-0FA077607FBB.jpg 76C6A305-363F-4DD1-B5BA-95008C1B86DD.jpg F567E2DC-62F9-4F57-B627-19B0FB302EDB.jpg 67BEBECE-E1BB-4D4A-B51B-BF0CCA211E56.jpg 92CC0BB7-8E4F-407E-B41A-50ACF01AA082.jpg
    MadTaco461 and Jon64l like this.
  8. Nov 27, 2022 at 8:27 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Oh my....Pass
    Reh5108, BananaMan and MadTaco461 like this.
  9. Nov 28, 2022 at 5:46 PM
    MadTaco461
    CA
    Kinda stock
    For the 1gr is there a drop in maf housing out there that works?
    My buddy is making an custom intake because he has an engine cage. He bought this stupid housing and it is a pile. Fuel trims dance like hula girl.
  10. Nov 28, 2022 at 7:08 PM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    Brake Weight and MadTaco461 like this.
  11. Nov 29, 2022 at 3:57 AM
    BananaMan
    So I'm revisiting the idea of the turbo taco. Mainly to use the drivetrain and stand-alone to swap into my '76 midget. Anybody think that Supra rear end is worth anything? I'd either scrap it with the truck or pull it out and sell it.
    My thought process here, is that I can get the truck for cheap enough to possibly make most of my money back selling interior parts and the Supra rear. And even if I don't, where else am I going to buy a running+driving turbo drivetrain with a stand-alone for under 2k? (We wiggled on price)
    MadTaco461 likes this.
  12. Nov 29, 2022 at 12:40 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    How capable is that standalone?
  13. Nov 29, 2022 at 12:40 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Jon64l and MadTaco461 like this.
  14. Nov 29, 2022 at 12:45 PM
    BananaMan
    I guess I don't have to worry about options, the listing got removed.
  15. Nov 29, 2022 at 12:48 PM
    MadTaco461
    CA
    Kinda stock
    It's pretty low value items on that truck. If you have the time to do it right could be worth the time. Could get a good 300whp with some solid maintenance.
    BananaMan[QUOTED] likes this.
  16. Nov 29, 2022 at 1:15 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  17. Nov 29, 2022 at 1:23 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    So off the market?
  18. Nov 29, 2022 at 1:24 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I've seen the guys at Roadkill have fun with worse. With some ingenuity, it'd be a blast, and definitely something that you weren't worried about being pristine.
  19. Nov 30, 2022 at 8:42 PM
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Wondering if I should move my boost controller fitting closer to the butterfly on the charge pipe?
    It's just aft of the impeller on the turbo housing now as circled in red so it us way downstream.
    BananaMan likes this.
  20. Dec 1, 2022 at 7:28 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Why?
    BananaMan and Speedytech7 like this.
