Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Jan 5, 2023 at 5:18 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Panty hose work as a good alternative in a pinch.
    MadTaco461[QUOTED] likes this.
  2. Jan 5, 2023 at 8:44 PM
    PhoS
    PhoS Proffauxssional
    PNW
    08 FJ Cruiser
    Contains MSG
    My filter wears prefilter is like 2 years old holding up great.
    MadTaco461 likes this.
  3. Jan 14, 2023 at 6:34 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  4. Jan 14, 2023 at 7:59 AM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
  5. Jan 14, 2023 at 8:59 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I did too. Either bursting with confidence, or ignorant.
  6. Jan 14, 2023 at 9:13 AM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I've used one with diamond on the leading edge. It was ok. Bit sketchy.
  7. Jan 14, 2023 at 9:33 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Well if he ever does cut a thumb off, he probably won't do it again... Unless they can reattach it, then I suppose there is a chance
  8. Jan 14, 2023 at 9:51 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  9. Jan 14, 2023 at 9:52 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    So have I. Works really good on non metal applications. Not nearly as quickly as the one in the demonstration. Must be in the grit size.
  10. Jan 14, 2023 at 4:54 PM
    Yota X
    Yota X Some say dresser, I say dryer.
    NW New Jersey
    1st gen
    ls turbo, tons, 40's and a partidge in a pear tree
    looks familiar. I feel your pain. I just wrapped my efi crap up behind dash. Sucked.
  11. Jan 15, 2023 at 8:24 AM
    Texasdynaryder
    Texasdynaryder Well-Known Member
    Chance
    Paris, Tx
    Kings Built Engine All the other small goodies
    Who is the 3rz turbo guru? I need to bounce some questions off of he/she….
    I bought a new reman 2.7l a few years back and had it swapped in for my turbo 3rz build. I’m going to start tearing the engine down and want to know the suggestions while it’s sitting on the engine stand.
    BananaMan likes this.
  12. Jan 15, 2023 at 9:39 AM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    @Texasdynaryder
    My friend still has a few 3rz engine goodies available.
    Screenshot_20230115-103655_Chrome.jpg Screenshot_20230115-103707_Chrome.jpg Screenshot_20230115-103711_Chrome.jpg Screenshot_20230115-103717_Chrome.jpg
  13. Jan 15, 2023 at 11:36 AM
    BananaMan
    Easy one is delete the balance shafts. LCE is a good company for that and most other 3rz engine performance stuff.
  14. Jan 15, 2023 at 11:52 AM
    Texasdynaryder
    Chance
    Paris, Tx
    My current engine from Yotaone has the delete in it. I was most curious along the line of needing a stronger bottom end or just roll with what I got. I’m not looking for fun and solid!
    That looks like a good price!
  15. Jan 16, 2023 at 12:57 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Fooling around with a 1GR merge design, as well as a T3 merge for a 2TR. 20230115_180654.jpg
    Yota X, BananaMan, MadTaco461 and 2 others like this.
  16. Jan 16, 2023 at 1:03 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    If you’re keeping it at or below 300whp the stock bottom end is good. If you want more, forged rods and pistons, ARP main & head studs and ARP rod bolts, and you should be able to turn it up quite a bit.
  17. Jan 16, 2023 at 2:04 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    With that combo listed above, the engine will be able to output far more than the oem transmissions can handle. That's easily 800 plus crank power capable.
    With the balancing shafts removed. And o-rings around the cylinders.
    BassAckwards and BananaMan like this.
  18. Jan 16, 2023 at 2:22 PM
    BananaMan
    Have you heard if anybody has o-ringed a 2tr block?
    BassAckwards likes this.
  19. Jan 16, 2023 at 2:35 PM
    BassAckwards
    You should be the guinea pig with one of those spare blocks you have lying around… :boink::D
  20. Jan 16, 2023 at 2:48 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Only those trying for the 1K mark. Some over the 1k mark have gone to larger diameter head studs.
