Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Feb 21, 2023 at 8:11 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I should have photos in my build thread. I think it was May of 19'. I'll try any find it later this evening. It worked well enough I suppose. Not the prettiest thing. I might try and mold/weld some plastic for the next one.
    unstpible[QUOTED] likes this.
  2. Feb 21, 2023 at 8:15 AM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    @unstpible
    Ik22 are good for SC, works fine for turbo too. That's what I'm currently running on 8psi.
    Also definitely use a Bov or recirc valve. When you close the throttle, pressure builds up in the charge piping and overpowers the compressor wheel causing the assembly to spin backwards for a moment. It makes a cool noise called flutter, but it is a bad thing for turbo life span. I saw a guy loose a new gt3076 on the dyno because his bov had seized closed.
    Tial and TurboSmart make quality valves. I'm using the TurboSmart plumb back on mine.
    unstpible and Torspd like this.
  3. Feb 21, 2023 at 8:29 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    What did CX provide on the turbo itself and for a drain fitting? Pics?
    I wouldn't put larger injectors in unless you're going to be using a piggyback or standalone. But maybe consider a FMU (fuel pressure regulator that causes greater enrichment under boost) 3:1,6:1... something in there. I know someone who is selling a Toyota specific one
  4. Feb 21, 2023 at 8:36 AM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Ok cool. The 7163 EFR was recommended earlier. Any other recommendations I should look at? Wanting to keep the low end torque of the S/C up to 10psi or so.
    Speedytech7 and Torspd[QUOTED] like this.
  5. Feb 21, 2023 at 8:44 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Being an all inclusive turbo, nope. That's just my opinion though.
  6. Feb 21, 2023 at 9:06 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Working on a 1GR turbo manifold. With cross-over to follow. This one has been quite tricky. Soon to work on the 2TR turbo manifold that I started a while ago.
  7. Feb 21, 2023 at 10:34 AM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    Woot!
    Torspd[QUOTED] likes this.
  8. Feb 21, 2023 at 12:33 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If I could do an underslung for the 2TR, that would make me super happy. Don't have access to a truck anymore though. :pout:
  9. Feb 21, 2023 at 2:07 PM
    BananaMan
    Unfortunately you're just a touch far away for me to drop mine off for a year or two :rofl:
    edit: that would be some real tight packaging for an underslung, and it would suffer from heat soak in that location I would think.
  10. Feb 21, 2023 at 3:12 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    I'll need to get more pictures of the hardware and stuff that came with the turbo. I know there are some banjo fitting in there and I knew i should have gotten more pictures before stuffing it back on the parts shelf.
    I forgot about the tuning requirements with different injectors. So ill definitely keep it stock for now.
    What FMU is it and who's got it?
    I've seen a few FMU installs recently but I don't remember exactly where.
    BananaMan likes this.
  11. Feb 21, 2023 at 3:23 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    @BananaMan , it was either within the course of one day or two, I had the manifold mocked up for @BassAckwards. Regardless, plenty of OEM's use the style. In the case of the 2TR, it'd make it easier to retain the SAIS functionality.
    BananaMan and BassAckwards like this.
  12. Feb 21, 2023 at 3:25 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    The underslung design would help substantially with downpipe packaging as well. My downpipe was a pita and it still doesnt fit well. I will be rebuilding it again at some point.
  13. Feb 21, 2023 at 3:27 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That is another reason as well^^^
  14. Feb 21, 2023 at 4:19 PM
    BananaMan
    How far forwards does the turbo sit currently? I would think there'd be enough room to clear the rear header pipe and take a 75 degree or so turn down to follow the factory ish routing for the down pipe?
  15. Feb 21, 2023 at 4:21 PM
    BananaMan
    This was my theoretical positioning of the holset turbo, obviously not at that incline but roughly that location. 637C32BA-86DD-41BF-9EBB-B37BA403DCFF.jpg
    MadTaco461, BassAckwards and Jon64l like this.
  16. Feb 21, 2023 at 5:51 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Only problem is top mount is sexy.
    Torspd and BassAckwards like this.
  17. Feb 21, 2023 at 8:29 PM
    unstpible
    Derek
    Cedar City, Utah
    @Speedytech7
    Here's a look at the included hardware for my CX Racing setup.
    Using my Sesame Street smarts identifying shapes and color I believe I know where it all goes but I don't know what the banjo bolt and brass tubes are supposed to be supplying, they bolt on at the 3 and 9 o'clock position with the oil lines at 12 and 6
    Maybe coolant lines that tie into the throttle body? :notsure:
  18. Feb 21, 2023 at 8:30 PM
    Speedytech7
    Those banjos and brass tubes supply coolant because that's a ball bearing Turbo and it needs more than just oil to keep it cool. Looks like you got about everything there though. We'll just have to figure out what fitting goes in the top so you can get an oil supply line too. Looks like it might be a 4AN or 6AN
  19. Feb 22, 2023 at 8:08 AM
    Reh5108
    Idaho
    This doesn't help in closed loop, does it? From my understanding the ecu wants to see stoic and will just trim the excess fuel out. Is this correct?
  20. Feb 22, 2023 at 8:13 AM
    Speedytech7
    The answer is yes and no, the enrichment is so instantaneous it will still richen up and the computer over time can trim it out. But because it has no effect on cruising range (any out of boost range) it tends to do much better than other methods of helping get enough fuel in. It richens well over what the computer can compensate for in a reasonable amount of time, but usually doesn't throw a code because it doesn't affect cruising steady state ranges.
    Reh5108[QUOTED] and unstpible like this.
