Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Feb 27, 2023 at 7:05 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    A good internal and external coat, will protect the metal.
    BassAckwards and BananaMan like this.
  2. Feb 27, 2023 at 7:12 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Isn't the cracking concern usually more for stainless (particularly lower grades) that have been wrapped with fiberglass wrap?
  3. Feb 27, 2023 at 7:39 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Yes sir, still holding up nicely after about 6 months and 8,500 miles. Whenever i get around to rebuilding the downpipe and it actually fits, i will be having that coated at Polydyn as well
  4. Feb 27, 2023 at 8:08 AM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2006 Tacoma, 2000 4runner, 1996 Tacoma
    @Shortman5
    I probably would do T4 twin just to avoid the adapter/spacer. Makes turbo sit higher and one more thing to leak.
    I personally chose to ceramic coat all my hot parts, (mani, turbine, downpipe). My charge pipe runs right over them so anything to keep the heat down. I also made a stand off heat shield on the downpipe.
    Blanket is good too, but it was just easier to coat all at once for me.
    unstpible and Torspd like this.
  5. Feb 27, 2023 at 8:20 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I have only seen mild steel headers that are wrapped, have a problem. Never 304 or greater. Make sure not to get some off label "304" though.
  6. Feb 27, 2023 at 8:49 AM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Yeah. No telling what CXR uses. I wouldn’t wrap anyway. Only ceramic coat. But damn I would hate to buy a set, send them off, then find out the fitment is shit. Ive been through that twice with both JBA and DT. Not fun.
    Torspd[QUOTED] likes this.
  7. Feb 27, 2023 at 8:52 AM
    Speedytech7
    The CX kit is known to have crossover pipe fitment issues... but they have a flex section in the crossover now so maybe that has been resolved.
    This guy talks about the fitment
    https://youtu.be/tYX96aR-n8Q
    Jon64l, Torspd and unstpible like this.
  8. Feb 27, 2023 at 9:21 AM
    Shortman5
    Supercharged TRD
    I guess I’ll just have to get it in and compare it to a stock manifold best I can before I decide on sending it off.
    What’s the word on the CXR intercooler kit? Looking At the size of the thing it ought to cool a hot curry fart.
    BananaMan and unstpible like this.
  9. Feb 27, 2023 at 9:23 AM
    Speedytech7
    Can't comment on it, ruled it out immediately on my truck with the steel bumper and the 95-97 flat face. No room for it. Decided to go water to air instead
    unstpible likes this.
  10. Feb 27, 2023 at 12:31 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I'm running a Treadstone TR8 and love it. It's a heavy sucker.
  11. Feb 27, 2023 at 1:48 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I was close to getting a Treadstone core. Except that their thickeness to hp capacity was thicker than that of the Garrett cores. So Treadstone end tanks onto a Garrett core. :D
    MadTaco461 likes this.
  12. Feb 27, 2023 at 2:37 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    I've got my stock manifolds in the garage still so when I get feeling a little better I'll go put them up next to the CX manifolds for comparison.
    Damn drivers side ball flanges on the DT's I have the same issue. It's a damn shame. The man himself is buried in the cemetery not far from my house and he probably turns in his grave every time I drive past.
  13. Feb 27, 2023 at 2:48 PM
    Shortman5
    Supercharged TRD
    Do you have a recommendation for a vendor on the EFR?
  14. Feb 27, 2023 at 5:03 PM
    Jon64l
    Jon
    @Shortman5 and @unstpible
    Test fit your Cx kits before you decide to coat them. You probably need to have the head flanges decked at a shop. This can also change how things fit up.
    I've bought some cx flanges in the past, they are wavey and not flat even before welding. I'm not talking about a slight bow that can be fixed with a 2lb hammer and a couple pieces of wood. More like sporatic low pockets. Last ones the holes were not even in the right spot. Had to die grind out the holes to make it fit.
    unstpible, Shortman5 and Torspd like this.
  15. Feb 27, 2023 at 5:44 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    BoostLab.
    MadTaco461 and BassAckwards like this.
  16. Feb 27, 2023 at 6:33 PM
    BassAckwards
    I bought my 7163 from BoostLab. I would pass on the ceramic coating they offer for the hot side, mine hasn’t held up to the test of time. Other than that, I’d buy from them again. Came packed very well and no issues here. They make a nice billet drain flange for the EFR turbos as well
    https://www.theboostlab.com/bl-billet-efr-series-turbo-oil-drain-flange-10an/
    Torspd and Shortman5[QUOTED] like this.
  17. Feb 27, 2023 at 6:47 PM
    Shortman5
    Supercharged TRD
    The EFR really does seem like the ticket. I’m curious now about the recirc valve and how well that plays with the factory MAF. It would be really nice not to have to worry about tuning that on of everything else. Anybody have any comments on that?
  18. Feb 27, 2023 at 7:22 PM
    unstpible
    Derek
    Cedar City, Utah
    Sounding more and more like expensive cheap shit all the time.
  19. Feb 27, 2023 at 7:33 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It is far from the MAF, and recirculating. It won't affect what thr MAF sees.
    Shortman5[QUOTED] likes this.
  20. Feb 27, 2023 at 7:56 PM
    Jon64l
    Jon
    If the Maf is before the turbo (draw thru), you must recirc the bov to intake pipe after the Maf, before the turbo. It is metered air and ecu will be sending fuel for this air. Rich condition happens when bov is open otherwise.
    If the Maf is after Turbo (blow thru) and the Bov is before the Maf, then it can vent to atmosphere. The Maf will not see this air and thus not add fuel for it.
    Don't put a Bov after the Maf, if Maf is after turbo.
    I recirc because my truck sees alot of dirt miles, even tho bov is before maf and maf is after turbo. Less dust entering the engine the better.
