Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Feb 28, 2023 at 5:11 AM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    How about oil drain in the pan. Obviously, I want to install that as high in the pan as I can but googling around I also read you don’t want to install it in the vicinity of the windage gray to avoid oil slosh.
    Just looking at some pictures of the 5vz it doesn't look like this would be an issue as the windage gray is above the whole pan except for a gap on the passenger front. So looks like middle of the sump area of the pan is ideal.
    Anything to kind in mind when doing this so I won’t have to go back?
  2. Feb 28, 2023 at 6:43 AM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    The pan is easy if you can weld. I used a 90° bend of 1" Dom with a -10an welded onto it. I trimmed the angle of the bend a little to sit away from block and behind Ac pump. Put it as high up on pan that i coild get the Tig around, between the bolts that hold pan to block and marked it. Then just remove, clean, prep, weld, paint.
    I used the 90 up so the hose end fitting would never be at or below oil level. Figured ot would have less chance to leak over time. Also I can pull the turbo/line without leaking any oil.
    If you are 4x4, you will have to pull the front diff.
    Shortman5 and Torspd like this.
  3. Mar 1, 2023 at 1:55 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    I'm thinking I might be able to use this Spectra box between the snorkel and the turbo IF it will fit.
    The 4" outlet will match up perfect to the turbo. A little more than 10 inches in length seems reasonable but I honestly don't know how much space will be available in front of the turbo.
    Any thoughts?
  4. Mar 1, 2023 at 2:16 PM
    Jon64l
    Jon
    I would wait to buy anything extra until you mock up. Takes longer but wastes less money this way.
    Not much room in there. Not a Cx kit but pretty similar placement.20221021_155247.jpg
    PhoS, unstpible and MadTaco461 like this.
  5. Mar 1, 2023 at 2:23 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Words of Wisdom ^^^
    unstpible likes this.
  6. Mar 1, 2023 at 2:47 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    I would make sure that the filter has enough surface area to support your HP goals and CFM requirements. I was looking at those for myself previously, but found that I needed to size up and then it woudl be far to big to fit anywhere in the engine bay. Would be even more of a problem with the location of the turbo on your setup.
    unstpible[QUOTED] likes this.
  7. Mar 1, 2023 at 3:02 PM
    Shortman5
    Supercharged TRD
    I could save some good cash if I build my own intercooler setup instead of using the CX stuff. looking at this silicone intake intercooler in the link below. I don’t think I’ll be making more than 300 with 8-9 psi so should be fine. Other option is a treadstone.
    I guess the one concern with putting my own together I have is getting the MAF reading correctly. I’m going to have to neck down somewhere for the MAF factory sized connector and not really sure if it’s as simple as just installing in a straight run of it it’s going to require trial and error.
    anything I should know?
    https://directpsonline.com/product/treadstone-tr6-intercooler-400hp/
    https://www.siliconeintakes.com/front-mount-intercooler/heat-exchanger-p-207.html
  8. Mar 1, 2023 at 3:41 PM
    Jon64l
    Jon
    I would probably lean towards the treadstone Ic out of those two, but either will work.
    https://performancemrp.com/i-304976.../performancemrp.com/search.html?q=2000+tacoma
    I run 2.5" piping off compressor to Ic.
    2.75" from Ic to TB. I cut the lips off that maf housing, beveled the inside edges, and welded it to the 2.75" pipe. My truck is 96 so I had to convert to the 2000 style maf that can drop in to the housing. Had to switch some wires at the plug, works fine otherwise.
    You could run 2.5" from Ic for the first couple/few feet, cut down on volume to fill and have a little more clearance.
    Shortman5 likes this.
  9. Mar 8, 2023 at 9:09 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Or pull the engine... :D
    Any 5VZ folks know what the fuel rail o-ring size is for injectors, 11mm? 14mm?
    BananaMan and Jon64l[QUOTED] like this.
  10. Mar 8, 2023 at 9:16 AM
    Jon64l
    Jon
    11mm.
    While that's out you should plate the engine mount brackets on the frame. Cut the existing horizontal plate that the mount bolts to off and put on a thicker one. Then plate from this down to the frame.
    MadTaco461, BananaMan and Speedytech7 like this.
  11. Mar 8, 2023 at 9:24 AM
    Speedytech7
    Thanks!
  12. Mar 8, 2023 at 9:31 AM
    Jon64l
    Jon
    Consider making a quick fixture and do 1 side at a time so you don't mess up the hole locations. I had to do mine with engine in after I broke the mount (on 2 trucks) and it was a pita.
    BananaMan likes this.
  13. Mar 8, 2023 at 9:35 AM
    Speedytech7
    What do you mean? What holes get messed up?
  14. Mar 8, 2023 at 9:39 AM
    Speedytech7
    Nevermind, I see what you mean now, I was going to plate the underside of those and add a gusset, but it is worth doing the tops too huh? @Jon64l
  15. Mar 8, 2023 at 9:47 AM
    Jon64l
    Jon
    The tops are thin and weak for that heavy iron 6 to be bouncing around offroad. I used 3/16" plate, perfect for the distance the cut took out under the thin factory top plate. Overall height remained the same this way. No trouble since.
    Torspd and Speedytech7 like this.
  16. Mar 8, 2023 at 11:42 AM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I plated mine while the motor is in. So many bird shit welds. Can't get the MIG in there. That is all getting fixed when I need to pull the motor.
    BananaMan and Jon64l like this.
  17. Mar 8, 2023 at 11:47 AM
    Shortman5
    Supercharged TRD
    What are you guys doing for oil feed line. I remember the STS turbo kit uses a T on the sender port on the block. But would it be any better/worse to use one of those aluminum oil filter spacers with the ports? That would make it easy and give you an extra port for an oil pressure gauge.
  18. Mar 8, 2023 at 11:56 AM
    Speedytech7
    Don't use a sandwich plate, it just gives you 1" less room for an oil filter, there is a filtered oil pressure bung right next to it you can tee off of.
    Torspd likes this.
  19. Mar 8, 2023 at 11:57 AM
    Jon64l
    Jon
    Both are good options. I cut up a old knock sensor and welded it to a T. The block is BSPT but most fittings are NPT. 1/8 npt is larger than 1/8 bspt, so less threads engage.
  20. Mar 8, 2023 at 12:04 PM
    Jon64l
    Jon
    Good call @Speedytech7
    There is a 8mm Allen plug under the oil pressure sensor that shares the same passage. Definitely use this.
    unstpible, Shortman5 and Speedytech7 like this.
