Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Mar 24, 2023 at 8:37 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    Damn, I'm still only a little past halfway through the thread. The more I read the more I want a haltech
    GoJo[QUOTED] likes this.
  2. Mar 24, 2023 at 10:05 PM
    GoJo
    GoJo Well-Known Member
    Utah
    Yea I binged the hell out of this thread and other's specific build threads.
    Yea, haltech would be sweet but got damn they is pricey!
    I've been keeping my eye out on aem units and there seems to be some pop up on ebay here and there. That said, anyone know if any of the current aem equipment is compatible? Series 2 or the infinity line I think they are.
  3. Mar 25, 2023 at 6:08 PM
    Adrian1
    Adrian1 New Member
    Hilux 2.7
    Not sure if this is the right place to ask.....
    What are people using for cams in their 2tr-fe turbo builds. Also the only head gasket I can find are mahle ones. I'm nearly through my shopping list
    BananaMan likes this.
  4. Mar 25, 2023 at 6:11 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I’m running stock cams in mine. ARP head studs and Mahle head gasket.
  5. Mar 25, 2023 at 6:16 PM
    Adrian1
    Adrian1 New Member
    Hilux 2.7
    Did you go for valve springs?
  6. Mar 25, 2023 at 6:21 PM
    BassAckwards
    Stock valvetrain at the moment. Running about 8-10lbs
    Adrian1[QUOTED] likes this.
  7. Mar 25, 2023 at 6:26 PM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    If you check out the 2tr performance thread, we've discussed it a couple times. The only option out there so far for us that want a different cam setup, would be WEB camshafts. You have to send them a set of factory cams, and tell them your build specs and they'll work with you on a custom grind. Back when I contacted them in January of 2021, they were six week lead time and 1k for the regrind.
    In talking with LCE about it, if you do the regrind and send them the specs, they can do a set of relief cut pistons from their forged lineup.
  8. Mar 26, 2023 at 8:58 PM
    unstpible
    Derek
    Cedar City, Utah
  9. Mar 27, 2023 at 3:47 AM
    BananaMan
  10. Mar 27, 2023 at 12:02 PM
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Taco47, BassAckwards, JustDSM and 4 others like this.
  11. Mar 27, 2023 at 12:13 PM
    BananaMan
    Finally! A third gen with some balls!
  12. Mar 27, 2023 at 12:18 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Nice! Sure sounds like a turbo. Have a rough idea what power you are putting out?
    ShiftyShank likes this.
  13. Mar 27, 2023 at 12:29 PM
    RedLantern
    Honolulu, Hi
    387g/sec @ 6578RPM. This blower moves some air! Will try to get dyno data this month
  14. Mar 28, 2023 at 6:27 PM
    Yota X
    Yota X Some say dresser, I say dryer.
    NW New Jersey
    1st gen
    ls turbo, tons, 40's and a partidge in a pear tree
    Chinese special.
    ShiftyShank and BananaMan like this.
  15. Mar 29, 2023 at 5:54 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    What's going on here?
  16. Mar 30, 2023 at 9:02 AM
    GoJo
    Utah
    Stocking up on parts..woot! Cx mani and tube kit came back in stock earlier so just pulled thyne trigger
  17. Mar 30, 2023 at 4:22 PM
    ShiftyShank
    ShiftyShank Oof
    Pat
    Northern Colorado
    02' BestGen 5VZFET
    I like this
  18. Mar 30, 2023 at 4:53 PM
    GoJo
    Utah
    Yes, long time coming should be fun! Jumped on the kit in a hurry, didn't want them to do go out of stock again quickly haha
    ShiftyShank[QUOTED] likes this.
  19. Mar 30, 2023 at 5:12 PM
    ShiftyShank
    ShiftyShank Oof
    Pat
    Northern Colorado
    02' BestGen 5VZFET
    I was fortunate that they were instock when I ordered. However it is still sitting in the corner of the garage collecting dust since December.:annoyed:
  20. Mar 30, 2023 at 10:08 PM
    GoJo
    Utah
    Get on it! You waiting on anything to get stated?
