Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Apr 17, 2023 at 1:34 PM
    GoJo
    GoJo Well-Known Member
    Utah
    Tucked in there nicely
    unstpible and PhoS like this.
  2. Apr 17, 2023 at 3:25 PM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    Some of both. Hoping for 400/400 at the flywheel but 350~ is fine. There’s folks pushing 5-600 on stock trans back as a daily. If it works out right it’ll be seeing some WTX summers which is often 110*+. Plus any idle time in those temps will heat soak rather quickly. Contemplating an additional fan or possibly reroute the headlight sprayer feed to an aux pump to spritz the IC.
    Still sitting on my Treadstone 3rz manifold and scouring the webz for a local ‘mechanic’s special’. Wanting 2wd regular cab 2rz manual trans and preferably coil pack era.
    Torspd[QUOTED] likes this.
  3. Apr 18, 2023 at 2:02 PM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    I foresee this being my truck in a year or two with autocross...
  4. Apr 18, 2023 at 3:27 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  5. Apr 21, 2023 at 9:08 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  6. Apr 22, 2023 at 3:49 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    So I watched the first 10 minutes of a video of a guy installing an "air cooled" turbo on his trans am... No oil lines, just a grease fitting. Any thoughts on this? Be a heck of a space saver/not having to figure out how to run supply and return lines or drill and weld.
  7. Apr 22, 2023 at 3:53 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    They're made by a company called Comp Turbo. Jetski guys love em
    yota243[QUOTED] likes this.
  8. Apr 22, 2023 at 7:45 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    If it were me, I'd rather not add another thing to the list of stuff to grease/maintain like that. Makes more sense for a jet ski though since those see a lot less hours than a car motor.
    What's the grease interval supposed to be?
  9. Apr 22, 2023 at 7:48 PM
    Speedytech7
    8 pumps of grease every 3k mi and rebuild every 50k. But apparently it's easily rebuildable on site with regular hand tools.
  10. Apr 23, 2023 at 7:03 PM
    Speedytech7
    Started the truck on the Haltech and with the exhaust side of the turbo all done. Not gonna do more than that until I can get chargepipes on it.
    https://youtu.be/g6XnrGQa0Bg
  11. Apr 24, 2023 at 10:37 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    Very nice!
  12. Apr 26, 2023 at 3:19 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Woot woot!!!
  13. Apr 28, 2023 at 11:22 AM
    unstpible
    Derek
    Cedar City, Utah
    It might sound like a dumb question but how are people getting the AeroCatch latches to fit on the hood. The hood is rounded where It should go and the latch body is flat.
    Just slap some rtv on to fill the gap or does it just distort the hood when you sinch it down (nobody wants a bent out of shape hood)
  14. Apr 28, 2023 at 11:31 AM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Add a bracket under the hood to push the hood latch back. Core support to the fender support.
    unstpible[QUOTED] likes this.
  15. Apr 28, 2023 at 11:44 AM
    MadTaco461
    CA
    Kinda stock
    Or do the hood button push to release style one. I just have the racing autofab ones, but they are a bit on the ugly side.
  16. Apr 28, 2023 at 12:02 PM
    yota243
    E.J.
    north Alabama
    Could you cut a "gasket" that would just take you that space?
  17. Apr 28, 2023 at 12:03 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    They conform decently. For that reason, I angled mine to have the least amount of deformation.
    unstpible and MadTaco461 like this.
  18. Apr 28, 2023 at 12:07 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  19. Apr 28, 2023 at 12:08 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Those are in the center line of the curve. For reference.
    Look what fits and works best for your mounting.
    unstpible likes this.
  20. Apr 28, 2023 at 12:37 PM
    MadTaco461
    CA
    Kinda stock
    There you go. Turn it 90*
