Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. May 5, 2023 at 7:44 PM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    Clock the cartridge so that they are 12 and 6.
  2. May 5, 2023 at 8:04 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Hi everyone, first time posting here. I've done three separate turbo setups on my truck (1st gen 5VZ-FE) until I am now finally satisfied. Did a TON of research before and during each of these projects from the science to the different parts available. Figured I'd offer my knowledge if it can help anyone.
    1. ebay GT35 @7PSI & all work done by me
    - Split Second Piggyback, 440cc
    2. Twin Focus ST K03s @ 4PSI (never was satisfied with the plumbing to turn it up) & all work done by me - one low mount, one high mount, both passenger side
    3. Twin Focus ST K03s @ 9PSI and climbing & all work done by me - both top passenger mount, fabbed together
    - Haltech 2500, 630cc
  3. May 6, 2023 at 3:28 AM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    Oh you can't tell us you twin turbo'd your truck and not post pictures! We gotta see this! It sounds awesome!
    Torspd likes this.
  4. May 6, 2023 at 8:20 AM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    @unstpible I had a similar issue on mine. I uses a steel flange and bent stainless tube to snake around, then put a -10 fitting on the end. I then heat wrapped it.
    Torspd and unstpible like this.
  5. May 6, 2023 at 8:57 AM
    treyus30
    Trey
    Mesa / AJ, AZ
    Got some stuff in the 2nd half of the first page of my build thread haha - see signature
    BananaMan[QUOTED] likes this.
  6. May 8, 2023 at 3:57 PM
    GoJo
    GoJo Well-Known Member
    Utah
    Progress
    I too am running into the oil drain flange issue. Best angle I can get is it at the 5 o'clock position, but not with my 10an flange, using the barbed flange the cx racing kit come with. So going to have to fenagle something together to connect to my 10an lines
    @unstpible I did get better v bands for the cross pipe but could not get them to work, wasnt enough give in them for the amount of tolerance on the cx crosspipe. So I opted to use the ones in the kit but with the better nuts from the better clamps..
    unstpible, Jon64l, MadTaco461 and 2 others like this.
  7. May 8, 2023 at 8:01 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Can you clock the center cartridge where the drain is on the other side of the flange? Closer to the firewall. You may have to pull it out of the turbine housing to make that happen.
    treyus30 and Jon64l like this.
  8. May 8, 2023 at 8:08 PM
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Be careful with the spectre filters. if it has the metal button in the middle of the cone, that's a no no. I ran one on my setup and it only lasted a month til the engine temps melted the glue off the button and I heard it hitting the blades of the inlet side of the turbo. I was fortunate that it didn't go through.
  9. May 8, 2023 at 8:11 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I have no clue if this is a good idea or not but does anybody ever use a banjo bolt for the drain. That would solve the space constraint
    unstpible likes this.
  10. May 8, 2023 at 8:21 PM
    Jon64l
    Jon
    I have not seen a banjo drain. Maybe if the holes in the bolt were drilled out and the hose immediately turned down. Don't want to back up flow and blow the seals.
  11. May 8, 2023 at 8:30 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Some OEMs may do just that. I don't know.
  12. May 8, 2023 at 8:31 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I am pretty sure that I have only seen it for feed and coolant.
  13. May 8, 2023 at 8:42 PM
    Jon64l
    Jon
    Would still need custom stuff made. Easier to rotate the way you said and hopefully a 45 fits in there. Otherwise do what I did Imo.
    Torspd likes this.
  14. May 8, 2023 at 8:47 PM
    Speedytech7
    In other news, I'm in piping hell, making this all route isn't fun.
    unstpible, Jon64l and MadTaco461 like this.
  15. May 8, 2023 at 9:11 PM
    GoJo
    Utah
    good call, yes it is that model. Guess I will be looking for a new one...
    Yea I can and its a worse angle that direction. Its a .82 exhaust housing so I think that is causing the issues for me that direction, unstpible has the .63 I believe and why he can cluck straight up and down.
  16. May 8, 2023 at 9:28 PM
    Jon64l
    Jon
    What's peaking out in the corner?
  17. May 8, 2023 at 9:31 PM
    Speedytech7
    Water to air intercooler core from a V12 Mercedes. They're plentiful and cheap on eBay and way more dense/nicely built than a lot of the new cores offered.
    Torspd and Jon64l[QUOTED] like this.
  18. May 8, 2023 at 9:34 PM
    Jon64l
    Jon
    Very nice! Where is the other inlet/outlet located? What's wrong with the situation?
  19. May 8, 2023 at 9:38 PM
    Speedytech7
    I'll take a picture tomorrow, it shoots out right in-between the edge of the radiator shroud and the power steering pulley, I'll be close down there but with any luck the 90° coupler will clear well enough to get it shooting back up toward the throttle body
  20. May 8, 2023 at 9:43 PM
    Jon64l
    Jon
    Maybe you can trim the coupler leg for more room. Or weld a bend directly to Ic outlet, then use a coupler. Also from the pic angle, i would say cut approx 1" off the throttle body coupler to get away from turbine. Otherwise looks great!
    Speedytech7 likes this.
