Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. May 25, 2023 at 9:51 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Right now just targeting 5.5psi, but long term goal is around 12
  2. May 26, 2023 at 5:16 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Truck looks super clean, and the paint looks better than that on my 2006. Eesh. Doesn't say much about the paint woes of my year model though.
    How are you liking the Haltech so far?
    Speedytech7[QUOTED] likes this.
  3. May 26, 2023 at 6:29 AM
    Speedytech7
    Thanks! Toyota white holds up decent being single stage, just polish it up when it starts to haze or cloud.
    The Haltech is great I think, lots of capability and adjustability. It's amazing how quick I could be totally daily drivable with it. Just needs some efficiency work in the tune now and it should be decent all around. Getting horrible MPG currently but that's probably equal parts tune and my right foot haha. Soon after that I'll start turning up the boost a bit
  4. May 26, 2023 at 8:37 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    I found that to be the case with mine too with the mpg's. It's surprising how much gas it drinks on the occasional pull. As long as you stay out of the boost, mpgs are pretty much unchanged.
    Just goes to show how much work toyota put into the ECU to try and make it efficient
  5. May 26, 2023 at 8:40 AM
    Speedytech7
    Yeah and I start hardcore safe and work my way down so even my transition cells are way richer than need be. Slowly but surely I'll get it nailed out. With a power adder it is way easier to ride near 0 inHg as well which even in a stock tune is richer than stoich so that contributes a bit, you'd normally only see that at wide open throttle NA. I'm going to put in my 4.56 gears next week as well which will lower my load all around a bit.
    unstpible likes this.
  6. May 26, 2023 at 9:22 AM
    betterbuckleup
    Ian
    Concord, CA
    Yea totally. Especially with 35's and such, it's easier to load it down and hit that 0 inHg at lower rpms. What gears do you have currently?
    Have you done any knock sensor tuning or do you plan to at all?
  7. May 26, 2023 at 9:26 AM
    Speedytech7
    I have 4.10s in there currently. If I had knock sensors I might try to fart around with them for another layer of safety in my tune. But I've never tuned with knock sensors before, I have detcans and my local dyno has an external knock ear setup to listen for it. I'm not shooting for a bleeding edge tune, even as conservative as it is now I sit at more advance than a stock computer would achieve NA in most cells.
  8. May 26, 2023 at 9:40 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The hardest part for me is the transient throttle tuning. I only ever get a brief amount of time to mess with it, so I cannot be too thorough. I think mainly it is my lack of understanding on it. As the inputs aren't making noticeable enough changes where I need it. More time is needed to better figure it out.
    Best fuel mileage that I ever had was ~30 mpg on a highway trip. I was literally giddy when I calculated that. That was done with the Haltech and the turbo kit installed. I was not staying under 60 mph either.
  9. May 26, 2023 at 9:41 AM
    Speedytech7
    Yeah transient tuning is tough, I love that it is a by ear/feel thing, but I also hate that it is a by ear/feel thing haha
  10. May 26, 2023 at 9:43 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Mine shows that it needs more instant tip in fuel, as there is a lean spot. Which I understand. However, my fueling changes only seem to make a difference when I get heavy into the throttle. So not sure what adjustment or where to properly adjust that out. Eh.
  11. May 26, 2023 at 10:32 AM
    betterbuckleup
    Ian
    Concord, CA
    Gotcha. Yea if you take enough timing out down low where you don't want to be building boost, you should be alright without knock control.
    Also why I plan to do the trans gear timing correction map for added safety in higher gears where you might forget to downshift or something
  12. May 26, 2023 at 10:34 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Agree to disagree... https://youtu.be/Bg617mnSHiE
  13. May 26, 2023 at 10:55 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Plasti-dip? :D
    Also, is 1st Gen white better than 2nd Gen white? I think it may be. Considering that I have two in my proximity, and the 1st Gen's looks better than the 2nd's.
    yota243[QUOTED] likes this.
  14. May 26, 2023 at 11:00 AM
    Speedytech7
    Didnt those have a whole lawsuit because the paint on those models failed
  15. May 26, 2023 at 11:18 AM
    Speedytech7
    I've got a bit more control over where my boost occurs and how much occurs too thankfully. But as of right now for safety I pulled a degree out in all of the positive pressure cells but I don't think I needed to. I'm, still sitting at 17-19* at WOT at 6psi.
  16. May 26, 2023 at 11:23 AM
    yota243
    E.J.
    north Alabama
    Lawsuit went back to 08... So missed it by 1 year
  17. May 26, 2023 at 12:15 PM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2006 Tacoma, 2000 4runner, 1996 Tacoma
    I hope we can all figure out the transient response, that was one of the biggest reasons to leave the fic.
  18. May 26, 2023 at 12:21 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It shouldn't be too hard. For me, it is just having the time to focus on that. I'm sure one of us will.
    Speedytech7 likes this.
  19. May 26, 2023 at 12:23 PM
    Speedytech7
    It'll get on my nerves enough to sort out sooner than later
  20. May 29, 2023 at 5:06 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    One small task completed before the sneezing and itchy eyes kicked in
    Torspd, Jon64l, GoJo and 1 other person like this.
