Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Jun 16, 2023 at 4:08 PM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    Just keep stacking parts/material and building it in your head. Do it in logical segments. When I did mine I didn't do the IC kit to start, just used couplers and pipe to get it to throttle body and drove on low boost. Then as I got more time did Ic (actually 2 versions). Anyway just keep going, slow progress is better than no progress.
    Torspd, unstpible and GoJo like this.
  2. Jun 16, 2023 at 5:27 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Well, happy/sad day, truck is making good power and hitting boost as planned but I smell clutch after pulls so it seems I'm exeding the torque load my new Exedy racing clutch can handle. :(
  3. Jun 16, 2023 at 8:09 PM
    Speedytech7
    Chatted with Exedy support. So that means I'm exceeding 370lb ft.
  4. Jun 16, 2023 at 8:46 PM
    Jon64l
    Jon
    Dayum!
    Speedytech7 likes this.
  5. Jun 17, 2023 at 6:17 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    This is wise^^^
    Grown out of those britches quickly. :muscleflexing: What's the next available stronger clutch?
  6. Jun 20, 2023 at 11:34 AM
    Speedytech7
    I am going to call clutch specialties in Georgia about having one made for me. We did that with my buddy's 300zx and the dude made an awesome clutch for it (same disc size as a tacoma) that held 700 ft lb for multiple dyno pulls and events even though he only guaranteed it for 500 ft lb.
    05Taco4x4 likes this.
  7. Jun 20, 2023 at 11:43 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    my concern in going to a heavier clutch would be having too heavy of a pressure plate to where it'd be tiring after a while offroad or any scenario where you have to use the clutch a bit
  8. Jun 20, 2023 at 11:45 AM
    Speedytech7
    I'm not overly concerned about that. There's a lot they can do to mitigate that by moving the fulcrum in the pressure plate. The 700 lb clutch in a 300ZX felt just barely heavier than stock.
  9. Jun 20, 2023 at 11:59 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That's quality there.
    A personal experience of my own, I installed a SPEC Clutch 3+ on my 2nd Gen. Before the change to the Twin Disk. It was rated for 500 brake torque, and held 550 WTQ. During the swapping, there wasn't even the hint of a hot spotting.
    Some clutches can be made very well.
    Jon64l and Speedytech7[QUOTED] like this.
  10. Jun 20, 2023 at 2:17 PM
    Jon64l
    Jon
    I've had good luck with Spec in the past too.
    Torspd likes this.
  11. Jun 26, 2023 at 2:08 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    Just putting it out into the universe that I'm planning on starting the turbo install this Thursday. I've got 5 days cleared off my schedule and will probably hang a do not disturb sign on the garage door
    Taco47, Gmak621, Brake Weight and 4 others like this.
  12. Jun 26, 2023 at 3:10 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It shall be manifest.
    Jon64l and unstpible like this.
  13. Jun 26, 2023 at 4:02 PM
    Jon64l
    Jon
    Nice, now you'll have 2 days left to enjoy it.
    unstpible likes this.
  14. Jun 26, 2023 at 6:19 PM
    unstpible
    Derek
    Cedar City, Utah
    I checked the gap on my IK22's and directly out of the box they are all at .030 on my feeler guage. Ive heard the target gap is between .034 and .028
    Figuring with how low I'm starting out on the boost it shouldn't need to be gapped super tight.
    I'm working on getting a small head start tonight and figuring out the Innovate BSP guage wiring
  15. Jun 26, 2023 at 6:49 PM
    Jon64l
    Jon
    I would definitely not run a boost controller of any sort to start. Just low WG spring pressure. Doesn't hurt to look at and plan, but you just need the wide band and boost guage functions for now.
    I would also start with the oil drain fitting once it's in the garage. After this is done and capped, truck is back to a drivable state.
    Torspd and unstpible like this.
  16. Jun 26, 2023 at 7:41 PM
    unstpible
    Derek
    Cedar City, Utah
    Exactly what I was planning.
    You have been full of great advice and I appreciate it. I was planning on skipping the boost controller for now and I have the smallest wg spring installed in the TiAl wg already.
    A local handyman said he was going to build me a billet aluminum oil drain fitting so I really hope that works out but I've got a plan to weld one up if that doesn't pan out like I want.
    Really just setting a date and getting started on the guage has got me feeling excited about it all over again.
    It's great knowing I've got the support of you guys in here too. Such a wealth of knowledge
  17. Jun 26, 2023 at 8:24 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Let us know how the billet drain turns out, otherwise, one of us should be able to help.
  18. Jun 28, 2023 at 7:22 AM
    Speedytech7
    Just got back from a 1,450mi trip through the Montana back country and mtns with the truck. It really did awesome even with the crazy elevation in some spots over 11,000ft. I need to add some minor barometric correction for boost control but still reliable and fast the whole time.
  19. Jun 28, 2023 at 8:00 AM
    GoJo
    GoJo Well-Known Member
    Utah
    quite the maiden voyage there!
    You still have it dialed up to 10 or did you back off given the clutch/torque limits you were experiencing?
    Speedytech7[QUOTED] likes this.
  20. Jun 28, 2023 at 8:10 AM
    Speedytech7
    Turns out I had a dragging brake, clutch is still holding and I have it at 9psi for now but it is allowed to spike to 11 during quick spool.
    I let my buddy ben drive it this weekend, here it is with a full load of camping gear at about 6000ft. Not as fast as sea level or empty but still solid for a heavy pig on 35s
    https://youtu.be/SGggNlLNTxs
