Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Jun 28, 2023 at 6:40 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    Starting a little early
    GoJo, MadTaco461, Speedytech7 and 3 others like this.
  2. Jun 28, 2023 at 8:18 PM
    unstpible
    Derek
    Cedar City, Utah
    Looks like the Toyota manifold MLS gaskets are off the table all together because the little rivits holding the layers together are in the way of the CX manifold flanges
    I guess if it was absolutely necessary I could possibly drill out the two rivets on the far left and right but I have extra manifold gaskets on hand for a reason haha.
    It's going fairly smooth so far except for smacking my hand while breaking a nut loose with a wrench. Also one of the bottom exhaust stud nuts slipped from my fingers and bounced around the engine bay without ever reaching the floor so I'm playing a little eye spy.
    I can also finally see the source of my oil leak on the drivers side valve cover. I was expecting it to be the half moon but it seems to be a little further to the right
    Not very easy to get a picture up in there
    Speedytech7 and Taco47 like this.
  3. Jun 29, 2023 at 5:54 AM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    You could drill or die grind a relief in the manifold flange where the rivets are.
  4. Jun 29, 2023 at 5:56 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Definitely some leaking cam plugs haha, mine were bad too
    unstpible[QUOTED] likes this.
  5. Jun 29, 2023 at 8:27 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    This^^^That way, all future gaskets will also work.
    unstpible likes this.
  6. Jun 29, 2023 at 3:53 PM
    unstpible
    Derek
    Cedar City, Utah
    Solid advice, It shall be done.
    Today's progress so far
    I got the oil feed line put together and installed using a T from the oil pressure sensor. I would have preferred to install it in the plug just below that but the fitting I had planned to use was too small
    Speaking of oil, all my catch cans are full so we won't be switching to 10w40 and the tundra oil filter today.
    I got the new spark plugs in.
    The ones I took out all looked about the same
    I should be hearing from the guy building the oil drain fitting later today, really wish I wasn't waiting on that piece but if it's what I need it will be worth the wait. Hopefully he will also be able to surface a couple of the V Band flanges, I realized yesterday the one coming off the drivers side manifold is pretty bad
    Torspd[QUOTED] likes this.
  7. Jun 29, 2023 at 3:59 PM
    unstpible
    Derek
    Cedar City, Utah
    I installed new ones when I did the valve cover gaskets but that's when I cracked the valve cover so I'm guessing I forgot to reseal it when I replaced the valve cover
    Torspd likes this.
  8. Jun 29, 2023 at 4:10 PM
    Jon64l
    Jon
    Do you need a valve cover? I should have some in a box.
    Also that black oil feed fitting looks like it's straight thread going into the T. Does it have a inverted flair or are they both Npt to seal? Just looks like it's sticking out too far.
    Be sure to check clearance with alternator and it's wiring too.
    GoJo, Torspd and unstpible like this.
  9. Jun 29, 2023 at 4:45 PM
    unstpible
    Derek
    Cedar City, Utah
    I bought a replacement Doorman cover after cracking the old one. Maybe I could paint yours and swap it out when I redo the cam seal, definitely worth considering.
    The fitting on the end of the T does stick out a little further than I like but it feel good. The female threads on the T are NPT and I think the fitting is straight I was considering cutting some of the threads off to make it a little shorter but I don't believe it's necessary. I have an NPT fitting too but it only goes in a couple threads so I stuck with the strait one. as for clearances I've got the hose installed on there now and it looks good I just forgot to get a picture but I will when I go back out there (I got washed up and had a late breakfast/lunch)
  10. Jun 29, 2023 at 6:14 PM
    Jon64l
    Jon
    I would recommend replacing that fitting with Npt. Straight thread doesn't seal properly without a O ring or inverted flair. If you feel the Npt doesn't thread in far enough, get a Tap and remove the T from block and tap it deeper. You may need to push a pilot drill into it so your Tap doesn't bottom out.
    Which side valve cover do you need? I can probably get it in Priority Mail tomorrow if we can work something out.
  11. Jun 30, 2023 at 6:31 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Definitely follow the steps Jon listed. Or you'll be back in there very soon, and it'll be a headache. We don't want that for you.
  12. Jun 30, 2023 at 11:16 AM
    GoJo
    GoJo Well-Known Member
    Utah
    I had to 90* off of that to get down and around the alternator wiring
  13. Jun 30, 2023 at 8:14 PM
    unstpible
    Derek
    Cedar City, Utah
    I'll have to get a 1/8 NPT tap to follow the advice but it shall be done.
    As for the valve cover I'm not in a rush to get back to that. The drivers side (with the oil fill cap) is the one with a leaking cam plug but if you have a set I might be interested in both so I can take my time cleaning them before painting and installing but that's a project for the future.
    For those following along I want to update on the rivits in the OEM MLS gasket.
    After further investigation I don't think drilling out the manifold is necessary. The CX manifold hits the rivits but the engine side doesn't come into contact with it
    Torspd, Jon64l and GoJo like this.
  14. Jul 1, 2023 at 5:35 PM
    unstpible
    Derek
    Cedar City, Utah
    How close can I put the BOV to the MAF?
    It's a turbosmart 25mm dual port recirculating BOV if that makes a difference it's attached to the Silicone coupler with my plyers sticking out right there by the radiator cap in the picture
  15. Jul 1, 2023 at 7:47 PM
    unstpible
    Derek
    Cedar City, Utah
    Definitely not getting the billet aluminum oil drain fitting I was hoping for
  16. Jul 1, 2023 at 9:01 PM
    Jon64l
    Jon
    That's probably a fine place for it. You are probably not using the recirc portion of it?
  17. Jul 2, 2023 at 12:08 AM
    unstpible
    Derek
    Cedar City, Utah
    Tonight's progress shot
    I hadn't intended to reuse the Airaid intake tube but damn it's a near perfect fit
  18. Jul 2, 2023 at 12:11 AM
    unstpible
    Derek
    Cedar City, Utah
    Recirc is all plumbed in. Enters back into the system just before the IC underneath the air filter.
    Jon64l[QUOTED] likes this.
  19. Jul 2, 2023 at 3:34 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Well done for being thorough.
  20. Jul 2, 2023 at 3:35 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If the hood closes, then it's a perfect fit.
