Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Nov 8, 2023 at 10:01 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Pedal feel is heavier than stock but not overly so and it behaves excellently in the rocks. Last trip I really liked it.
    Torspd likes this.
  2. Nov 8, 2023 at 2:23 PM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2006 Tacoma, 2000 4runner, 1996 Tacoma
    Just ordered a new clutch kit from Lce. Supposed to hold 385 ft/lbs.1053033-2.jpg Will report back on pedal feel and bite once that is swapped in.
    Speedytech7, unstpible and MadTaco461 like this.
  3. Nov 8, 2023 at 2:26 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Interested on your input. I thought about that clutch but I have the one right below that one.
  4. Nov 8, 2023 at 2:34 PM
    Jon64l
    Jon
    That's also the one I have currently (pro). It's 2 years old now and hasn't given me any problem until today. Drives really nice. Been slowly creeping up the duty cycle on the controller. Did a hard 1-2 shift and the revs went up quick but the truck didn't move as quick. Then the smell. Dang it. So now its time to turn the page.
    MadTaco461 likes this.
  5. Nov 9, 2023 at 7:45 AM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    Look at the import drag scene for a superior clutch setup. A stronger under dash clutch pedal spring can take a lot of the stiffness out.
    Torspd and Jon64l like this.
  6. Nov 9, 2023 at 7:47 AM
    Speedytech7
    I'm more interested in life with this one, I love the bite of a ceramic puck clutch but they are supposed to be driven more like they're binary. They eat the diaphragm and flywheel a lot when slipped so I think slipping it in the rocks is going to be really hard to do and hard on clutch parts themselves. That's the only reason I went with the highest rated organic clutch I could, which Exedy rates at 272wtq, back that up for drivetrain loss and its about 326crank tq. Clutch is the one thing that should always be crank numbers, dunno why they use at the wheels, but RA actually spells it out thankfully. The only confusing part about the numbers given here is the 420lb number, not sure what the different between at the crank and at the clutch would be since they should be a unit.
    Jon64l[QUOTED] likes this.
  7. Nov 9, 2023 at 3:12 PM
    Jon64l
    Jon
    I like the spring idea. I was thinking of playing with the pedal to get more leverage. Also thought about a clutch booster. Just gonna test it out first and see.
    @Speedytech7 I suppose I will have to change my driving a bit. If I can get another 2 years or so out of it I would be happy. 1 year is acceptable. Good thing it's a R151, lower ratio 1st and 2nd. I might re cam the throttle body so when it opens the truck doesn't snap forward as hard. This way I can leave it in 1st with the clutch out and not slip it. Will see.
  8. Nov 9, 2023 at 3:20 PM
    Speedytech7
    You could always take a little bit of timing out of your leave if you want to cut down your reaction there.
  9. Nov 9, 2023 at 3:38 PM
    Jon64l
    Jon
    Good call. Maybe it's time for a rotary trim knob.
    Speedytech7 likes this.
  10. Nov 10, 2023 at 10:33 AM
    Jon64l
    Jon
    Lightning fast shipping from Lce!
  11. Nov 27, 2023 at 10:10 PM
    Jon64l
    Jon
    Just thought I would share, last minutes to get 10% off from LCE on your yota goodies. Use Code cybermonday or CYBER10 to get discount. I used the first one on a new heavy weight flywheel.
    Torspd, MadTaco461 and betterbuckleup like this.
  12. Nov 28, 2023 at 1:50 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    10% could add up quick.
    Jon64l likes this.
  13. Nov 28, 2023 at 2:10 PM
    MadTaco461
    CA
    Kinda stock
    Stupid super duty taking up my Toyota mod time.
  14. Nov 28, 2023 at 9:43 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I can kind of relate. Lol. Stupid BRZ.
    MadTaco461[QUOTED] likes this.
  15. Nov 28, 2023 at 9:49 PM
    Jon64l
    Jon
    Idk if 10% off would even matter
  16. Nov 29, 2023 at 11:49 AM
    unstpible
    Derek
    Cedar City, Utah
  17. Dec 1, 2023 at 1:29 PM
    Taco47
    Taco47 Well-Known Member
    Norcal
    2016 2TR 5-Speed
  18. Dec 1, 2023 at 1:32 PM
    Jon64l
    Jon
    The compressor wheel looks too damaged. I personally would avoid it at that price.
    Torspd and Taco47 like this.
  19. Dec 1, 2023 at 2:07 PM
    Taco47
    Norcal
    2016 2TR 5-Speed
    I was thinking the same but there is an OBO option. What would be a good price to offer if I factored in a rebuild kit/labor? I’d rather buy new but wouldn’t pass up a sweet deal if it’s accepted.
  20. Dec 1, 2023 at 4:03 PM
    Jon64l
    Jon
    I dont like how the owner considers those "slight nicks". It basically looks like it ate an allen wrench. The rest of the wheel must be beat up too, not that it matters since we already know it needs a wheel. Definitely do bearings too, who knows what kind if "slight" loads they took. You might ask around to a reputable builder for a quote, but I personally would pass on this. Too much headache and unknown. Maybe @Torspd has some input.
