Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Dec 1, 2023 at 5:05 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Have you called anywhere to see what a repair cost may be?
    Those might be only on the leading edge, but without feeling it in person, you should stay away.
  2. Dec 8, 2023 at 1:18 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    What's everyone use for hardware on the hot side of the turbo? I keep pulling threads out of housings with stainless. Starting to think there may be a chemical reaction going on between the cast and bolt.
  3. Dec 8, 2023 at 1:22 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    Regular black oxide bolts and hi temp anti seize. If you can spring for copper coated bolts they do really well. Or better yet just put in Black oxide studs and use copper nuts
    Reh5108[QUOTED] and MadTaco461 like this.
  4. Dec 8, 2023 at 2:00 PM
    Taco47
    Taco47 Well-Known Member
    Norcal
    2016 2TR 5-Speed
    I’ve called a few places including boostlab where I planned to buy new but no one has got back to me. One shop advertised 500 repair cost not including parts which seems reasonable. I’m leaning towards a new unit if this persists.
    Torspd[QUOTED] likes this.
  5. Dec 8, 2023 at 2:01 PM
    Speedytech7
    Call Joel at Arizona Tractor and Turbo, guy is a turbo rebuilding savant
    Az Turbo Inc https://g.co/kgs/5zkfm3
    Torspd, MadTaco461 and unstpible like this.
  6. Dec 8, 2023 at 3:45 PM
    Taco47
    Norcal
    2016 2TR 5-Speed
    Just got off the phone with Joel and here is what he said
    1. ball bearing turbos are not rebuildable.
    2. journal bearing turbos are rebuildable and will do pretty much everything a BB turbo can.
    3. Buy an eBay turbo instead, they work just as good.
    4. Failures from turbos are always caused by the engine.
    5. The performance industry is a scam.
    dude seems genuine, time to ponder over life choices.
    MadTaco461 likes this.
  7. Dec 8, 2023 at 3:56 PM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    Interesting.
  8. Dec 8, 2023 at 4:28 PM
    Reh5108
    Idaho
    Interesting about the engine always being the cause of turbos failing.
  9. Dec 8, 2023 at 5:13 PM
    GoJo
    GoJo Well-Known Member
    Utah
    Black Oxide and copper nuts here, so far so good.
  10. Dec 8, 2023 at 5:23 PM
    Taco47
    Norcal
    2016 2TR 5-Speed
    He elaborated on too much back pressure and oil not having enough zinc (royal purple) killing bearings.
    That was an interesting conversation. He’s very talkative, didn’t want to make a dime from me even though he’s a turbo dealer. He said he’s seen ebay turbos balance better than garret units. I even asked him again if there were any cons for ebay units and he said the casting is sometimes less than perfect and parts are hard to get.
    Reh5108[QUOTED] likes this.
  11. Dec 8, 2023 at 7:07 PM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    @Taco47 maybe consider a ebay unit you can directly upgrade later if needed. Down pipe flange may chance or oil fittings, ect. Or consider Pulsar turbos. They are Garrett knock offs. Direct replacement as far as I know. They have a decent track record too.
    Really how much boost are you trying to run? Even if you give up 10% in overall performance (spool time, peak power) wouldn't a 50-75% cost savings negate that? If you are not competitively racing, it kinda doesn't matter. I've used a ebay T70 turbo many moons ago and had no problem with it. Maybe a comparable name brand unit would spool quicker and make more power per psi, but there are alot of places to put money in a turbo kit. Overall you will be better off with a name brand wastegate and quality ecu (cough haltech cough). Again maybe go middle of the road on a Pulsar or get a older Garrett journal bearing turbo. T3 60-1, T3to4e 60 trim, ect. What are your realistic goals/usage?
    Torspd likes this.
  12. Dec 9, 2023 at 6:17 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I have a bit of a disagreement with that. Poor quality control of cheap turbos will be the failure of cheap turbos. I have seen plenty that have had to be pulled apart straight out of the box to check for shavings. Sure enough, there were and would have ruined the turbo. @RedLantern even dealt with that, if I remember correctly.
    "Just as good" is a serious understatement of relativity. Will "just as good" have a tiny failure rate over the hundreds of thousands that are on the road, or have a 1:100 failure rate due to poor machining processes, and inferior metallurgy?
    Cheap turbos definitely blow up better, when they fail in the overspeed.
    Their modeling for fin design isn't as good either.
    Will they work, yes. How long will they work? How well will they work? Those are what are in question.
    RedLantern and dirtdigginjoe like this.
  13. Dec 9, 2023 at 7:57 AM
    Brake Weight
    Another cheaper, reliable option would be OEM pull offs. Most are designed with daily abuse in mind.
    Torspd likes this.
  14. Dec 9, 2023 at 8:23 AM
    Speedytech7
    This is true, water cooled journal bearing turbos are nearly indestructible.
  15. Dec 9, 2023 at 10:02 PM
    Reh5108
    Idaho
    Taco47 likes this.
  16. Dec 9, 2023 at 10:49 PM
    Taco47
    Norcal
    2016 2TR 5-Speed
    @Jon64l I’m not sure how much boost but my power goal is just below 385 crank which is the limit of lce’s dual comp clutch. I’d like to keep it daily drivable and their half metallic/fiber disc seems like a good place to stay. I’m not opposed to pulsars as the g30-660 seems like a possible fit aside from needing a t3 to vband adapter. I have a t3 manifold from @Torspd already which does not have provisions for a EWG. Thats why the efr 7064 is the top pick unless I can find something else that fits the bill.
    @Torspd trust me I was skeptical for the whole conversation. I just don’t understand why a turbo shop owner would say those things.
    @Brake Weight @Speedytech7 which ones should I look into?
    Torspd likes this.
  17. Dec 9, 2023 at 11:04 PM
    Speedytech7
    @Torspd is probably better at sizing than I am. If you're looking for a decent budget turbo I'd check out the ones from VS Racing. I'm partial to borgwarner EFR turbos for lower power goals though since they're good all in one units.
    Taco47 likes this.
  18. Dec 10, 2023 at 8:03 AM
    Jon64l
    Jon
    Will adding the adapter affect cleance elsewhere? Other options are to add Ewg port or change the turbo flange. Not ideal I know. With more cost incurred maybe just buy a new efr unit or a better used one.
  19. Dec 10, 2023 at 10:35 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I am using ARP stainless bolts and nuts. They are far stronger than typical stainless. They have been my best so far.
    Some places offer inconel.
  20. Dec 10, 2023 at 11:06 AM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    Turbo loves cold air. I hit a new PSI max while going up a steep grade on I-15 after a Christmas party. I was hardly on the throttle just maintaining speed and hit 5.2psi (still have the 3.6 psi wastegate spring installed).
    I really really need to stop procrastinating and get to work on the valve clearances so I can start figuring out what shims It'll need
    MadTaco461 and Torspd like this.
