Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Feb 9, 2024 at 9:52 AM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    My next option to quieten it down would be resonators just ahead of the bumper. Not much room at all under there.
    There’s a guy locally with an LS BRZ and has the motor tuned like whodathunkit. Man, it sounds so good.
    Torspd[QUOTED] likes this.
  2. Feb 9, 2024 at 9:10 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    His has the 3" MBRP axle back. We just need to tie into it. He's been contemplating a resonator of sorts, prior.
    Brake Weight likes this.
  3. Feb 9, 2024 at 11:43 PM
    Brake Weight
    I’d look for the biggest and longest resonator that’d fit in the tunnel. If he was contemplating it with the smaller motor he’ll definitely want something with the LS. Or maybe not. I’d love to hear it when finished.
  4. Feb 10, 2024 at 1:21 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    For sure, I'll be posting more about it, including a video. It'll be a few weeks though. Still need to order materials.
  5. Mar 7, 2024 at 3:11 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    What happens when e85 sits in a tank over a year, then you jump the battery off and drive it 15 minutes to see if the battery will hold a charge, to find out it doesn't so you r place the battery a few days later only to hear a terrible noise, just to have to wait 2 weeks until i had time to pull the spark plugs... This is a long question just to say "water was in the gas and got in the cylinders"... It exited quit violently when I turned it over without spark plugs btw as noted by the wet spot on my hood, fuse box and batteryIMG_20240307_170506_815.jpg
  6. Mar 7, 2024 at 3:13 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Ouch, that sounds like a project
    yota243 likes this.
  7. Mar 7, 2024 at 3:23 PM
    yota243
    E.J.
    north Alabama
    Well luckily the company that bought our company out 6 months ago, is about to cause a mutiny so I may have a ton of free time coming up for plenty of projects
    MadTaco461[QUOTED] and Torspd like this.
  8. Mar 7, 2024 at 3:53 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Sooooo did it break anything, or is there a chance that nothing was harmed?
    Will Stabil Marine grade even work to prevent E85 from separation? I know it does in fuel with up to ~10% E85
    Jon64l likes this.
  9. Mar 7, 2024 at 4:11 PM
    yota243
    E.J.
    north Alabama
    I don't think anything is broken, all cylinders were blowing out on compression/exhaust stroke and sucking in on the intake/power strokes. I'm not sure if anything could help with that much alcohol in an average of 123% humidity lol
    Jon64l and MadTaco461 like this.
  10. Mar 7, 2024 at 4:26 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Lol
    yota243 likes this.
  11. Mar 7, 2024 at 5:53 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    In news related to my truck, phew, I really need to work on the tune for daily driving. Just need to spend some good time with it. Haven't driven it much over the last few years, besides working on projects on it.
    I was rear ended in my Bimmer in December. Not badly though, and had been driving it up until last Thursday, when I dropped it off for repairs. Driving the truck has made me really want to spend some time to refine its operations. As well as finally get that built T56 Magnum.
    Still getting between 70-80 miles per quarter tank, but the fuel table needs some work, as well as the transient throttle mapping. Once I get some time to spend on that, it will happen.
  12. Mar 7, 2024 at 5:55 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    For you, I really pray that nothing bad happened to your engine. :fingerscrossed:
    yota243[QUOTED] likes this.
  13. Mar 7, 2024 at 5:57 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Any of you guys ever skip a tooth on the steering rack? If so, know a process of how to get it apart to get it back to normal?
  14. Mar 7, 2024 at 7:27 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
  15. Mar 7, 2024 at 8:49 PM
    MadTaco461
    CA
    Kinda stock
    Usually it's an alignment issue to make your steering go off. Believe it's not possible to skip a tooth without having a complete rack failure. I've blown out rack seals before.
  16. Mar 7, 2024 at 9:06 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Mine did, years ago. Time to finally fix it. Came across another guy on the forum mention that he had the same problem. Hit something and it skipped a tooth.
    MadTaco461[QUOTED] likes this.
  17. Mar 7, 2024 at 10:03 PM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2006 Tacoma, 2000 4runner, 1996 Tacoma
    That's got to be a big hit to deflect the rack to get enough tolerance to clear a tooth. Not saying it isn't possible. Maybe it's tundra rack or Howe time. Or consider a slider. Did one on mine and Wow what an improvement.
    MadTaco461 likes this.
  18. Mar 8, 2024 at 7:38 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yeah, was avoiding an accident on the freeway, at night time. Veered off quickly to the exit. Didn't notice the base to a sign that had been missing for who knows how long. Except the base that was concreted into the ground, remained. Right tire hit it, and instantly the steering wheel was off.
    Being that the truck is a street truck, with relatively small tires, the Howe is out of scope. A Tundra rack may be a good option. Which Tundra?
  19. Mar 8, 2024 at 10:15 AM
    Jon64l
    Jon
    Ouch, that'll do it.
    Any chance it's a bent tie rod inner?
    I'm not sure which rack, but there is someone modding them for offroad use. I saw it awhile back but doesn't work with my 1st gen so havnt thought about it until now.
  20. Mar 8, 2024 at 10:28 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Oh no. Not bent. This was 6 or 7 year ago BTW.
    The other reason that I can tell it is off a tooth, is when turning to full lock on one side pops.
    The easiest method would be swapping in a new rack. If I can fix this one, that would be better. I'll have to do some digging.
