Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Mar 17, 2024 at 6:51 PM
    Pinchaser
    Pinchaser Flipper Crazy
    Alan
    2020 Tacoma ECU 04B82 AT
    This. Using a helicoil is stronger than the original threading, with the Helicoil, the bolt tension is spread over a slightly larger area of aluminum; the OD of the helicoil. Take care to drill and tap very straight/perpendicular.
  2. Mar 18, 2024 at 10:20 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    I had a similar thing happen on my aftermarket head, except with the cam bearing cap hardware. Was tightening one down and the bolt kept stretched and almost snapped before I pulled it out to inspect it.
    On my most recent valve job, the threads in the head for some of the cam bearing caps started to let go. Something about aftermarket/remanufactured heads and the metal they're using in the castings.....
    Reh5108[QUOTED] and Torspd like this.
  3. Mar 18, 2024 at 11:58 AM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    If you haven't done a helicoil on Aluminum a few times in your life you aren't doing it right.
    Torspd and Reh5108 like this.
  4. Mar 18, 2024 at 11:59 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    When I was working as a machinist we'd make these huge aluminum drive hubs for a bakery machine and put helicoils in right from the start because they're stronger than just running the bolt into the base material.
  5. Mar 18, 2024 at 12:06 PM
    MadTaco461
    CA
    Kinda stock
    I do inserts too on my designs that see repeat threading. I can only get away without inserts if we do a hard anodize and some course threads.
    Torspd and Speedytech7[QUOTED] like this.
  6. Mar 18, 2024 at 12:08 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    unstpible likes this.
  7. Mar 18, 2024 at 3:40 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
  8. Mar 18, 2024 at 4:14 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yeaaaah. Most in this thread. Lol
    yota243 and Jon64l like this.
  9. Mar 18, 2024 at 4:24 PM
    Speedytech7
    Supercharger whine is okay... But turbos even at their worst never sound like a bad power steering pump :p
    unstpible, yota243 and MadTaco461 like this.
  10. Mar 18, 2024 at 8:50 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    The power steering on the 91 F150 I had:bananadead:
    MadTaco461 likes this.
  11. Mar 21, 2024 at 5:35 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Glad I decided to check valve lash. Had 4 out of spec. Any advantage to leaning towards one side or the other of the factory spec with the turbo? Guessing it won't make much of a difference.
  12. Mar 21, 2024 at 6:29 PM
    unstpible
    Derek
    Cedar City, Utah
    Good question
  13. Mar 21, 2024 at 8:13 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Tight side will give you more run time before needing adjustment. A thou heavy on the tightest tolerance, will give close to maximum lift, plus a little extra expansion room. Since you aren't running a pure race engine, you'll be good.
  14. Mar 21, 2024 at 8:20 PM
    Reh5108
    Idaho
    Maximum lift being good for both exhaust and intake?
  15. Mar 22, 2024 at 4:17 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    "Maximum" is relative to the tolerance of gap.
    Maximum allowed lift. Which in turn leads to a tad more flow.
    Get them all as close to possible, and you'll have more even performance between cylinders.
    Reh5108 likes this.
  16. Mar 23, 2024 at 11:12 AM
    yota243
    E.J.
    north Alabama
  17. Mar 23, 2024 at 1:46 PM
    Reh5108
    Idaho
    Is that all condensation over time?
    yota243 likes this.
  18. Mar 23, 2024 at 1:53 PM
    Speedytech7
    theres no way haha
  19. Mar 23, 2024 at 2:16 PM
    yota243
    E.J.
    north Alabama
    I do live in Alabama and it sat for a year and a half or so...
  20. Mar 23, 2024 at 7:52 PM
    unstpible
    Derek
    Cedar City, Utah
    yota243[QUOTED] likes this.
