Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Jul 6, 2017 at 7:17 PM
    #1761
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    Any of you guys messed with seafoam, thinking of doing the fogging type to try to get ready for the turbo.
    The fogger goes right before the throttle body and sprays in vs the regular seafoam in vacuum line trick
    MrCrowntown likes this.
  2. Jul 6, 2017 at 7:20 PM
    #1762
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Nope. It is abrasive. Through the tank with VP Racing or Redline S1 or both fuel system cleaners. High concentrations to clean off contaminants and injectors, without damaging components.
    Jstand and GreeGunc like this.
  3. Jul 6, 2017 at 7:23 PM
    #1763
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Would it not, in theory, help clean the intake runners though thru the intake or vacuum line that would be missed by hist using in the gas tank?
  4. Jul 6, 2017 at 7:24 PM
    #1764
    GreeGunc
    Jacob
    North GA
    Gotcha, so it says 1 oz per gallon....1st gen holds 18 gallons. So like 20 oz?
    I'll try the redline stuff, maybe couple more oz than called for
  5. Jul 8, 2017 at 8:26 AM
    #1765
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    FPpanchhh and Nickel like this.
  6. Jul 8, 2017 at 12:51 PM
    #1766
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If you aren't living on the edge, then you're taking up too much space.... :eek:
    MadTaco461 and boostedka like this.
  7. Jul 8, 2017 at 1:42 PM
    #1767
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Sounds like a good tattoo
    Nickel and Torspd[QUOTED] like this.
  8. Jul 9, 2017 at 11:20 AM
    #1768
    GreeGunc
    Jacob
    North GA
    I may be canceling the turbo project and just go ls1 if I can figure out if an r154 will work with an adapter so i can use my factory t case
    Been hearing a ticking and my neibor thinks it's lifters or rockers, speeds up with rpms.
    Don't want to destroy a motor
  9. Jul 9, 2017 at 1:35 PM
    #1769
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    I installed mine at 218000 miles. In the cold if I try to take off before worming up it makes a lot of lifter noise that was before the turbo.
  10. Jul 9, 2017 at 1:57 PM
    #1770
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Might need to adjust the loft on the cams. Not hard but time consuming.
  11. Jul 9, 2017 at 3:51 PM
    #1771
    GreeGunc
    Jacob
    North GA
    It does it no matter what
  12. Jul 9, 2017 at 3:52 PM
    #1772
    GreeGunc
    Jacob
    North GA
    I just dont want to tear in the motor for just that, might as well fix it up a bit
  13. Jul 9, 2017 at 5:28 PM
    #1773
    Jstand
    Irving,Tx
    Understand if your not using it already try a 40w or 50w oil
  14. Jul 9, 2017 at 5:47 PM
    #1774
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    0W-40 has a high film strength so it will stay on the bearings under heavy stress. If your pushing even harder try a 5W-40 diesel oil. Most of them are also SN rated these days.
  15. Jul 9, 2017 at 6:00 PM
    #1775
    MadTaco461
    CA
    Kinda stock
    My remanufactured head is super loud. Think it my timing tensioner. Sounds like a diesel. Trying to kill it, but everything else breaks. All my valves are in spec. Plans to build up the oem head anyways when I can get the rest of the truck beefed up first.
    2.7taco likes this.
  16. Jul 9, 2017 at 6:48 PM
    #1776
    GreeGunc
    Jacob
    North GA
    Might try that, just changed the oil this morning
    Might try it
    I am thinking that if I do do it I could throw in a stage 2 or so head with a stage 2 cam and forged 9:5:1 pistons and boost the shit out of it instead of waiting
  17. Jul 10, 2017 at 6:34 AM
    #1777
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Amazon sells Euro spec 5w-40 oil for a decent price.
    Jstand[QUOTED] and GreeGunc like this.
  18. Jul 10, 2017 at 9:39 AM
    #1778
    boostedka
    James
    NM
    I just got the Euro Spec 0w-40 at Walmart the other day. $25 for the 5qt just plus another $6 for the single quart
  19. Jul 10, 2017 at 10:17 AM
    #1779
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Mine says Ferrari on it so its better.
  20. Jul 10, 2017 at 10:39 AM
    #1780
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
