Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Mar 23, 2017 at 1:22 PM
    #161
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    makes me feel like mine are weldporn lol
    Torspd and boostedka like this.
  2. Mar 23, 2017 at 2:06 PM
    #162
    Clay_916
    Clay_916 [OP] Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Hey was your Tacoma a 2rz or 3 before the ls? If it was a 3rz what kind of out of boost response did it have? My goal is to have stock 4.10 gears on 33" tires so I'll have good highway cruising speeds but I'm worried I'll lose too much from the bottom end since I do a fair bit of trail oriented wheeling. I'm wondering if the 3rz does a little better off low engine speeds due to the longer stroke.
    Speed Freek[QUOTED] likes this.
  3. Mar 23, 2017 at 2:42 PM
    #163
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I'm interested to hear about this as well. I'm on 4.88 w 33's and with the turbo it's a bit much sometimes
  4. Mar 23, 2017 at 3:04 PM
    #164
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Those things that give you the O face!
    For gods sake! Was he welding with a 6 volt battery??
    yota243[QUOTED] likes this.
  5. Mar 23, 2017 at 3:07 PM
    #165
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Prolly gonna be running half and half e15 and e85(min e70 according to pump i assume for winter blend) its freaking cheap and with roughly 50% gasoline i should still get plenty of lubrication right? I did get 10 cent off a gal today but still. Looks like e15 has about an 88 octane rating so half and half should still put me in the mid to upper 90's and i would get slightly better mpg than str8 e85 and higher octane than premium
    20170323_160936.jpg still have some work to do tho...
  6. Mar 23, 2017 at 3:07 PM
    #166
    Speed Freek
    Im a 5 lug street truck, not too sure, I ran 3.90 gears on a 27" tires, also a 2RZ. I was making 28 psi so cant really compare. The 3RZ will make more torque due to stroke, but doesnt love too many RPMs so keep that in mind..
  7. Mar 23, 2017 at 3:35 PM
    #167
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    doubt it.
    That's an area were turbos aren't gonna help. No replacement for displacement.
  8. Mar 23, 2017 at 3:38 PM
    #168
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    E85 only. Much safer than e15.
    Lord Helmet and yota243[QUOTED] like this.
  9. Mar 23, 2017 at 3:39 PM
    #169
    yota243
    E.J.
    north Alabama
    Yeah uh autocorrect. :anonymous:
    Brice and Lord Helmet like this.
  10. Mar 23, 2017 at 3:40 PM
    #170
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Damn filled up on BS CA 91 for 2.82 today. Price I pay for spool.
  11. Mar 23, 2017 at 3:46 PM
    #171
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    5 years ago, californians would have killed for that price haha
  12. Mar 23, 2017 at 3:47 PM
    #172
    Blackdawg
    Monte
    Wyoming/St. Louis
    was gonna say..that sounds pretty damn cheap. Similar to Wyo prices.
  13. Mar 23, 2017 at 3:57 PM
    #173
    MadTaco461
    CA
    Kinda stock
    I'm not complaining having 91 under $3.00.
    Truck gets out a lot more around town. When I threw my turbo in gas was around $4.30
    MrCrowntown likes this.
  14. Mar 23, 2017 at 4:04 PM
    #174
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Ouch. 93 octane is 2.50 here. Filled the truck with 19 gallons of regular for 1.94/gal. Drove all the way home with the light on. :rofl: Go across the river and prices are 20+ cents higher.
    MadTaco461[QUOTED] likes this.
  15. Mar 23, 2017 at 4:11 PM
    #175
    MadTaco461
    CA
    Kinda stock
    Get the GM fuel sensor. Be pumping e85 without an issue.
  16. Mar 23, 2017 at 4:12 PM
    #176
    MadTaco461
    CA
    Kinda stock
    Yeah every time I fly to VA for work I'm like if only I could have 93 at your price.
  17. Mar 23, 2017 at 4:16 PM
    #177
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    I know how that is. I was out in NM until I moved out here last year. NM is 91 octane premium. I didn't have my car then, so it didn't effect me. Always seemed weird to me because TX is 93 octane. People told me it was because of the higher altitude in NM.
    Even the regular was different though. NM was like 85 oct. I think it's 87 or 89 here.
  18. Mar 23, 2017 at 4:18 PM
    #178
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    I once told my girl it's a man's version of a hair dryer.
    MadTaco461 and buyobuyo like this.
  19. Mar 23, 2017 at 4:33 PM
    #179
    yota243
    E.J.
    north Alabama
    I got the deatchwerks (however u spell it) pump and the urd injectors and everything was e85 rated so im hoping i wont have any problems
  20. Mar 23, 2017 at 4:47 PM
    #180
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    WIth the GM sensor, you can wire it into your mapecu3 and have separate maps for normal 10% ethanol gas and e85 and it will auto switch maps and adjust based on ethanol content. Also fuel temp if you wire up the fuel temp part of the sensor.
    yota243[QUOTED] and MadTaco461 like this.
