Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Jul 10, 2017 at 10:43 AM
    #1781
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Car and Taco been running on that for a while now.
  2. Jul 10, 2017 at 10:51 AM
    #1782
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    What's the extra quart for?:confused:
    All you guys run a 40 or 50wt with he turbo? :anonymous:
  3. Jul 10, 2017 at 11:09 AM
    #1783
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    5w-40. Just switched from the 5w-30; not much difference that I can tell but I'm sure the bearings are liking the heavier weight.
    What I got: https://www.amazon.com/Pennzoil-550...sr=8-1-fkmr0&keywords=Penzoil+5W-40+Euro+spec
    One thing of note; getting the high pressure radiator cap didn't lower engine temps but when I shut off the engine, even after an extended cool down idle, you could hear the coolant "boil" in the turbo. I don't get that now. Also, if you get the cap, keep an good eye on all your fittings. EVERYTHING leaked and required tightening down all my hose clamps.
    Torspd likes this.
  4. Jul 10, 2017 at 11:13 AM
    #1784
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    I run it on a stock 2.7. It burns oil like no one's business so I changed to 5W-40. It's helped reduce burn off and seems the engine just likes it. Now if I can fix the rest of the engine bugs...
  5. Jul 10, 2017 at 11:20 AM
    #1785
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Blasted little critters....
    2.7taco likes this.
  6. Jul 10, 2017 at 11:25 AM
    #1786
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    You'll probably want new piston rings before putting a turbo on it.
    2.7taco[QUOTED] likes this.
  7. Jul 10, 2017 at 12:38 PM
    #1787
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Oil pan holds 5.5qts
    2.7taco likes this.
  8. Jul 10, 2017 at 12:40 PM
    #1788
    boostedka
    James
    NM
    StAndrew[QUOTED] and MadTaco461 like this.
  9. Jul 10, 2017 at 4:22 PM
    #1789
    2.7taco
    Texas
    Rings, valve guides and seals.
    Really need to pull the engine and do a good once over. New gaskets and seals where possible. Even plasti-gauge the bearings.
    Don't know if I really want to go that route just yet. May just do an engine swap. Only time will tell.
  10. Jul 10, 2017 at 4:23 PM
    #1790
    2.7taco
    Texas
    Them critters done ate stuff.
    Really just need to get the truck back on its feet. I don't drive it much any more.
    Torspd[QUOTED] likes this.
  11. Jul 12, 2017 at 1:59 PM
    #1791
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
  12. Jul 12, 2017 at 4:44 PM
    #1792
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    If your tolerances are sloppy this won't help at all, but try running some Diesel oil in there, Shell Rotella is a favorite among the Subie crowd, the extra additives help with the blow by on your piston rings. Seems to have made a huge difference, especially to the turbo guys.
  13. Jul 12, 2017 at 4:46 PM
    #1793
    Gaunt596
    Matthew
    Central Maryland
    I stumbled across this a while back, it still seems to be in early development, as there's a lot of features it lacking, but it's by far one of the cheapest solutions out there that actually works.
    MrCrowntown[QUOTED] likes this.
  14. Jul 12, 2017 at 4:59 PM
    #1794
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Got to be very careful with using diesel oil. Has to be for both gas and diesel engines. Otherwise it won't last, and will mess up the engine. Regular diesel oil will be broken down more easily by gasoline, that gasoline engine oil.
  15. Jul 12, 2017 at 5:00 PM
    #1795
    Gaunt596
    Matthew
    Central Maryland
    I wasn't aware of that. Need to go lookup that Rotella before I go reccomending it to others.
    boostedka and Torspd[QUOTED] like this.
  16. Jul 12, 2017 at 5:02 PM
    #1796
    Gaunt596
    Matthew
    Central Maryland
    Ah, I see now. I missed a piece. It's specifically the Rotella T6 Multi vehicle, that works for both. Thanks for the heads up on that :thumbsup:
    2.7taco, Nickel, MadTaco461 and 2 others like this.
  17. Jul 12, 2017 at 5:16 PM
    #1797
    MrCrowntown
    Alyn
    Ky
    I would totally rig that up for an engine test stand or something like that
    boostedka likes this.
  18. Jul 12, 2017 at 5:19 PM
    #1798
    Gaunt596
    Matthew
    Central Maryland
    I feel like it's good if you need a low budget, N/A 4 cylinder solution, and it's just getting dd'd or run at track days/autox's where you don't need extra stuff like boost control, launch control etc.
  19. Jul 12, 2017 at 5:24 PM
    #1799
    MrCrowntown
    Alyn
    Ky
    All of those are just settings in a computer program. Whats to say you can't just write the programs to supplement what you're asking it to do?
    obviously you have to be good at writing code, and being 1337 haxorz tho :ballchain:
  20. Jul 12, 2017 at 5:26 PM
    #1800
    Gaunt596
    Matthew
    Central Maryland
    Yeah, I'm looking at it from the standpoint of "I can't code worth a damn, so I'm stuck with what it comes out of the box" with the upside of additional features being added over time as it's developed. Plus, it being open spirce, there will probably be a bunch of little scripts released to add little odds and ends features.
