Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Jul 14, 2025 at 6:20 PM
    Pinchaser
    Pinchaser Flipper Crazy
    Alan
    2020 Tacoma ECU 04B82 AT
    Does the target boost have any influence on spring pressures? I would not think so. Cam lift and Max. RPM would be what I expect influence spring pressure needs. Consult your camshaft specs or manufacturer.
  2. Jul 14, 2025 at 11:37 PM
    Dirty Dude
    Dirty Dude Well-Known Member
    2004 Tacoma SR5 Xtra cab 5-lug
    Dirt, miles, and wear.
    Boost does influence spring choice because there's pressure on the back of the valve effectively canceling some of the spring force that would otherwise be available to close the valve. 20psi on the back of a 38mm valve is about 35lbs of force.
    Pinchaser likes this.
  3. Jul 14, 2025 at 11:41 PM
    Dirty Dude
    I think that may be a wholesale price because it's similar to what I saw on Aliexpress for orders with a minimum quantity.
  4. Jul 15, 2025 at 4:51 PM
    Pinchaser
    Alan
    Of course, makes sense, is pressure on back of both the intake and the exhaust. Not sure how long it might have taken me ot realize that, but Of Course.
    Dirty Dude[QUOTED] likes this.
  5. Jul 18, 2025 at 4:46 AM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    You can run off spring alone if no boost reference is added to the wastegate. Would be trial and error to dial it in unless someone has the same WG and runs same boost as your target.
  6. Jul 25, 2025 at 7:10 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Gentlemen, I’m about to do a parts dump on the forum and I’ll list items I think are of interests here before I put them on the sale board.
    First up was a proof of concept G10 spacer to stop plenum heat soak. 2TR-FE of course. I didn’t bother to put the factory oring grooves in it, that was going to be added if I mass produced it, it was RTV in place and performed so well I didn’t bother making another.
    I’d like to get $200 shipped
    Torspd likes this.
  7. Jul 25, 2025 at 7:14 PM
    05Taco4x4
    2TR-FE Enthusiast
    Turbosmart Oil Pressure Regulator & Gauge
    $120 shipped NEW
  8. Jul 25, 2025 at 7:36 PM
    05Taco4x4
    2TR-FE Enthusiast
    It brakes my heart I didn’t install this.
    R155 5th gear is 0.8:1 for 20% overdrive
    This 5th gear set is from another Toyota R trans, is 0.694:1 for 30% overdrive.
    Sounds crazy unless you’re turbo charged on 4.10s+
    I’ll need $400 for this. It cost more than this to buy it, had to import from Japan. Last I checked at least 2 of the parts aren’t available anymore. I broke my trans down twice to measure and then verify fitment but was before I installed the turbo. I never felt like dropping it to install after the turbo and always thought I’d get around to it.
    Jon64l likes this.
  9. Jul 25, 2025 at 7:51 PM
    Dirty Dude
    Damn, and I thought Tremec parts were expensive.
  10. Jul 25, 2025 at 7:53 PM
    05Taco4x4
    2TR-FE Enthusiast
    Hi output Hitachi COPs 2TR-FE
    Should be running Haltech etc to get most out of these, I will provide calibration.
    I had tried the R35 COPs but was not happy with fit, as they have different orientation (I had made a conversion bracket). Stalk is from another vehicle, too much time spent and dollars wasted finding one that worked. Direct mount, no conversion bracket needed. Plug-n-play harnesses.
    $150 $100 shipped
    Torspd and Jon64l like this.
  11. Jul 25, 2025 at 8:00 PM
    05Taco4x4
    2TR-FE Enthusiast
    One item of your choice with purchase, or if anyone needs just lmk. I’ve got a box of misc parts I wish I could just give someone, new fittings and weld bungs etc, but too much a bother
  12. Jul 27, 2025 at 7:58 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  13. Jul 27, 2025 at 7:59 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Curious if these would work on the 1GR?
  14. Jul 27, 2025 at 10:32 AM
    05Taco4x4
    2TR-FE Enthusiast
    IDK
    Would need to measure mount hole distance, length of stalk and compare wiring.
    Are the 1GR mount hole at right angle to body, like these, or in line?
  15. Jul 27, 2025 at 1:22 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Negative, they are 180° from the harness plugs.
  16. Jul 27, 2025 at 7:37 PM
    05Taco4x4
    2TR-FE Enthusiast
    Like these R35?
    Torspd[QUOTED] likes this.
  17. Jul 27, 2025 at 8:00 PM
    05Taco4x4
    2TR-FE Enthusiast
    Also up is the PICOSCOPE I used to find calibration, would like $100 for it so $120 shipped
    Torspd likes this.
  18. Jul 28, 2025 at 8:10 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Correct
  19. Jul 28, 2025 at 8:14 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    How much for those? Just curious.
  20. Jul 28, 2025 at 5:12 PM
    05Taco4x4
    2TR-FE Enthusiast
    I’ll take $100 for either set
