Turbo Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jcyr, Apr 24, 2017.
  1. Jun 18, 2018 at 6:34 PM
    #201
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    I have no idea what that is, but it sounds good
    mach1man001 and Jcyr[OP] like this.
  2. Jun 22, 2018 at 7:41 AM
    #202
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Hey man! Finally joined the party in here! :cheers:
    My question/observation, is for the vacuum hose that I see, routed from the compressor housing to the BOV. Do you still have it like that or have you changed its sourcing?
  3. Jun 22, 2018 at 7:48 AM
    #203
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Also, have you fired up that Haltech yet, and fiddled around?
  4. Jun 22, 2018 at 8:00 AM
    #204
    Jcyr
    Jcyr [OP] Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Where should I source the bov? The TB? I thought you wanted the waste gate and bov sourced from the housing? Enlighten me... lol.. and no I haven’t fired up the haltech yet I still need to boost refrence it along with melt in some sensor bungs. I’m still trying to figure out how to tie in my haltech afr sensor and the wb1 system for it to the ecu
  5. Jun 22, 2018 at 8:02 AM
    #205
    Jcyr
    Jack
    North east
    Haltech installed mostly and attached my harness in the glove box2A29ECD4-AC64-49B1-8E41-40BC3B711C4A.jpg 637BC422-7BB8-4CE8-AFBB-B85E8D0A9BAE.jpg
    jjsul likes this.
  6. Jun 22, 2018 at 8:24 AM
    #206
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    BOV from a vacuum/boost source. Typically post TB. I believe that @boostedka knows which TB port does both.
    The wastegate, can go from the compressor cover. However, the pressure drop between the outlet of the compressor to the intake manifold can be anywhere from 1psi to 5psi(worst case obviously). Referenced against your spring rating and altitude, you may notice that not enough boost is being made. Thus moving to a source closer to or from the manifold would be necessary to match the springs rating.
  7. Jun 22, 2018 at 8:27 AM
    #207
    Jcyr
    Jack
    North east
    So do you just typically plug the housing outlet??
  8. Jun 22, 2018 at 8:30 AM
    #208
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Prior to turning it on, create an ESP account with Haltech. That way you can update the the firmware to the most current version, as well as the ESP software. Do the both of those when the laptop is physically connected to the Haltech and the Haltech tuning is connected.
    As for the Haltech. @arcenik has his file in the turbo BS thread, if you haven’t downloaded it already. At least for a point of reference.
  9. Jun 22, 2018 at 8:31 AM
    #209
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yup. It just depends though. Compressor port to wastegate port. If boost is lower than expected, then put a nipple on the charge pipe near the TB, or find a vacuum port post TB.
    Jcyr[QUOTED][OP] likes this.
  10. Jun 22, 2018 at 8:36 AM
    #210
    Jcyr
    Jack
    North east
    yeah i think I definitely have a big task ahead of me! Lol
  11. Jun 22, 2018 at 8:58 AM
    #211
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It is not as daunting as it seems.
    Jcyr[OP] likes this.
  12. Jun 22, 2018 at 11:27 AM
    #212
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I hooked up my BOV to the front of the intake manifold. The ports on the top of the TB did not pull nearly enough vac to open up the BOV when letting off the throttle. There was an unused port on the front of the intake mani that had a bolt capping it off. I replaced that cap with a threaded nipple to connect the BOV to.
    I also did that on the back of the mani as well to use for the boost gauge and FPR.
    For the WG, I just hooked it up to the port on the turbo'd compressor housing. I didn't have any issues running it this way. It definitely makes for a different (higher) reading than you'd get at the manifold, but I figure that could be a bit of a safety feature too in that you're motor is seeing slight less boost than your WG is. IDK if that logic makes sense but it worked for my set up.
    This video kind of shows the WG connection as well as the BOV connection. (I later swapped back to the TurboSmart BOV, but hooked it up the same way)
    Here's the Back of the Mani:
    Jcyr[OP], Torspd and 05Taco4x4 like this.
  13. Jun 22, 2018 at 12:12 PM
    #213
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    Do
    Did you get the Haltech WB1? it should be a CAN connection to the Haltech ECU, I think I did have to buy or convert the plug, as the Widebands have not been updated to the new CAN connection.
  14. Jun 22, 2018 at 4:20 PM
    #214
    Jcyr
    Jack
    North east
    Yes i did but it looks though the elite 500 only had one big plug then where the computer wouldn’t hook up
  15. Jun 22, 2018 at 4:22 PM
    #215
    Jcyr
    Jack
    North east
    Great pictures thank you
    boostedka[QUOTED] likes this.
  16. Jun 22, 2018 at 4:50 PM
    #216
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    So......how does it drive?
  17. Jun 22, 2018 at 5:23 PM
    #217
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    Looks like the 550 only has the Can wiring in the harness you just need to wire it in to the Can high, low and power and ground. 4 wires not that hard to do.
    Torspd likes this.
  18. Jun 22, 2018 at 5:49 PM
    #218
    boostedka
    James
    NM
    Ran great. Sounded and ran just like stock until it hit boost. Then it pulled pretty decent. It added about 80 wheel hp
    COMAtized99[QUOTED] likes this.
  19. Jun 22, 2018 at 6:17 PM
    #219
    COMAtized99
    North Carolina
    99 DCLB v8
    It's already been on a Dyno? What was the HP at the wheels? I know togoTo rated the 3rz 155hp/177tq, but those are crank numbers. What Rpm does boost start coming on, and what is peak boost?
    Btw, OP, truck looks awesome also
  20. Jun 22, 2018 at 7:06 PM
    #220
    Jcyr
    Jack
    North east
    Thanks it’s getting close thanks to the helpful guys in the turbo thread
