Turboing 96 tacoma?
Discussion in 'Performance and Tuning' started by vipr2165, Apr 8, 2015.
  1. Apr 8, 2015 at 8:29 PM
    vipr2165
    vipr2165 [OP] New Member
    Riverside, CA
    96 Tacoma 4x4
    Hey guys and gals,
    wanted to know what would go into turbo charging my 96 tacoma 4x4 6cyl (335k miles, still ruuning strong though) what i would need to do, what could go wrong, and what it would cost?
  2. Apr 9, 2015 at 4:53 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Do a compression test, to make sure all is well and that the cylinders are all within close proximity to each other.
    Speak with www.lceperformance.com. They have a lot of good knowledge to share.
    If you do decide to use the CX Racing kit, then do get their Chinese brand turbo. Save up and get something which is quality made, American. Even used is ok. Just my opinion on the turbo.
    The member StAndrew is doing the process of the turbo kit install still. His build thread can also shed some light on this subject.
  3. Apr 9, 2015 at 4:58 AM
    Clearwater Bill
    Billy
    Largo Florida
    Be sure a leakdown test is part of the compression test. And send an oil sample to Blackstone for an evaluation of the engine from that perspective.
    I don't know cost on this marquee, but in another area I'm fairly familiar with, $3k for a proper set up would be minimal. Engine management is not to be overlooked, and it's not always cheap.
    Worst that could happen. Well come on. You know the worst. Do it wrong and pop the motor.
  4. Apr 9, 2015 at 1:40 PM
    Clearwater Bill
    Billy
    Largo Florida
    another thought. What is the purpose? Sure, more power, but when and for what application.
    Sometimes a supercharger is a better choice.
    Just depends on how you expect to use the power.
  5. Apr 10, 2015 at 2:38 AM
    Cruzintaco
    Cruzintaco Well-Known Member
    Sanjose
    2001 PreRunner TRD
    K&N drop in filter EGR Silencer Delete More MODS soon to come!
    I agree, whats it for.. however the supercharger runs constantly. I mean so does the Turbo but you could boost it when you need it. But thats just my opinion. Dont get me wrong theyre both great things to have but its just one of those things where its a pro/con
  6. Apr 10, 2015 at 5:13 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
