Turkey hunting and BS welcome!
Discussion in 'Guns & Hunting' started by wilcam47, Mar 23, 2017.
  1. May 4, 2024 at 6:33 AM
    #1741
    dklehman
    dklehman Well-Known Member
    Darin
    Eastern wa
    2021 TRD off road
    Nice those birds always look so beautiful.
    wilcam47[OP], lynyrd3 and THatt like this.
  2. May 4, 2024 at 9:05 AM
    #1742
    THatt
    THatt Well-Known Member
    Upstate SC
    1996 Tacoma 2.7L MT 4X4
  3. May 4, 2024 at 5:56 PM
    #1743
    lynyrd3
    Bill
    East Central Upstate NY
    Turkey roaming around a friends house a few miles away from here . It is with a couple normal hens and a Tom .
    4x4spiegel, THatt, Harry2015 and 2 others like this.
  4. May 5, 2024 at 12:01 PM
    #1744
    THatt
    Upstate SC
    It's about over here so I am back to tinkering. My 20 gauge 1187 was purchased when Remington was really suffering QA issues some years back right before they went under. I even called them about the first barrel and they sent me a replacement with no questions asked. Unfortunately, both barrels were rough as a cob inside with bad tool marks. I polished them up as best I could, patterned to get average 150-160 in 10" with TSS and hunted it some. The last few years I've hunted it exclusively, light, maneuverable and a pleasure to carry. Still, the patterns were well below what other friends get with similar factory loads. So, I broke down and bought a bore gauge and a honing set. Found I had .001-.002" variation, high spots, in several spots in the barrel. Worked those with the hone and then followed up with a light polish job just this weekend. Shot a few shells today and am pleased with the improvement. This is about where I want to be, no need to go any further. Appears to have helped pull some pellets in for a denser core and 20". Could have bought another gun I guess, but Lord knows I need another shotgun.
    Before with TSS Browning #7&9s and Remington #7s:
    After with same loads:
    tacomaboned, wilcam47[OP] and lynyrd3 like this.
  5. May 5, 2024 at 4:19 PM
    #1745
    dklehman
    Darin
    Eastern wa
    2021 TRD off road
    That pattern looks pretty good to me. What choke are you using?
    lynyrd3 likes this.
  6. May 6, 2024 at 3:12 AM
    #1746
    THatt
    Upstate SC
    That’s a trulock .565
    lynyrd3 likes this.
  7. May 6, 2024 at 5:34 AM
    #1747
    dklehman
    Darin
    Eastern wa
    2021 TRD off road
    I run a .585 trulock on my retay 20 it is a inertia driven semi auto benelli knock off. It has the same issue most of the 20 Guage inertia driven guns have including benelli it does not consistently cycle 3 inch turkey loads. My gun will cycle every other 3 inch shell I put in it. I bought every 3 inch 20 Guage shell sportsman's and cabelas had last summer not a single hang up, first turkey load after 30ish different 3 inch rounds hung up. So after some research I find that this is a pretty well documented issue with the inertia guns. So I start reaching out on some of the forums and find that most of the guys running these guns hand load so they can trim there shells down and still shoot TSS. So after about 8 months trying to procure all the components I loaded my own this spring. The good news is the gun has cycles flawless with these loads and the patterns are amazing. The bad news is it was expensive getting an the stuff I didn't have to do the loading. The actual shells I can load for 3ish bucks a piece. The rest of the reloading stuff in into for around 250. The one thing I found that shocked me was how inconsistent the top of the line factory load weights were. So I got done with 10 shells and weighed them they were 59.08 to 60. 05 I was a little miffed how there was that much difference so I threw some of the apex loads on and they went from 61.14 to 63.33. The reality is I don't care that much as long as turkeys fall over when I pull the trigger. I should have just stuck with my old pump Acton 12 but as I get older I really don't like to carry that much gun across hells half acre.
    lynyrd3 likes this.
  8. May 6, 2024 at 6:26 AM
    #1748
    THatt
    Upstate SC
    I should be hand loading. I grew up with Remington so maybe that explains my efforts to improve the last one I bought. I have a .585 and may try it again. Previous patterning with it just threw more open patterns. The bore is now .616 as best I can tell, still a little unevenness but less than .001. May be able to level it further when I have more time. Am convinced it’s better now.
    I had a jam with my 12 gauge Franchi a couple years ago, did not cycle federal tss loads. Friend found the same with his 20 gauge Franchi and federal tss load. We both had patterned only firing one shell at a time. The failure to cycle came at a bad time. Those federal shells for both gauges are a little longer with that roll crimp. All other loads cycled fine. I was under the impression it was a dimensional issue rather than the inertia action. My franchi 12 ga is my go to duck gun and will eat any magnum duck load fine, all regular crimp.
    lynyrd3 likes this.
  9. May 7, 2024 at 1:38 PM
    #1749
    lynyrd3
    Bill
    Tagged out today
    18 pounds
    9” beard
    1” spurs
    bjohn041, THatt, Harry2015 and 2 others like this.
  10. May 7, 2024 at 1:42 PM
    #1750
    dklehman
    Darin
    Eastern wa
    2021 TRD off road
    Great bird congratulations
    lynyrd3 and wilcam47[OP] like this.
  11. May 7, 2024 at 7:01 PM
    #1751
    wilcam47
    wilcam47 [OP] Keep on keeping on!
    Will
    Bourbon state
    Nice! Congrats!
    lynyrd3[QUOTED] likes this.
  12. May 8, 2024 at 3:08 AM
    #1752
    lynyrd3
    Bill
    Thanks :fistbump:
  13. May 8, 2024 at 3:08 AM
    #1753
    lynyrd3
    Bill
    Thanks Darin :fistbump:
  14. May 8, 2024 at 3:54 AM
    #1754
    THatt
    Upstate SC
    Congrats!
    lynyrd3 likes this.
  15. May 8, 2024 at 3:59 AM
    #1755
    lynyrd3
    Bill
    Thanks :fistbump:
  16. May 8, 2024 at 6:33 AM
    #1756
    ole
    ole unproductive
    Rock County Wisconsin
    2025 Tacoma SR Double Cab
    530 am. 16 1/2 lbs. 6 1/2 inch beard
    4 came in to my decoy 3 walked away
    19 yards
    Harry2015, THatt, Wyle1 and 2 others like this.
  17. May 8, 2024 at 6:54 AM
    #1757
    dklehman
    Darin
    Eastern wa
    2021 TRD off road
    Nice congratulations
  18. May 8, 2024 at 7:25 AM
    #1758
    lynyrd3
    Bill
    Congrats
    wilcam47[OP] likes this.
  19. May 8, 2024 at 7:40 AM
    #1759
    wilcam47
    Will
    Bourbon state
    Nice congrats!
    lynyrd3 likes this.
  20. May 9, 2024 at 2:32 PM
    #1760
    THatt
    Upstate SC
    You know what's bad? No tags and hearing turkeys roost gobbling from the driveway and no dang gunner to take after them.
