Turn off your TPMS light FOREVER!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mach375, Feb 18, 2015.
  1. Jun 11, 2021 at 11:25 AM
    #141
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    For about $20 each you can replace the sensors when getting new tires mounted and keep the TPMS light off for about 10 more years. Works out to about the same cost as a McDonalds value meal once a year. Why is this an issue?
    And the sensors aren't designed to monitor air pressure for you, that is still done with an air gauge just like it has always been done. TPMS is to warn you of a sudden tire deflation while driving. My 2007 Tacoma is the 1st vehicle I owned with TPMS and I like it. Twice since buying the truck I ran over debris in the road that punctured tires. The light came on both times and gave me 10-15 seconds to get off the road and stopped before the tire came apart at 70 mph. That is what they are designed for.
    TyBud850 likes this.
  2. Nov 30, 2021 at 12:00 PM
    #142
    wisco kid
    wisco kid Member
    2009 Tacoma TRD Access Cab
    I suppose a square of electrical tape over the light would work well too.
  3. Nov 30, 2021 at 12:04 PM
    #143
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    :facepalm:
    No.
    wisco kid[QUOTED] likes this.
  4. Nov 30, 2021 at 12:12 PM
    #144
    llamasmurf
    Wes
    Northern Ontario
  5. Dec 1, 2021 at 5:58 PM
    #145
    wisco kid
    wisco kid Member
    But isn't this, in essence, what disabling the light is doing?
  6. Dec 1, 2021 at 7:08 PM
    #146
    Taco 422
    Taco 422 Well-Known Member
    USA
    Gen 2 AC v6 TRD SR5 Prerunner
    This is the solution to the problem I've faced. Thank you.
  7. Dec 2, 2021 at 5:58 AM
    #147
    llamasmurf
    Wes
    Northern Ontario
    Not in my eyes. You will always know there is just a piece of tape there. At night is the light going to leak around the outside after 2 years and the tape starts to dry out?
    Tape, where I live does not last long, 30C+ in the summer, -40C in the winter.
    :bananadead:
    :militarypress:
    I like doing things a little more, permanently.
    Taco 422 likes this.
  8. Dec 2, 2021 at 6:11 AM
    #148
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    It's so much easer to just ignore it! My winter tires have no sensors I don't loose a bit sleep.
  9. Dec 2, 2021 at 7:17 AM
    #149
    wisco kid
    wisco kid Member
    Good points!
  10. Dec 2, 2021 at 9:33 AM
    #150
    Sarra
    Sarra Well-Known Member
    2007 TRD Off Road 4.0 6MT
    None yet
    Well, this is more simple than finding the TPMS +voltage wire in the wiring to the cluster, and cutting it...
    Taco_Addict666 likes this.
  11. Sep 20, 2024 at 4:11 AM
    #151
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
  12. Sep 23, 2024 at 8:44 PM
    #152
    Williston
    Williston Well-Known Unknown Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a couple of non-OEM nods.M mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    ^^^This^^^
    I have had three cars now with this monitor. One would display the actual tire having the problem (with actual pressure showing) and the others just turned on a warning light. In all cases it was a either a nail, screw, rim leak or a valve stem. It turned on a light or screen display and warned me well before a flat. It was never wrong.
    :pccoffee:
  13. Sep 23, 2024 at 8:49 PM
    #153
    Woofer2609
    Woofer2609 Getting better all the time.
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    Taking the gauge panel out and removing the TPMS bulb took all of 15 minutes, just works, and is easily reversed. Worked like a charm in my 09.
    t1m829 likes this.
  14. Sep 24, 2024 at 8:20 PM
    #154
    TyBud850
    TyBud850 Well-Known Member
    Tyler
    Defuniak Springs, Florida (NWFL)
    2012 Black Tacoma DC TRD-OR
    3” lift Icon 2.5 shocks king 650 coils, ALCAN LP W/Sumo springs & FOX 2.0, CBI MOAB 2.0 Front Bumper w/Smittybilt X20 10K winch, CBI Rock Sliders, Mobtown Reinforced Steel Skids & Bed Bars, CBI rear bumper,
    What about those with 2 sets of tires? TPMS isn't really necessary.
  15. Sep 25, 2024 at 7:38 AM
    #155
    Rickman1
    Rickman1 Member
    Rick
    Arizona
    2006 Speedway Blue TRD Sport Prerunner
    My truck's TPMS also includes the spare tire. When I purchased the truck the TPMS light was on. I aired up the 4 tires to 32psi but still had the TPMS light on. Thought I had a bad sensor. Checked the spare tire (which I check maybe once a year anyway) and it was about 13psi low. Aired it up to 32psi and the TPMS went out. I will be keeping my TPMS sytem functioning to let me know that my spare tire is sufficiently aired up if I need to use it.
  16. Sep 25, 2024 at 5:42 PM
    #156
    Woofer2609
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    That's why I removed my light bulb from the gauge cluster.
    TyBud850[QUOTED] likes this.
