Turn Signal does not work
Discussion in 'Lighting' started by FooD2000, Dec 13, 2010.
  1. Dec 13, 2010 at 5:26 PM
    FooD2000
    FooD2000 [OP] Member
    1996 Tacoma, I did a radio install (blew 1 fuse to dome light) but after, my signals don't work:
    - My hazards work (the arrows light up as well)
    - Checked fuses both place inside the car and under hood
    - I've switch the other relays and found no change.
    - replaced flasher (part #ep 35 from autozone).
    - bought a used junk yard turn signal switch
    - i've also pulled my radio to look for exposed wires, looked fine from what i could tell.
    Any Suggestions or ideas?
    Thanks!
  2. Dec 15, 2010 at 8:52 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    A blown 15A HORN fuse might explain it ...
  3. Dec 15, 2010 at 3:37 PM
    FooD2000
    Yea i triple checked the fuses, all of them are good (under the dash and hood) and i've also switch the relays around and nothing changes so they're good.
    I checked out the wires and i don't think i have any shorting anywhere?
    ONly think i can think of is the turn signal switch which is weird that it'd go bad after the radio install...
  4. Dec 29, 2010 at 7:12 PM
    FooD2000
    So i went to the junk yard and replaced the turn signal switch, still no turn signals and i went back into the radio to make sure no wire is exposed or loose wires grounding out.
    also tried replacing the flasher underneath the dash (ep 35 part from autozone).
    Any ideas?
