Turn signal/hazard flasher
Discussion in '1st Gen. Tacomas (1995-2004)' started by crazyasu45, Apr 30, 2010.
  1. Apr 30, 2010 at 12:24 PM
    crazyasu45
    crazyasu45 [OP] Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    Where is the relay flasher unit located :confused: pics would be great...Thx Matt
  2. Apr 30, 2010 at 12:36 PM
    98tacoma27
    Ben
    Not Beech Creek
  3. Apr 30, 2010 at 12:37 PM
    98tacoma27
    Ben
    Not Beech Creek
  4. Apr 30, 2010 at 12:39 PM
    98tacoma27
    Ben
    Not Beech Creek
  5. Apr 30, 2010 at 12:48 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    Thx!!! :d
  6. Apr 30, 2010 at 12:51 PM
    98tacoma27
    Ben
    Not Beech Creek
  7. May 8, 2010 at 8:42 AM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    So I replaced the original flasher with a Tridion...same problem...right blinker works everytime...left one is intermitent...I can hear the flasher working...but no green arrow flashing on the instrument panel...an no the bulb isnt burnt out...pls help :eek:
  8. May 10, 2010 at 3:31 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
  9. May 11, 2010 at 10:49 AM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    Bump...bump...
  10. May 11, 2010 at 11:05 AM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    Is it that the turn signal bulb outside is flashing but just the dash arrow isn't?
  11. May 11, 2010 at 11:14 AM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    Nope...The turn sigal bulb outside flashes only when the green arrow inside flashes...
  12. May 11, 2010 at 11:20 AM
    HerNameIsLucy
    RIP Lucy.
    Not being sarcastic here, but the bulb for the turn indicator in the instrument cluster burnt out? I don't think they're LED but I may be wrong there, never looked at a 98.
    This might help (sorry for linking to a different forum): http://www.customtacos.com/tech/index.php?article=77
  13. May 11, 2010 at 12:01 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    Thx I appreciate any help I can get right now...This turn signal issue is driving me crazy...Haha...Anyways the turn signal bulb still works fine...It just flashes sometimes and sometimes doesn't...But I can still hear the relay flasher working...When the green arrow on the instrument panel lights up and flashes...The outside signal works...When it doesnt flash inside...The outside signal doesn't work...I hope this it this a little clearer...:D
  14. May 11, 2010 at 12:40 PM
    crimsonred2004
    crimsonred2004 X-wing Design Engineer
    Bob'O'
    MI
    02 Limited TRD Xtracab V6 4X4
    sounds like a loose wire on the relay base....i would check the wiring....you either have a loose wire or a intermittent ground in the wiring loop to the bulbs
  15. May 11, 2010 at 12:46 PM
    HerNameIsLucy
    RIP Lucy.
    Yup, agree with crimsonred...my shot would be a bad ground somewhere in the circuit. Maybe turn the blinker on and gently wiggle wires under the dash, and where they come out of the turns and into the wiring harness. See if you can make it work / not work.
  16. May 11, 2010 at 12:52 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    Thx I'll give it a shot...so u guys don't think it could be a defective flasher unit i picked up?
  17. Dec 21, 2010 at 10:46 AM
    MadeInMaine
    MadeInMaine MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    hey guys...
    i put LED lights in the signal flashers, switched the flasher relay for a LED relay (to slow the flashing) and now I keep blowing the signal fuse..
    you guys know whats going on?
  18. Feb 15, 2011 at 8:14 PM
    JayARRGHH
    JayARRGHH Well-Known Member
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    285/75/R16 Eldarado MTZ, Alpine CDE-102 Deck, DIY Snorkel, 2" Spacer Lift, Uniden Bearcat 880 CB, Custom over head console w/ map lights, CB Mount, and external CB speaker, 2 12" Kenwood Subwoofers, 300 Watt Alpine Amp, Alpine 3" lift 500# capacity
    its 100% a ground thing, i did the same thing as OP, changed the relay and everything and it worked for a while, then i fucked around in the taillight for some extra reverse lights and it started again, while trying to put the taillight back in i wiggled some wires and it would occasionally work. I have no idea which wire is the ground one because there are like 7000 wires in there and I have a tow package so the trailer control wires are all shoved in there too, anyone have any ideas as to where the ground fault could be??
    p.s.
    sorry to bring up an old thread but i need to fix this :/
  19. Feb 16, 2011 at 6:23 AM
    MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    Don't be sorry at all...
    I am going to switch out my flasher relay for the LED one, then one at a time, put in the LED signal lights, and if it works, awesome,
    if not, ill put in a new fuse, then turn the LED around, and try again.
    Ill keep people posted
  20. Jul 19, 2011 at 7:58 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    I agree with 99Taco..check your switch..the contacts may be dirty or super worn.
    You can pick up a switch from a junkyard or pick n pull for $10-20
