TW Acronyms
Discussion in 'New Members' started by TacoGlenn, Oct 14, 2014.
  1. Oct 14, 2014 at 12:44 PM
    TacoGlenn
    TacoGlenn [OP] Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
    IMO TW UTMA, ACS IBVW A NOPW BESAW LOWSCREP FUGER MYCOM; STREP TROP VERPY XEMO. FTMFW!
    Gibberish, or a TW post from 2050? As TW appears to be fully engaged in this world of ever increasing acronymic crypto-speak, new TW forum members may encounter some acronyms and finding themselves saying WTF? I am providing a supplemental acronym glossary geared specifically to TW, I will also include slang and truncated neowords. Many newly encountered acronyms can be deciphered by context or by backtracking through threads, others require a little more digging. An attempt will be made to provide the most TW-context correct answer. For example, when I first tried to decipher “RTT”, one online acronym dictionary provided no less than 31 different possibilities, with none being the correct answer as used on TW- roof top tent.
    I will be updating.
    TW Acronyms
    AAL - add a leaf
    ABS - anti-lock brake system
    AC - air conditioner (OR access cab)
    ACFTMFW -access cab for the motherf*cking win
    ADD - Automatic Disconnecting Differential (system)
    AFAIK - as far as I know
    AFR (A/F sensor) – air to fuel ratio (air/fuel sensor)
    AT - Automatic Transmission
    AWD - all wheel drive
    BA - brake assist
    BBP - blazing blue pearl (color)
    BCM - blue crush metallic (color)
    beavis'd - mishandle a situation or screw something up
    BFE – butt fu*k Egypt
    BFH - big f*cking hammer
    BHG - blown head gasket
    BHLM - blackout headlight mod
    BITOG - Bob is the Oil Guy (forum) http://www.bobistheoilguy.com/
    BTDT - been there, done that
    BTW - by the way
    CAI - cold air intake system
    CAT - catalytic converter
    CC - cruise control
    CCN - care car nut The Car Care Nut - YouTube
    CEL - check engine light
    CF - carbon fiber
    CL – Craig's List
    CPS - crank position sensor
    CRC - corrosive resistant compound
    CTS - coolant temperature sensor
    CV(J) - constant velocity (joint)
    DA - dual action (polisher)
    DCLB - double cab long bed
    DCSB - double cab short bed
    DCSBFTMFW – double cab short bed for the motherf*cking win
    DD - daily driver (your everyday vehicle)
    derp - plasti dip
    DGAF - don't give a f*ck
    DIY – do it yourself
    DRL - daytime running lights
    DTC - diagnostic trouble code
    EAD - engine and alert display
    EBD - electronic brake (force) distribution
    EBH - engine block heater
    ECGS - East Coast Gear Supply East Coast Gear Supply
    ECM - engine control module
    ECU – electronic-(ally) (engine) control unit
    EGR - exhaust gas recirculation (valve)
    FAQ - frequently asked questions
    FFG - full flat ground (knife)
    FI - fuel injection
    FIC - fuel injection cleaner
    FIFY - fixed it for you
    FIPG - formed in place gasket
    FIPK - fuel injection performance kit
    FLT – filter,flight, flat (yes, I've actually seen “flt” for flat, with only one letter differential, this is the most un-economical acronym seen to date)
    FML - f*ck my life
    FPV - first-person view
    FS - for sale
    FS/FT - for sale and/or for trade
    FSM - factory service manual
    FTW - for the win
    FTMFW - for the motherf*king win
    FWIW - for what it's worth
    GGDRS - Grandpa-Gearhead Driver Rating System http://www.tacomaworld.com/forum/pe...-1-10-driver-rating-system-mpg-reporting.html
    GHB - get home bag
    GLWS - good luck with sale
    GTFO - get the f*ck out
    GVWR - gross vehicle weight rating
    HG - head gasket
    HID - high-intensity discharge (head lamps)
    HPFP - high pressure fuel pump
    HTF – how the f*ck
    HU – head unit
    IACV - idle air control valve
    IAT - intake air temperature
    IBTL - in before the lock (thread lock)
    IDGAF - I don't give a f*ck
    IDK - I don't know
    IFS - independent front suspension
    IIRC - if I recall correctly
    IMO - in my opinion
    IMHO - in my honest (humble) opinion
    IPA - isopropyl alcohol
    IRS - independent rear suspension
    ISO - in search of
    jelus – “Did you lose”
    J/K - just kidding
    LBJ - lower ball joint
    LCA - lower control arm
    LEO – law enforcement officer
    LMAO - laughing my ass off
    LMFAO - laughing my f*cking ass off
    LOP – land owner preference
    LP - license plate
    LSC - limited service campaign
    LSPV - load sensing proportioning valve
    LT - long travel
    LTSU - lube that shit up
    MA - mechanical advantage
    MAF - mass air flow (sensor)
    MC - mall crawler
    MDF - medium-density fibreboard
    MGM - magnetic gray metallic (color)
    MGMDCLBFTMFW - magnetic grey metallic double cab long bed for the motherf*cking win (reigning TW acronym champ with 12 characters)
    MIL - malfunction indicator light
    MOAB - mother of all baskets (cargo baskets; also used for Moab, UT)
    MT - Manual Transmission (OR mid travel)
    NBD - no big deal
    NFC - no f*cking clue
    NVH - noise, vibration, & harshness
    NVM - nevermind
    OBA - on board air (compressor)
    OBD - on-board diagnostics
    OBO - or best offer
    OCI - oil change interval
    OEM - original equipment manufacturer
    OP - original post (or poster)
    OR - off road
    OTD - out the door (price)
    OYG - off you go
    PCM - powertrain control module
    PCV - positive crankcase ventilation (valve)
    PDR - paintless dent repair (removal) http://auto.howstuffworks.com/paintless-dent-removal.htm
    PEA - polyether amines (compounds in fuel system cleaners)
    PITA - pain in the ass
    PM - private message
    POS - piece of shit
    PPE - personal protective equipment
    PPI - pre-purchase inspection
    PWM - pulse-width modulation (valve) (also know as VSV)
    QS - quicksand (color)
    rattle cans – spray cans
    RC - regular cab
    RFRM - rear-fed fuse and relay module
    ROFL - rolling on the floor laughing
    ROFLMAO - rolling on the floor laughing my ass off
    RSCA - roll sensing curtain airbags
    RTFM - read the f*cking manual
    RTG - ready to go
    RTMR - rear terminal mini fuse and relay
    RTT – roof top tent
    RTV - room temperature vulcanized (silicone)
    SAS - solid axle swap
    SFA - set forward axle
    SFW - safe (suitable) for work (websites)
    SHTF – sh*t hits the fan
    SMH - shaking my head
    SOA - spring over axle
    SOP – standard operating procedure
    SOSAD - same old song and dance
    SPDT - single pole double throw (electrical switch)
    SPST - single pole single throw (electrical switch)
    SQ - sound quality
    SR - sport Rally
    SR5 - sport rally 5-speed
    SS - stainless steel
    SSC – Special Service Campaign
    SUA - spring under axle
    Sum Ting Wong - "something wrong" (one of my favorites)
    TB – throttle body
    TEOTWAWKI – The end of the world as we know it
    TIA - thanks in advance
    TLDR - too long, didn't read
    TMI - too much information
    TN – ToyotaNation (forum) http://www.toyotanation.com/forum/
    TNGA - Toyota New Global Architecture
    TPMS - tire pressure monitor sensor (or system)
    TPS - throttle position sensor
    TSB - technical service bulletin
    TSS - Toyota Safety Sense (bundle of active safety features)
    TTORA – Toyota Territory Off-Roaders Association (forum)
    UHMW - ultra high molecular weight (polyethylene rope)
    UOA - used oil analysis
    UTQG - uniform tire quality grading
    VQ -V6 engine produced by Nissan
    VSC - vehicle stability control
    VSV - vacuum switching valve
    VVT - variable valve timing
    WDH - weight distribution hitch
    WFO - wide full (f*cking) open
    WOT – wide open throttle
    WP – water pump
    WRT - with regards to
    WTB - want to buy
    WTF - what the f*ck
    WTS - want to sell
    WTT - want to trade
    WVO - waste vegetable oil
    WWMD - What would MacGyver do?
    YMMV - your mileage may vary
    YOLO – you only live once
    Finally, acronyms for Acronym:
    Alphabetical Code for Remembering Odd Names You Make up
    A Coded Rendition Of Names Yielding Meaning
    A Contrived Reduction Of Nouns, Yielding Mnemonics
    Another Cryptic Rendition Of Nomenclature You Memorize
  2. Oct 14, 2014 at 12:54 PM
    Marine.Doc
    Marine.Doc Well-Known Member
    central Alabama
    2015 SR5 Prerunner V6
    Thanks, I needed that
  3. Oct 14, 2014 at 12:54 PM
    Large
    Large Red
    RTFM - Read the f*cking manual
  4. Oct 14, 2014 at 12:59 PM
    TacoGlenn
    PNW
    '13 MGMAC 2.7L SR5
    Thanks, but that's actually in the TW glossary.
    :) cheers
  5. Oct 14, 2014 at 2:00 PM
    lowprofile
    lowprofile Well-Known Member
    matthew
    central, ms
    '15 Prerunner V6 SR5 DCSB
    Very timely and helpful for me. I found this thread googling some of this stuff trying to decipher a post.
  6. Oct 14, 2014 at 2:03 PM
    Large
    Large Red
    EAD.
  7. Oct 14, 2014 at 2:04 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    :laughing:
  8. Oct 14, 2014 at 2:06 PM
    medic2230
    Murph
    Bama! Roll Tide
    OYG = Off You Go
  9. Oct 14, 2014 at 2:06 PM
    TacoGlenn
    PNW
    '13 MGMAC 2.7L SR5
    Does that mean "Engine and Alert Display" ?
  10. Oct 14, 2014 at 2:07 PM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    yup, exactly what it means :p
  11. Oct 14, 2014 at 2:09 PM
    TacoGlenn
    PNW
    '13 MGMAC 2.7L SR5
    okay, thanks for the input!
  12. Oct 14, 2014 at 2:14 PM
    geekhouse23
    Not an acronym, but a term you should know...
  13. Oct 14, 2014 at 2:16 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    :laugh:
  14. Oct 14, 2014 at 2:22 PM
    TacoGlenn
    PNW
    '13 MGMAC 2.7L SR5
    grazie!
  15. Oct 14, 2014 at 2:28 PM
    Yotabilly
    Yotabilly Well-Known Member
    The Bluegrass
    2013 4cyl,5spd.4x4 Reg Cab
    UWS low profile toolbox, tint, rainguards, color matched grill surround 265/75r16 Goodyear Duratracs Ultra-Guage XB fogs, Weathertech Floor Liners, OME 884s, 2"AAL, Bilstein 5100s, FJ Trail Team wheels, Matt123 skid plate, 30" light bar, Rigid Duallys, Bed extender
    What about WFO?
  16. Oct 14, 2014 at 2:36 PM
    TacoGlenn
    PNW
    '13 MGMAC 2.7L SR5
    wide full (f*cking) open?
  17. Oct 14, 2014 at 2:37 PM
    Yotabilly
    The Bluegrass
    :thumbsup:
  18. Oct 14, 2014 at 2:38 PM
    TacoGlenn
    PNW
    '13 MGMAC 2.7L SR5
    Danke!
  19. Oct 14, 2014 at 2:58 PM
    AndyTaco
    AndyTaco ACLBFTMW
    Andy
    Waco, TX
    '10 ACLB V6
    "Raptor Style" grill mod, aftermarket wheels, 265/75/16 Goodyear Wrangler Authorities, TRD Shoulder pads on seat belts, no mud flaps, AVS Hoodflector bug shield *removed*, Dee Zee Ultrablack Bull Bar w/ license plate mount, dipped my fuel door for no reason, N-Fab Spare tire mount w/ full size matching spare, dipped eyelids onto my headlights for no reason, dipped my hood for no reason
    :infantry:
  20. Oct 17, 2014 at 4:55 PM
    TacoGlenn
    PNW
    '13 MGMAC 2.7L SR5
    bump for new mem vis
