Tweeter wiring colors on my 2nd gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nd4spdbh, Mar 19, 2016.
  1. Mar 19, 2016 at 10:22 AM
    nd4spdbh
    nd4spdbh [OP] Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Maybe this will get more exposure here.
    Alright all. I am in the process of upgrading the stock tweeters and speakers in the front doors.
    I understand how the tweeters and front speakers are wired. The 4 pin plug to the tweeter simply combines like colors to run the tweeter in parallel connection with the main speaker.
    What i DO NOT get is the coloring. On the tweeter side its "standard" red and black. You would assume its + for red, and - for black. but that seems to be the opposite.
    The coloring on the harness side is Green and blue. Everything (including toyota factory service manuals) state that Green is POSITIVE, and blue is NEGATIVE (for the front right door) But look at the picture below, the red and blacks are flip flopped!!!! That is the green (positive on the harness side) goes to black, and blue (Negative on the harness side) goes to red.
    W T F.
    I have not moved any pins on the plug changed the configuration of how the wires were connected together. I simply chopped off the tweeter and crimped on connectors for my new ones.
    I am just wondering if the colors on the tweeter side of the factory front door tweeters are backwards!
  2. Mar 19, 2016 at 11:21 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    My prints from the field service manual says that Green is positive and Lavender is negative in the passenger door regardless of the model. And Pink is positive and Violet is Negative for the driver door on the Double Cab and Green is positive and Lavender is negative on the Access Cab.
  3. Mar 19, 2016 at 5:29 PM
    nd4spdbh
    SoCal
    yeah i ended up disregarding the colors on the tweeter side of the stock harness and did the positive of the new tweeters to the positive (green and pink on right n left doors)
  4. Feb 6, 2019 at 7:37 PM
    tbird95
    tbird95 No Longer a TRD sport, it’s a TRD OFF-ROAD.
    British Columbia, Canada
    TRD sport SR5 V6 DC, LB, 4x4, Tow package
    rearview mirror w/compass, temp & backup cam w/ pop luck PL 5400, Interior lights/gauges, BHLM, Uptop Overland Alpha rack, Relentless fabrication Predator plate front bumper. Third brake light LED swap. 3" Toytec (Boss) Coil overs, rear OME Dakar, JBA off-road UCA. TRD grill badge, MY CAR Smart Start, topper EZ lift, front and rear e-lockers, 4.88 gears, dasaita g13 head unit, molle panels everywhere, topper, decked drawe v2, dick Cepek DC2, Falken Wild-peak at3w, trailer plug relocate, group 31 marine battery, front and rear winch wiring, heated seats, sound deadened doors, roof and back wall, kicker front door complete speakers, Kenwood rear door 7” speakers, CBI full skid plate (aluminum), Dobinsons snorkel, steering wheel swap 2012-heated (cartrimhome), auto up/down power windows with illuminated switches full from 2012 (cartrimhome), guild outfitters anytime outlet, interior chrome delete, Subaru kicker tweeters. More coming
    Trying to figure out exactly what you did here? I get what you were looking for in the colors but why? Did you tap into existing wiring to add aftermarket? Im trying to add the subaru kicker tweeters into second gen. Its not plug n play like the third gens. Ideally if i could get a male plug for a taco, 4runner or subaru i could just splice it in now that i know the colors.
  5. Feb 6, 2019 at 8:24 PM
    nd4spdbh
    SoCal
    pull the stock tweeter off the truck. Note the positve and negative colors of the wires left on the door harness that go to the tweeter plug and main speaker plug. Now note how on the tweeter side of the plug the positive wire that goes to the main speaker is actually the black (or negative) for the tweeter. Chop that plug off the stock tweeter with some extra so you can wire in your aftermarket tweeter, but disregard the general idea that black is negative and red is positive as its backwards in reference to the door harness and main speaker. (they flip it like this with the stock tweeter to create a larger sound space)
  6. Feb 6, 2019 at 8:34 PM
    tbird95
    The plug is integrated and soldered to the tweeter. I literally need a factory male plug from a tacoma, 4 runner or subaru. But i understand now what was happening in this thread lol. Thanks. If you hear that anyone cut out their male harness from 2016+ taco point them my way i need 2.
  7. Feb 7, 2019 at 8:08 AM
    nd4spdbh
    SoCal
    Ah, the plug of the subaru tweeter is integrated into it? Good luck.
    Just do what i did grab some of these
    https://www.amazon.com/Pioneer-TS-T...id=1549555656&sr=8-2&keywords=pioneer+tweeter
    and use the plug off the original tweeter to plug into the harness.
  8. Aug 4, 2019 at 9:09 AM
    TXTaco211
    TXTaco211 Well-Known Member
    Corpus Christi, Tx
    13 Pyrite Mica TRD Sport DCSB
    Kicker Speakers, 5100's with HS coils and HS AAL, Caliraised 30" LED light bar
    what did you end up doing did you get this figured out I am in the same predicament as you were.
  9. Aug 4, 2019 at 9:11 AM
    tbird95
    Sent mine back. Still using factory.
  10. Aug 4, 2019 at 9:13 AM
    TXTaco211
    Corpus Christi, Tx
    damn not what I wanted to here.
  11. Sep 17, 2019 at 6:43 AM
    BEE-ROCK
    BEE-ROCK Well-Known Member
    Brock
    Dallas, TX
    2013 Tacoma TRD Sport
    TRD Pro Grille, TRD Pro Headlights, Bilstein 5100's and 5125’s.
  12. Sep 17, 2019 at 8:48 AM
    Corny Taco
    Corny Taco The Sauce
    Blake
    Columbus/Atlanta Georgia
    06 SR5 DCSB Prerunner
    -33 inch Nitto Ridge Grapplers -18 inch fuel kranks -Bilstein 5100s -OME normal duty dakars -Toytec/Eibach coils -Magnaflow off-road pro exhaust -Prinsu roof rack -nfab rock guards -EBay Faux Trd Pro Grille -Custom basshead audio build in progress
    Lol, when I installed my Skar tweets, I just snipped and wired to what was there. I gave no fucks and it miraculously turned out perfectly.
    stonybrook likes this.
  13. Feb 13, 2021 at 4:39 AM
    Ttfran1t
    Ttfran1t Well-Known Member
    Tim
    Mentor, Ohio
    2013 Grey Tacoma Sport Extended cab
    nothing as of yet
    So all you did wa
    So all you did was plug in these tweeters to factory harness? Can you explain how want to get better sound out of my tweeters cause replacing 6x9 soon thanks
  14. Feb 13, 2021 at 4:53 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    The Tweeter wiring is backwards because the capacitor that is the crossover for the tweeter inverts the signal. Positive in, negative out. The wiring is reversed so that all driver's are moving in the same direction with the music input.
  15. Feb 13, 2021 at 4:54 AM
    gearcruncher
    Canadain bumper technician
  16. Apr 24, 2021 at 5:57 PM
    Dmeezy333
    Dmeezy333 Well-Known Member
    2015 White Tacoma TRD Sport
    I'm guessing you are just reusing the stock harness clip?
  17. Apr 25, 2021 at 8:22 AM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
  18. Apr 25, 2021 at 9:33 AM
    Dmeezy333
    Thanks bro. I did find some on Amazon.
  19. Apr 25, 2021 at 9:55 AM
    gearcruncher
    i disconnected the front tweeters and used high power wiring from the cross overs and amp . the factory tweeter wiring cant handle 5000 watts
  20. Jul 4, 2022 at 7:10 AM
    caribe makaira
    Caribbean, Puerto Rico
    Jimmyh[QUOTED] likes this.
