Two blank spots beside the power outlets?
Discussion in '1st Gen. Tacomas (1995-2004)' started by custom1, May 27, 2012.
  1. Aug 18, 2012 at 8:08 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    You can get a fog light switch from a similar year Toyota Camry. It fits perfectly, without modification, and looks like it came from the factory. I use one for my HID off road lights.
  2. Aug 19, 2012 at 8:10 PM
    pyfaz
    pyfaz Well-Known Member
    Pyfaz Angulo
    brawley,ca
    01 PreRunner SR5 TRD
  3. Aug 3, 2016 at 1:20 PM
    erik530195
    erik530195 Instagram: @toyota_vintage
    2003 Tacoma Prerunner Double Cab TRD
    A.R.E. Bed Cover; Upgraded fender flares; PA System; spotlights on tow hitch
    Does anyone know the name or part number for the panels themselves? I plan on screwing something into one but want to order a spare to have on hand.
  4. Aug 4, 2016 at 7:53 AM
    SteadsN4LOW
    SteadsN4LOW I Like Toyota Trucks and the Grateful Dead
    Denver Colorado
    2002 Tacoma TRD
    Lots of Custom Stuff
    I have one that had factory fog light switch in it.... you want the switch? i cut up that area and put in a voltmeter and usb port!
  5. Aug 7, 2016 at 1:43 PM
    erik530195
    Thank you, but I don't need the switch, just the blank panel for backup. I will be drilling holes and if I ever take the accessory out I want a clean panel to put back without holes drilled in it. If you know the part name or anything let me know!
  6. Jan 15, 2021 at 6:42 AM
    Carl7
    Carl7 Member
    2004 Black Tacoma PreRunner
    Bump on an ancient thread to see if anyone ever tracked down link/part numbers for the original tan piece. My system is expanding and I’d like to get that section back to factory as I’ve added a switch panel elsewhere in the cab. Thanks
  7. Jan 15, 2021 at 7:20 AM
    reallifeonhold
    reallifeonhold Well-Known Member
    Travis
    2004 4WD 5MT
    I don't have a part number but they're easy to get from your local dealer. I picked one up a couple of months ago to mount a USB outlet on.
    Carl7[QUOTED] likes this.
  8. Jan 15, 2021 at 7:26 AM
    christsay
    christsay Well-Known Member
    chris
    Austin, TX / Santa Fe, NM
    2021 Army Green DCLB TRD 4x4
    JB Grand Raid Evo XXL mounted on an Alu-Cab. 5.29 gears.
    Since this thread got necro'd I'll answer this: Security system only uses one slot for the glass breakage sensor.
