Two options for lift - DCLB
Discussion in 'Suspension' started by mcbagpiper, Mar 11, 2014.
  1. Mar 11, 2014 at 1:40 PM
    mcbagpiper
    mcbagpiper [OP] Well-Known Member
    Ottawa, Canada
    14 DC/LB TRD Sport
    Tonneaupro hard tri-fold 3D Maxpider floor mats 10g steel skid plate N-Fab steps AVS bug guard & window visors 5100's @ 1.75" 1" steel rear blocks 265/70/17 Nitto Terra Grapplers Graphite metallic sport rims 20% front tint MBRP dual cat-back exhaust
    Gents,
    I've done several searches and read lots of good info on this site regarding lifts. Looking to bring my 14 DCLB (with TSB rear) up a few inches and I've narrowed down to two options from a budget and goal perspective.
    The truck is my daily driver, limited if any off-roading (camping and skiing) but I deal with heavy snow for a good portion of the year :mad:
    Option 1:
    Adjustable 5100's with stock TRD sport coils set to 1.75" + 1/4" toytec spacers on both sides ~ 2.25" front lift with a 1.5 aal.
    Option 2:
    Full OME kit (coils and shocks) with the 885 springs and 1.5aal - no spacer, so from what I've read approx 2.5" in the front.
    I don't want to deal with new UCA's and the other complexities of going 3" or over. The price difference between 1 and 2, when factoring shipping and duties etc, is about $350. I know the OME lift gets lots of support on this board however my question is this, if I'm not doing any off-roading will I even notice/appreciate the difference between the OME and 5100 with stock coil option?
  2. Mar 11, 2014 at 1:47 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    2
    but , with OME shocks , 884's , OME 5mm trim packer for driver's side , and 1/4" top plate spacers
  3. Mar 11, 2014 at 1:52 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
  4. Mar 11, 2014 at 1:57 PM
    mcbagpiper
    Ottawa, Canada
    14 DC/LB TRD Sport
    Thanks guys. Oz, from what I've read the 884 and 885's are the same spring rate (884's are just shorter), so why the 884 + 1/4" spacer vs. 885's alone?
    I'm not planning on a front bumper replacement or winch etc so are the 884's a better riding spring?
  5. Mar 11, 2014 at 2:04 PM
    geekhouse23
    OME884 390mm, 590lbs/in, 1 inch of lift
    OME885 395mm, 590lb/in, 1.5 to 2 inches of lift
    OME886 402mm, 660lbs/in, 2.5-3+ inches of lift
    http://tacoma-upgrade.com/2009/06/2...old-man-emu-spring-rates-and-lift-height.html
  6. Mar 11, 2014 at 2:10 PM
    mcbagpiper
    Ottawa, Canada
    14 DC/LB TRD Sport
    Perfect, thanks!
  7. Mar 11, 2014 at 2:12 PM
    SportyHeretic
    SportyHeretic Well-Known Member
    Jeremy
    Wyoming/South Carolina
    2010 Sport
    Icon Stage 3 Suspension, Diff Drop, MagnaFlow Cat-Back Exhaust, Tonneau Cover
  8. Mar 11, 2014 at 3:02 PM
    OZ-T
    Peter North
    British Columbia
    They are the same spring rate , but I think that going with 884's & 1/4" top plate spacers could reduce the chances of " over speed bump goes clank "
  9. Mar 11, 2014 at 3:24 PM
    rogs6266
    rogs6266 Well-Known Member
    Alliance, OHIO
    '13 TRD Sport 4X4 DCLB MGM
    SOS weld on sliders, SOS bed rack, SOS front aluminum winch bumper with center and head light hoops, Stealth 6 wheels wrapped in goodyear duratracs, 285-70/17 Beer opener in bed, Thule roof rack on factory rack, Tool box, bed mat, K&N cai, flowmaster side out duals, and tailgate extender, Fog light anytime mod, no mud flaps mod Weathertech full set, Wet okoles front and rears, full OME 886 suspension lift with Dakars in rear, smittybilt X20 comp 10 winch, factor 55 yellow pro link,
    I ordered my full OME kit with dakars, 885 with sport shocks front and rear and no top spacer but did do the trim packer for drivers side and got the LR UCA's, diff drop kit just in case along with CB drop kit from headstrong. I received the $30 off discount for being a TW member. Marie was awesome to deal with and will answer all your questions. Received everything in exactly one week and im on the east coast. Great price. Saved about 500 going thru Headstrong. I even had them mount the springs for me. Long story short they all get put on this weekend. Cant wait. I have a 13 TRD sport DCLB 4X4. My lil boy becomes a man this weekend!
  10. Mar 12, 2014 at 7:22 PM
    swampcreek
    swampcreek Active Member
    Pasadena MD
    '13 TRD DCLB & '09 SR5 ACLB
    You'll have to show us the end result with some pic's, I have the same truck with a Leer shell. I really need to get this thing lifted and your choice sounds about what I need.
  11. Mar 14, 2014 at 7:12 PM
    mcbagpiper
    Ottawa, Canada
    14 DC/LB TRD Sport
    Good luck with the install rogs6266, make sure you post pics!
