TW's active 4runner builders BS thread
Discussion in '4Runners' started by ramonortiz55, Jul 21, 2015.
  1. Mar 2, 2017 at 11:04 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Sounds similar to my local pricing, we're a bit higher.
  2. Mar 2, 2017 at 11:05 AM
    RedRunner87
    RedRunner87 Mall Crawler LVL Expert
    Vince
    The Springs, CO
    16 4Runner SR5
    255/80 Falken Wildpeak AT3W
    He bought his in Phoenix. Not a bad deal since he had to special order for the color and transmission
  3. Mar 2, 2017 at 11:13 AM
    MattJakobs
    MattJakobs Everything but a Tacoma
    Matthew
    NorCal
    1985 4Runner w/ FlipPac
    I have an ARB sitting at my parents house and will take measurements for the mounting rails tomorrow. My rack will end up being right at 7 feet long and I'll be adding 2 1/2" X 1/8" sheets to each side to make it look a little cleaner. Depending on how far away the top and bottom rail are apart on the awning may or may not change the height of that aluminum sheet. Assuming I won't end up with a 4" tall plate on each side, that's my plan as if now. I plan on mounting the awning to that sheet by drilling through it. If the awning mounting rails are in fact further than I think, I'll get an aluminum sheet at 7' x 5" x 1/8" and have someone laser cut out where I'll mount the awning. The 1/8" thickness is up in the air depending on flex.
    For this weekend, I'm hoping I can build at least the frame and mounting points to the roof. Once I have that done, figuring out how to mount the awning will be much easier
    ERMB and RedRunner87 like this.
  4. Mar 2, 2017 at 11:31 AM
    T4RFTMFW
    These are in NorCal and for sale.. spread the word if anybody wants.
    Ultra Gauntlet 17x9. Center caps, wheels, lug nuts (no tires/no TPMS).
    RedRunner87 likes this.
  5. Mar 2, 2017 at 11:48 AM
    MattJakobs
    Matthew
    NorCal
    So looks like on an ARB awning the mounting tracks are roughly 1 7/8" on center and the overall height of the mounting plate is 2 3/8". Just got the dimensions from my dad so I'll double check this weekend. It's the ARB 2000 so the overall length is just shy of 79". The length of the rack will be in the 84" range.
    Plans for the plating are going to be 84" x 1/4 x 2 1/2". That should give me enough thickness to safely mount the awning on and height so I won't have to make any weird cut sections.
    T4RFTMFW likes this.
  6. Mar 2, 2017 at 11:53 AM
    SixthSnail
    SixthSnail I have no idea what I'm doing
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
  7. Mar 2, 2017 at 12:02 PM
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Got your PM - Still waiting on an update from vendor - I sent them a reminder.
  8. Mar 2, 2017 at 12:09 PM
    ramonortiz55
    Ramon
    Texas
    stock
    Copy/Paste:
    4runner coilovers all come standard with a 14" 650lb spring.
    There is NOT currently an option for remote reservoirs either with our without clickers and remote reservoir rear shocks with or without clickers for the 4runners. However they are looking to possibly develop this in the future.
    dtaco06 likes this.
  9. Mar 2, 2017 at 12:18 PM
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    He's told me to remind him haha
    dtaco06[QUOTED] likes this.
  10. Mar 2, 2017 at 12:19 PM
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Wtf...
  11. Mar 2, 2017 at 12:23 PM
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    I know. I'm really a fan of the adjustability of clickers though
    ramonortiz55[OP] likes this.
  12. Mar 2, 2017 at 1:25 PM
    ERMB
    ERMB Well-Known Member
    2002 Land Cruiser
    Sounds like a good plan. Unistrut has all their own fasteners and accessories area at home depot in my area. I bet you may be able to create a mounting system for your ARB awning using some of their accessory pieces. It's pretty stout stuff made out of 1/4in or 3/8in steel and it's got a galvi-zink dip already on it. Some other things I've found useful are in the construction hardware area and are usually all galvinized too. I made my hi-lift mounts out of some of those materials and it worked out quite well.
    MattJakobs[QUOTED] and T4RFTMFW like this.
  13. Mar 2, 2017 at 1:32 PM
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
  14. Mar 2, 2017 at 1:47 PM
    MattJakobs
    Matthew
    NorCal
    Browsing their site now, just found a 90 degree angle bracket that should work perfectly. Looks like the holes should line up with what my dad sent me from the awning.
    I'm sure I could figure out some easy hilift mounts with their stuff too. Thanks for sharing this man! I'll be sure to post pictures to your thread
    ERMB[QUOTED] and T4RFTMFW like this.
  15. Mar 2, 2017 at 3:45 PM
    4x4runner2002
    4x4runner2002 Well-Known Member
    Zach
    2002 4x4 limited
    suspension and armor
    Dang looks like a productive weekend for you. If you don't finish the rack sat we can finish it Sunday.
    I'll have my version of a cordless impact to swap your cvs. Co2 and and pneumatic impact and I have the correct socket.
    I just pulled the cvs off the parts car yesterday and the body and frame are gone tomorrow. Woot woot.
  16. Mar 2, 2017 at 4:10 PM
    .45 JHP
    .45 JHP Doesn't even own a Tacoma
    37.3582115,-121.9281197
    2015 4Runner TRD Pro
    King is king. Do it!
  17. Mar 2, 2017 at 4:16 PM
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    I am... Just trying to get a quote right now so I can order.
  18. Mar 2, 2017 at 5:36 PM
    rjsimz
    rjsimz Well-Known Member
    Rob
    Huntersville, NC
    13 4x4 DCLB
    I'm very curious as to how much you made out on that part out. It looks like it's going really fkn well.
    4x4runner2002[QUOTED] likes this.
  19. Mar 2, 2017 at 5:39 PM
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Alright. Ordering Kings from the other GB (Sorry @ramonortiz55). Just waiting to see if I can pay through paypal or something. They want card info via pm and I don't really trust TW security with my credit card info.
    LTDSC likes this.
  20. Mar 2, 2017 at 5:39 PM
    ramonortiz55
    Ramon
    Texas
    stock
    ill do your CC via PM
    SixthSnail[QUOTED] likes this.
