TW's active 4runner builders BS thread
Discussion in '4Runners' started by ramonortiz55, Jul 21, 2015.
  1. Mar 8, 2017 at 9:40 PM
    tacomgee
    tacomgee just ain't care....
    Blake
    NorCal - Ukiah
    2009 DCLB SAS in the works
    I think i got 20% through REI. And free shipping to the stire which was close to my house.
    Turned into a mess when my order got mysteriously deleted then re-entered and the month I had already waited got lost. Pretty lame, but it worked out. The savings were worth it between the free shipping and 20% off.
  2. Mar 9, 2017 at 6:57 AM
    mr optimist
    mr optimist Mr Lazy
    Sam
    Alamosa, CO
    1998 4runner SR5 5 speed
    Supercharged, 5 speed, AOR Sliders, Tundra Front Springs, OME 906 Rear springs, Bilstein Tundra 5100s, Factory Diff lock, Wrangler Authority 275/75/16
    If that works let me know. I want to see how high it really is. Shirty part of not having a bed... Mounts way high.
    Change the wallpaper on her phone... Subtile
    I ended up liking where I mounted mine. The left lower side is cut off by the wheel, but it isn't that big of a deal
  3. Mar 9, 2017 at 7:00 AM
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    I had no idea where I could mount my ultra gauge.
    I settled for the scangauge and mounted it in the sunglasses holder.
  4. Mar 9, 2017 at 7:03 AM
    mr optimist
    mr optimist Mr Lazy
    Sam
    Alamosa, CO
    I tried a bunch of places and that was the most out of the way. If I had to do it again Idk if I would get an ultragauge. It does an awful job of calculating mpg, gallons used, and distance remaining. May have to do with the supercharger, probably more to do with the return fuel system not acurately measuring gallons pumped. Who knows.
  5. Mar 9, 2017 at 7:08 AM
    RedRunner87
    RedRunner87 Mall Crawler LVL Expert
    Vince
    The Springs, CO
    16 4Runner SR5
    255/80 Falken Wildpeak AT3W
    It will be interesting since I'm mounting on the stock rails for now. I'm thinking of mounting the ultra gauge next to the cup holders. Kind of out of the way.
  6. Mar 9, 2017 at 7:09 AM
    ramonortiz55
    Ramon
    Texas
    stock
    I didn't care about the MPGs, etc, because I know I would forget to reset the ultragauge during every fill up. lol
  7. Mar 9, 2017 at 7:09 AM
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Lazy
    mr optimist likes this.
  8. Mar 9, 2017 at 7:10 AM
    ramonortiz55
    Ramon
    Texas
    stock
    very
  9. Mar 9, 2017 at 7:13 AM
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    My main use is tracking oil changes and CEL's since my CEL doesn't work.
  10. Mar 9, 2017 at 7:14 AM
    ramonortiz55
    Ramon
    Texas
    stock
    ah.
    The scangauge will track CELs and monitor the transmission temps. I settled for that,.
  11. Mar 9, 2017 at 7:14 AM
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Can't track trans temps on my year 4Runner :(
  12. Mar 9, 2017 at 7:54 AM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    4th gen uses DOT4 brake fluid?
  13. Mar 9, 2017 at 7:56 AM
    mr optimist
    mr optimist Mr Lazy
    Sam
    Alamosa, CO
    I have 2 extra stock crossbars you can have for a 6 pack of Miller lite. Lol
    I have a cel that likes to pop up every few thousand miles. Also where I go it is really nice to know how much gas you are sitting at. Not a lot of services and has stations.
    It is a pain in the ass. Don't lie. Lol
    Get a transmission that doesn't need a gauge. And I am sure you could get an aftermarket gauge to go with an external cooler, which you should have anyways....
  14. Mar 9, 2017 at 8:02 AM
    ramonortiz55
    Ramon
    Texas
    stock
    or he can wire up a gauge. It's not too hard
  15. Mar 9, 2017 at 8:11 AM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    DOT 3 I believe, but look at the cap of the MC to verify.
    LTDSC[QUOTED] likes this.
  16. Mar 9, 2017 at 8:11 AM
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    That might be a plan. It's a pain but not terrible to reset. I wish I could do a manual swap not sure if the limited transfer case works with the manual.
  17. Mar 9, 2017 at 8:12 AM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    thanks ill make sure to look. Was trying to line up all the things ill need soon.
    My extended brake lines come in today.
  18. Mar 9, 2017 at 8:27 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Aren't DOT3/4 interchangeable anyway?
  19. Mar 9, 2017 at 8:57 AM
    mr optimist
    mr optimist Mr Lazy
    Sam
    Alamosa, CO
    Yeah probably better to not be the first one to try that. Are you swapping the granny yourself or having someone do it?
  20. Mar 9, 2017 at 10:26 AM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    They are interchangeable (you can go to 4 from 3, but not 4 to 3) but it is not recommended to mix them. So, unless you are doing a full flush to switch from one to the other, it is usually best to stick to whatever is already in there. 3 is specd from the factory, so even when I did a full flush I just stuck with 3. Internal seals are also designed for a specific fluid, and should be stuck with. Here is a good article.
    http://www.stoptech.com/technical-support/technical-white-papers/brake-fluid
    T4RFTMFW[QUOTED] likes this.
