TW's active 4runner builders BS thread
Discussion in '4Runners' started by ramonortiz55, Jul 21, 2015.
  1. Feb 17, 2018 at 11:32 AM
    RedRunner87
    RedRunner87 Mall Crawler LVL Expert
    Vince
    The Springs, CO
    16 4Runner SR5
    255/80 Falken Wildpeak AT3W
    Well here is the new ride, 2016 SR5
  2. Feb 17, 2018 at 10:54 PM
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    My tax return says maybe I should shove a winch in my new front bumper. Thoughts? I'd need to change spring rates and probably revalve while the coil is off.
  3. Feb 17, 2018 at 11:11 PM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    What do you have?
  4. Feb 17, 2018 at 11:27 PM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    I think I'm going to mount mine below the radiator hahaha. Like right in front of the LCA's
  5. Feb 17, 2018 at 11:35 PM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    If I do it, I’m going to shove it in as far as possible. You should see what I have planned for the core support body mounts
  6. Feb 18, 2018 at 8:53 AM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Winch ordered. Really starting to be an expensive bumper build after buying a winch and a 20" Baja Designs bar
    dtaco06, swalters and stumbles like this.
  7. Feb 18, 2018 at 8:58 AM
    MattJakobs
    MattJakobs Everything but a Tacoma
    Matthew
    NorCal
    1985 4Runner w/ FlipPac
    What one did you go with? Synthetic, steel?
  8. Feb 18, 2018 at 9:09 AM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Shittybuilt 9.5k synthetic. https://www.amazon.com/gp/product/B00K150ZNG/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
    The bummer is, even if I really like it, it's going bye bye when I SAS because I'm making new frame rails, no way around that. My goal is just the experience so when it comes time to fab the bumper post-SAS, I can make it even better.
    dtaco06 likes this.
  9. Feb 18, 2018 at 12:52 PM
    Unner
    Unner Well-Known Member
    Huntsville, AL
    01 4Runner 4x4, 08 4Runner 4x4
    2001 4Runner, Lifted, Armored, 33s 2008 4Runner Stock
    @4Running Daily
    It might be too late, but you can probably save a good chunk of change if uoy get your winch like I did.
    I found this website, which has it for $387,
    https://www.discountbandit.com/vehi...-5-gen-2-winch-with-synthetic-line-98495.html
    but it seems a little sketchy so I had Morris 4x4 price match it online since they garuntee a price match. They matched it no problem so I got my winch shipped to my door for $380.
    Some people hate on Smittybilt, but I really like mine and you can't beat the price. I just spooled it this morning to check the function like I do every couple months. Still works!
  10. Feb 18, 2018 at 12:55 PM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Nice! I’ll see if I can cancel my order
  11. Feb 18, 2018 at 1:04 PM
    Unner
    Huntsville, AL
    Maybe Amazon will price match also, not sure if they do that or not. Good luck! Worth a shot at saving $80.
  12. Feb 18, 2018 at 1:22 PM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    They fucked my weekend up royally, sent me 3/4” instead of 7/8” shaft 2.0 joints for the upper links. Got everything pulled apart and ready to install and pulled them out of the box . . . Fuuuuuuuck.
    They better have them in stock and overnight them tomorrow.
  13. Feb 18, 2018 at 1:24 PM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Also, the 2.63 joints just barely fit the ruffstuff brackets, had to take the zerks off so they could rotate.
  14. Feb 18, 2018 at 3:23 PM
    swalters
    swalters Well-Known Member
    Samantha
    Apache Junction, AZ
    2004 Tundra SR5 4x4 V8
    Brute Force Fab front bumper, 5100s, 35" Toyo RTs on Icon Six Speeds
    So my truck wouldn't start. It had one single click and nothing. The battery is brand new and we just replaced the starter contacts thinking that was the problem. It's not. Any other ideas?
  15. Feb 18, 2018 at 3:25 PM
    MattJakobs
    Matthew
    NorCal
    Have you checked your grounds? And all connections to/from the battery?
  16. Feb 18, 2018 at 3:27 PM
    swalters
    Samantha
    Apache Junction, AZ
    That's next step. Everything looks good at a glance but we're gonna crawl under it and follow everything.
  17. Feb 18, 2018 at 3:29 PM
    MattJakobs
    Matthew
    NorCal
    When I did my contacts and plunger, I thought my starter was out but it was just a bad connection on the battery.
    Also, if you pop the fuse cover in the engine bay, the starter relay is in there. You should be able to hear it click. No click=no good
  18. Feb 18, 2018 at 3:32 PM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Just the wire that goes from the battery to the starter. You can test this by "jumping it". Take a jumper cable from the battery and touching the bolt on the starter.
  19. Feb 18, 2018 at 3:34 PM
    swalters
    Samantha
    Apache Junction, AZ
    Yeah we hear a single click then nothing. Even when we tried jumping it there was no change.
    I'll have Aaron try that, thanks
  20. Feb 18, 2018 at 3:37 PM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Make sure the keys are turned to on the position haha
