TW's active 4runner builders BS thread
Discussion in '4Runners' started by ramonortiz55, Jul 21, 2015.
  1. Jul 23, 2018 at 9:21 PM
    4x4runner2002
    4x4runner2002 Well-Known Member
    Zach
    2002 4x4 limited
    suspension and armor
    Sounds like you might need to probe around with a multimeter and see if and where it’s getting power. Maybe there is a broken or melted wire somewhere.
    AssBurns[QUOTED] likes this.
  2. Jul 23, 2018 at 10:05 PM
    4x4runner2002
    Zach
    2002 4x4 limited
    It’ll be your secret anti theft mod.
  3. Jul 23, 2018 at 11:05 PM
    4WALKER
    4WALKER Save the manual trans!!!
    1991 4runner 5 speed SR5 4X4
    Dirt
    No. In the run position and running I should have said. The pump may prime on initial key on to run position in anticipation of cranking. Again it would be a pre programmed ecm timing though. You need the ecm pinout diagram to check for power from it if you know the wire harness is good for efi module and fuel pump.
  4. Jul 24, 2018 at 7:16 AM
    Unner
    Unner Well-Known Member
    Huntsville, AL
    01 4Runner 4x4, 08 4Runner 4x4
    2001 4Runner, Lifted, Armored, 33s 2008 4Runner Stock
    The fuel pump doesn't turn on at the on position. I believe you can use the diagnostic box in the engine bay that's connected to the intake manifold to "jump" the fuel pump and make it run without the engine on. Just need a paper clip and the right pins. Might be helpful in troubleshooting.
  5. Jul 24, 2018 at 8:19 AM
    Unner
    Huntsville, AL
    Yeah you don't even need to put power into that pin straight from the battery. One of those pins is a 12V hot, B+ usually I believe. So take a paper clip or jumper wire and go from B+ to FP and that should get you 12V to the fuel pump. I'd just verify those pins that B+ is 12V and FP is Fuel Pump, I'm 99% sure they are, but I don't want you to fry something in case I'm wrong...
  6. Jul 24, 2018 at 8:24 AM
    4WALKER
    Dirt
    Paper clips are good but I recommend a fusible link just in case something is shorted to ground. Battery power jumped to ground with a paper clip is no fun.
    dtaco06 and Unner like this.
  7. Jul 24, 2018 at 4:49 PM
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Marlin crawlbox purchased. Guesses on how many years before I install it
    Jonesn13, Unner, stumbles and 2 others like this.
  8. Jul 24, 2018 at 5:01 PM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Picking it up Thursday done or not.
    Bought it used 30 minutes from your house for $1k
  9. Jul 24, 2018 at 5:04 PM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    92377 whatever City that is. Sitting in 215S currently
  10. Jul 24, 2018 at 5:05 PM
    stumbles
    stumbles 1 eye
    bryan
    mesa
    2002 White Double Cab
    After my Atlas. :p
  11. Jul 24, 2018 at 5:17 PM
    stumbles
    stumbles 1 eye
    bryan
    mesa
  12. Jul 24, 2018 at 5:19 PM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
  13. Jul 24, 2018 at 5:20 PM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Also, I really fucking hate the 215
    dtaco06 and AssBurns like this.
  14. Jul 24, 2018 at 8:19 PM
    4WALKER
    Dirt
    Tug on wire harnesses to make sure they aren't pinched somewhere then inspect for welding slag that may have melted the harness
  15. Jul 24, 2018 at 8:56 PM
    Unner
    Huntsville, AL
    7, maybe 8?
    Well it was worth a shot. At least you know it's probably a wiring issue and not related to the ignition switch or something.
    Could a rodent have gotten under the truck and chewed the wires? I'm always worried about those mice in the desert chewing a wire and leaving me stranded...
    The rocker switch works too though, and adds a little theft protection.
  16. Jul 25, 2018 at 4:06 PM
    4x4runner2002
    Zach
    2002 4x4 limited
    This Mexican made me jealous.
    4Running Daily and Jonesn13 like this.
  17. Jul 25, 2018 at 4:11 PM
    Jonesn13
    Jonesn13 Nifty
    Tempe, AZ
    '16 T4R Trail Premium, 08 AC 4x4 6spd(Sold)
    Some, Suspension and stuff, tires, maybeh some armor.
    Whoa. That front end kinda reminds me of that awful VW.
    Still jealous. Even more so if it's a diesel
  18. Jul 25, 2018 at 4:27 PM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    They come in diesel
    dtaco06 and 4x4runner2002 like this.
  19. Jul 26, 2018 at 9:56 AM
    SixthSnail
    SixthSnail I have no idea what I'm doing
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    If you were looking at buying a third gen 4runner with 201k miles on it, what would you look for as potential red flags.
  20. Jul 26, 2018 at 11:01 AM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Depends on year, but I avoid the 01, 02’s for their transfer case and brake booster. Otherwise, transmission fluid on autos for pink milkshake. Timing belt done near 120k, at 200 probably close for round 2.
